HF Radio Setups
Submitted: Thursday, Jun 20, 2024 at 22:12
Member - TroyR
Hey everyone, I'm looking into getting a HF setup for some truips over the coming years. I am curious though on how do you connect to a specific network, eg: HFRC or VKS. Do you have to configure the radio to talk on their networks?
Also, what brand and models would be best for a new user, Codan or Barrett. Obviously being a newbie I don't want to spend a ton but want something that will last a few years.
Just curious at this stage.
Reply By: Pepper - Friday, Jun 21, 2024 at 09:44
I have owned both barrett and codan radios and been a member of all networks .
For me both barrett and codan are excellent uniys..i found barrett easier and simpler to use.. codan has multifunction buttons which i think are
Confusing..
You pay for
membership to each network and get frequencies programmed into the radio as required..
You can buy older second hand radio sets as low as about $500 etc..
Barrett has served me very
well with after sales service for years..
You will join a great aust wide helpfull community..
646049
Reply By: Member - TroyR - Friday, Jun 21, 2024 at 10:10
Thanks for the info. Can you program the frequencies for each network yourself? I have a strong IT background and am happy to learn new tech
646050
Follow Up By: Pepper - Friday, Jun 21, 2024 at 11:19
I dont have the skills to program them ,i have paid a small fee each time..note when you join a network they will often have someone that can do the programming or assist..just ask..
You may be able to program it ..instructions are available..
926516
Reply By: Member - dirvine - Friday, Jun 21, 2024 at 13:35
I have a very old Codan with seperate head and with a taped ariel. I had nothing programmed for
mine. I just dial in the channel for VKS and make sure the tap pin wire is wound around ariel and then the end pin is placed in the correct pin hole. That simple.
646051
Follow Up By: Member - sparra - Friday, Jun 21, 2024 at 16:41
David, same as me, an old Codan X2 with tapped antennae.
926517
Reply By: Nomadic Navara - Friday, Jun 21, 2024 at 23:16
"Do you have to configure the radio to talk on their networks?"
Troy, If you are buying secondhand equipment, ask what networks the equipment the sets are set up for. You will mostly find one that suits you that is preset for your requirements. They will also have the RFDS frequencies in them as
well. If you do have to have the set reconfigured, it will depend upon the age of the set. The older models require new crystals for each new frequency you require, there will not be many of those (if any) around. The next generation require memory modules reconfigured, you will need to find someone with the equipment to do this for you. Later ones require a cable for a computer to do the trick, you can probably learn to do these yourself. Then the later ones may not need extra equipment to do the Job.
If you are purchasing new equipment, they will set them up for you.
646055
Reply By: Truedogz - Saturday, Jun 22, 2024 at 20:37
I have an older basic Barrett radio and am a member of the VKS network which I can recommend.
I am very much a believer in the KISS strategy so used a tapped aerial. Many people only use their HF radios for listening to and calling into skeds so often use just one frequency. A tapped aerial is simple with no parts to maintain. So basic for me is a simple to use radio, that can use sellcall to find the best station and make an emergency call if needed, and a tapped aerial. I enjoy listening to the sked calls around the nation.
It is horses for courses though if you want all the bells and whistles and flexibility.
This page has good basic information on the strengths and issues with a range of models. Search the site and you will find a wealth of info:
https://www.hfradio.com.au/4wd-hf-radio-faqs.html
646059
Reply By: Truedogz - Saturday, Jun 22, 2024 at 20:41
