Is the Suzuki Jimny good for the Gibb River Road trip?
Submitted: Friday, Aug 30, 2024 at 07:30
ThreadID: 148368 Views:1845 Replies:11 FollowUps:5
Hi All,
I would like to tackle the Gibb River Road in January 2025. Would the 4WD Suzuki Jimny good for the trip? Tank you in advance for your wisdom.
QC
Reply By: Stephen L (Clare) SA - Friday, Aug 30, 2024 at 08:57
Are you aware that’s the wet season and you may need a pontoon to ford some of the crossings
Smile like a Crocodile
AnswerID: 646433
Reply By: Member - Jim S1 - Friday, Aug 30, 2024 at 09:06
Jimny will be fine. Take your time , and don't go in the "wet" season.
Jim
"Sometimes I sits and thinks, and sometimes I just sits." A fisherman.
"No road is long with good company." Traditional
AnswerID: 646434
Reply By: Mikee5 - Friday, Aug 30, 2024 at 12:20
Most places along the Gibb will be shut for the wet season, the roads will probably be closed at least in part due to the rain. The heat will be unbearable. It isn’t a good time to visit.
AnswerID: 646439
Reply By: Quang C - Friday, Aug 30, 2024 at 22:53
Thank you all for your comments. I will have to schedule the trip in the dry season then, perhaps early October this year.
AnswerID: 646442
Follow Up By: Member - McLaren3030 - Saturday, Aug 31, 2024 at 08:00
Hi Quang,
Even in early October, some places may be closed. I would suggest you go on line to the W.A. National Parks Website and check when parks etc. in The Kimberley close. Also, there is likely to be little water at any of the waterfalls that the Kimberley is renowned for.
FollowupID: 926996
Follow Up By: Member - Cuppa - Sunday, Sep 01, 2024 at 09:27
Macca is correct & this year , based on recent temperatures - up into the mid 40's already, October could be a real doozy. Not only will most places be closed then & the temperatures high, you need to consider how much more 'remote' the route will be then with very little other traffic. The high temps won't just affect you, they will place a great deal more pressure on your tyres & your vehicle in general. You may find it impractical to drive with air con on due to the need to reduce pressure on the engine to keep it cool.
If you are able, the best time to go is very early in the season, as soon as possible after the road opens. Generally late May/early June... but it can vary from year to year. At that time instead of brown dust, things will still be green & all the main attractions will be at their best with water flowing. Places will be open & there will be others on the road, although if you get in early enough river crossings may still be putting off the less adventurous, so it wont be too busy & if you have time to wait at crossings that are too deep (with plenty of provisions on board) you would have the best adventure.
See 'My Profile' (below) for link to our Aussie travel blog, now in it's 6th year.
FollowupID: 927010
Follow Up By: Member - peter_mcc - Sunday, Sep 01, 2024 at 10:07
As the others have said, don't go too late in the season. The gorges will be dry and/or green and it will be hot. Our experience in June was a million times better than our friends who went in October. We swam at every gorge and had a great time, can't wait to get back. They spent days stuck in the car on a corrugated dusty road with it being too hot to get out and too dry to swim.
FollowupID: 927011
Reply By: The Explorer - Saturday, Aug 31, 2024 at 19:01
Hello - Jimny fine - it's just a gravel road (albeit remote, with some large "gravel"). You could drive a Hyundia Getz down it (driving to conditions). Some side roads a different story but Jimny great option. As others have indicated, time of year is a more important consideration. Did it in 1998 in RAV 4 easy peasy - so you will slay it.
Greg (my real first name)
AnswerID: 646453
Follow Up By: Zippo - Sunday, Sep 01, 2024 at 10:41
A Getz (or i30 ...) may struggle with the Pentecost. But a Jimny would probably float across the deeper bits.
FollowupID: 927012
Follow Up By: The Explorer - Sunday, Sep 01, 2024 at 18:11
With any low clearance vehicles wheel placement on the tricky bits would be the key (if you could see under the water :).. but I have no doubt you could do it. It's not a "4WD" track, though agree you would have to desperate/crazy to take a normal car down there.
FollowupID: 927016
Reply By: Quang C - Sunday, Sep 01, 2024 at 14:01
Many thanks for your invaluable advice!
AnswerID: 646461
Reply By: Member - peter g28 - Saturday, Sep 14, 2024 at 15:02
Agree with what others have mentioned about your January 2025 departure..
In regards to your Jimny, it will do the trip..but with a few caveats regarding you the driver..
1/. The road in places can be very rutty and with the small wheel base of the Jimny..it would become a bit uncomfortable after a few k's of corrugations.
Just be known..you are going to get uncomfortable and tired..
So take in mind, long day driving distances will be a challenge..
2/. The Jimny has a petrol engine with a small fuel tank..about a 600km range in perfect conditions.."the Gibb ain't perfect conditions"..and you will be carrying stuff..so the vehicle will weigh higher..so that 6ltr /100 you get?...
nah..work on doubling that..
So drop that 600k range back to about 400-450km and from that work out your stopping and refuelling places..because it gives you a 100 -150km buffer to play with.
Learn and practice on how to use the vehicles trip A & B computer, combine this with using the ExploreOz Traveller App whilst travelling offline at the same time.
It's very very handy...
3/. Tyres, the standard tyres..nah..go and get some good quality AT tyres with very good sidewall protection and a compact block tread pattern..including the spare!!!!!
4/.Get a decent hand held 5watt UHF or get one inbuilt into the vehicle and a PLB..you will need these..and learn how to use them..please.
5/. First Aid kit..including a snake bite bandage...and practice how to use the kit plus the bandage..you might not need to use it, but you may come across someone who will.
6/. Fuses and circuit breakers..find out where they are located in the vehicle..then go and get some spares of BOTH, specific to the amps of your vehicle.
Some circuit breakers aren't cheap..but worth their weight in gold..
I have seen people stranded all because a circuit breaker or a fuse has shite itself, they have stopped for a break and tried to start to vehicle after a long of hours driving.
7/. Take out the highest Roadside Service plan ie NRMA / RACV have as they will be your backup.
Apart from that..have fun and enjoy yourself..
AnswerID: 646510
Reply By: mark s57 - Tuesday, Sep 17, 2024 at 18:10
The Suzuki Jimny can be a good choice for a trip on the Gibb river road, but there are a few factors to consider:
Pros:
Compact Size: The Jimny’s small size makes it highly maneuverable, which is advantageous on narrow and rough roads.
Off-Road Capability: The Jimny is well-regarded for its off-road capabilities, including features like 4WD and high ground clearance, which are beneficial for tackling the rough terrain of the Gibb River Road.
Cons:
Limited Space: The Jimny is a small vehicle, so cargo space and comfort for long journeys can be limited. Make sure you pack efficiently.
Comfort and Amenities: The Jimny’s ride can be quite rugged and basic compared to larger, more luxury-oriented 4WDs. Be prepared for a less comfortable ride.
AnswerID: 646521
Reply By: Hoyks - Sunday, Sep 22, 2024 at 16:28
Fuel range may be an issue, as a guess all loaded up you'll be lucky to get 400km from a tank?
You'll want to think about a long range tank as jerry cans will eat into your limited space and a single jerry on a roof rack will put you over the roof load limit.
You can probably do it one way, but it will limit side trips and may be an issue if you need to backtrack. Some places only have diesel available too.
AnswerID: 646538
Reply By: Peter_n_Margaret - Monday, Sep 23, 2024 at 13:15
For crying out loud you blokes. :)
The Gibb River Road is a wide graded road. Sometimes the grader has not been for a while and it gets a bit chopped up and there are a couple of river crossings that need caution, but frankly, I have driven Minis on roads that are at least as bad.
Your biggest risk is driving too fast and avoiding others that do likewise.
AnswerID: 646543
Reply By: George L4 - Friday, Oct 04, 2024 at 00:48
I think it doesn't good enough for long travelling.
AnswerID: 646595
