Oziexplorer help
Submitted: Friday, Jul 12, 2002 at 00:00
ThreadID: 1477 Views:1432 Replies:3 FollowUps:2
I've just bought ozi-explorer and Great Desert Tracks on CD, how do you get the map image to come up in ozi-explorer, I can't seem to find how in the help. Thanks, 'the obvious idiot'.
Reply By: Greg Harewood - Friday, Jul 12, 2002 at 00:00
Richard - The following assumes you have run and installed the Hema Desert Track CD .....Open OziExplore - then hit the "Load File Menu" button - select "Load Map File" - navigate to where the map file (calibration info not actual map image eg Great Desert Tracks - North Central.map ) is located (in my case after running Hema Desert Track CD map file data ended up here ...C:\Program Files\Hema\Great Desert Tracks\Maps - yours may be different). Double click required map file. Bingo should work. (may ask you to browse to location of actual image)
or you can get the calibration files for each map from here...
http://216.40.224.145/xtras/great_desert_tracks_mapfiles_setup.exe
Place these files in the Oziexplorer\Maps directory (or where ever you want) and follow instructions above.
Hope this helps
AnswerID: 4823
Follow Up By: Richard - Saturday, Jul 13, 2002 at 00:00
Thanks Greg. That is what I was doing, only thing was, I didn't have the desert tracks cd in... didn't realise you had to
FollowupID: 2052
Just found out [10 minutes later] installation of GDT doesn't copy map image files, had to do it manually... helps when you read everything.
FollowupID: 2053
PS..sign up to http://groups.yahoo.com/group/OziUsers-L
All your questions will be answered.
Cheers Greg
AnswerID: 4824
Reply By: Gary - Thursday, Aug 22, 2002 at 00:00
I have the system installed on my laptop. Along with the Auslig maps I have loaded them all on the hard disk so I don't have to have the CD with me. Just make up a folder and copy them then redirect the search to that folder.
Gary
AnswerID: 5911
