Thursday, May 09, 2024 at 08:57
The other aspect is how hard is the plastic in the first place, you cn get soft platic and hard plastic. I'm assuming it is a soft plastic to start with and becomes brittle over time?
Toyota could have placed a metal filter screen inside the unit which I would have thought would have been easier than injection moulding a very fine mesh.
The other aspect is people just tend to accept these things, like the guy in the video indicates it is a serviceable item. Yes you have a sump cover to allow access to the pickup and whatever else in that area might need to be tended to ie oil level switch goes faulty, engine needs to be overhauled etc but I would expect the car manufacturer wasn't expecting all the pickup to have to be replaced regulary.
If it is as bad as being made out then owners and others should be making more noise about the issue not just replacing the unit as they have seen a video on it.
Write to the manufacture and complain, use email and ask for a receipt having an audit trail does wonders for getting organisations to take things seriously.
926249
