Garmin Overlander
Submitted: Monday, Aug 26, 2024 at 16:25
ThreadID: 148328 Views:2623 Replies:4 FollowUps:2
Hi travellers, bit of a newbie here with GPS. Can anyone tell me how to if possible load Exploroz maps on to a Garmin Overlander ?
Thanks Mick.
Reply By: The Explorer - Monday, Aug 26, 2024 at 19:13
Hello - not possible - totally different system. Exploroz maps can only be used on Exploroz Traveller, and no other maps can be used in Exploroz Traveller except the ones supplied. Not sure what other maps maybe available for the Overlander from other sources. Some people found Shonkymaps handy for some Garmin devices but that was years ago...not sure it still works with newer Garmins.
Cheers Greg
AnswerID: 646401
Follow Up By: Member - peter g28 - Wednesday, Aug 28, 2024 at 11:00
Agreed..
The Exploreoz maps are only compatible with the Traveller App and is designed to used on either Apple or Android mobile devices.
The best you could do..is get the model of Garmin device you are using...and check its' specs to see what type of mapping format that is compatible with it..
Garmin have their own system and check their own website named Garmin Explore and I believe it has maps you can download from there.
FollowupID: 926973
Reply By: Member - wicket - Monday, Aug 26, 2024 at 19:50
These are nice. (free) maps, you will have to check if they work with the garmin though.
https://www.getlost.com.au/
AnswerID: 646402
Follow Up By: The Explorer - Monday, Aug 26, 2024 at 20:36
Hello
None of those maps will work directly with a Garmin gps unit. They are raster format not directly compatible with Garmin units. It is possible to convert smaller maps (i.e. smaller file size) so as to make them compatible but wouldn't bother as using raster maps is not one of Garmins high points.
FollowupID: 926960
Reply By: Member Vlas (VIC) - Wednesday, Aug 28, 2024 at 16:33
Hi Michael
You can download and use open street maps free.
I have been using them on my Garmin handheld GPS also on my pc using Basecamp. You have to download the Basecamp version.
Link :https://alternativaslibres.org/en/downloads.php
Bill
AnswerID: 646426
Reply By: Member - Boxer Mechaniker - Friday, Nov 15, 2024 at 10:53
The Tread editions are Android OS so you can sideload apps.
No support provided by ExplorOZ though.
AnswerID: 646809
