Mystery noise coming from Van wheel area.
Submitted: Monday, Aug 19, 2024 at 20:35
Member - Scratcher
Hi guys/gals,
We have a 2016 Blue Sky mini dakar 17.6 foot off road van which has developed a very bad noise in the wheel region. A mechanic has checked bearings, hand break mechanisim, electric brakes and has given the all clear, but the noisy,scrapping,rattling noise still persists. As the driver I can only hear it at slow speed ie when in caravan park, and other campers are quick to let me know about it but dont have a solution. Any help from fellow members would be appreciated.
Scratcher.
Reply By: Member - bungarra (WA) - Monday, Aug 19, 2024 at 21:06
Pull the brake drum completely off.
It could be a tiny iron stone pebble that is probably as hard as the brake drum. It is going to be impossible to find without disassembly. If your mechanic didn't pull the drum off and just checked the bearing by jacking and wobbling, then if it's as I suggested it would not have been found.
I had this exact iron stone pebble once and the noise was horrifying
646372
Reply By: RMD - Monday, Aug 19, 2024 at 21:42
Scratcher.
Did the mechanic remove the hub/drum off the axle to
check bearings? If NOT, he hasn't checked the bearings at all, just felt the adjustment slack if any!
If the hub was removed from the axle then any anomaly should be able to be identified. ie, stone as above.
It is normal for an electric brake magnet to hang on the drum and flutter sometimes. A slight mount of braking voltage, ie, minimum controller setting, should adhere the magnet to the inner drum face but not apply the brake during forward motion and stop the rattle, but some slight scraping may still be heard.
Without removing the hub, but having the brakes backed off so NO shoe contact is happening is the only way to hear the magnet. rather than the shoes scraping slightly. Adjust properly afterwards.
If hub hasn't been removed you cannot discount any magnet problem even though they may apply the brakes as normal. They DO WEAR THINNER, and OR tapered or BOTH and should be checked for thickness and integrity.
Any decent real
check should ID the problem IF abnormal in sounds!
Another possible is, Some hub/drums have insufficient stop facing inside the drum to accommodate the head of the wheel studs to be below the inner face where the magnet runs. The stud heads, only takes 1, if becoming proud of the surface will flick the magnet as the drum rotates. Again, it will be seen if apart and LOOKED AT.
646373
Reply By: Member - Scratcher - Tuesday, Aug 20, 2024 at 11:16
thanks for the help Guys,
but as I speak my local mechanic has just found some slack in the bolt mountings at both top and bottom of the shockers. Not sure on a solution just yet. Will keep in touch.
Scratcher
646376
Reply By: Member - Broodie H3 - Monday, Aug 26, 2024 at 10:49
Hi Scatcher, I had the same issue on our big lap and fixed it in Gympie in Qld. the problem was a magnet had come away from its mounting, and had been doing it for some time. I had to replace the whole brake assembly and backing plate . I still to this day still don't understand how it came off the hook on the magnet arm. I hope this helps. good luck
646397
Follow Up By: Member - Scratcher - Tuesday, Sep 03, 2024 at 13:43
Thanks Brodie,
but in our case we think the problem has been slack in the shocker mounts. The mechanic has tightened them as much as he dares and believes we should now have a quieter van. will know for sure when we start our next trip. Thanks to all the responses.
Scratcher.
927029
