D-Max HF install
Submitted: Saturday, Apr 27, 2024 at 12:12
ThreadID: 147600 Views:1257 Replies:1 FollowUps:3
Hello, I am pondering where to fit my Codan 9350 auto tune and Codan 9323 radio to my 2023 D-Max X Terrain.
It has a bullbar and just the normal tray with roller fitted.
Has any one any suggestions on where to place them.
Am I better off just fitting the antennae when I need it for trips and having the radio in a weather proof case and connecting that when needed, I did have them permanatly mounted in my 120 Prado and found it very convenient.
Thanks in advance,
William
Reply By: RMD - Sunday, Apr 28, 2024 at 18:28
G'day William
Do you have a Tub or a Tray? You mentioned a roller fitted. Not usual to have a roller on a Tray. I would NOT fit the autotune to the bullbar but have it on a frame/ bracket at rear of cab so it will be up high and away from bullbar vibes. If mounted on a pinned hinged bracket, it can then be folded rearward when not used. Can the radio itself be under the rear seat where fairly direct access can be performed through the rear of cab and coax and control wiring, straight up to the autotune unit.
AnswerID: 645747
Follow Up By: Member - William B - Sunday, Apr 28, 2024 at 18:43
Thank you for your reply.
It is fitted with a tub.
I was was cleaning the car today and saw the space under the rear seats and thought that would suite the main unit.
I will need to check on a mount for the antennae.
William
FollowupID: 926116
Follow Up By: Nomadic Navara - Sunday, Apr 28, 2024 at 19:40
"I will need to check on a mount for the antennae."
Please don't use that term here. Antennae is a plural noun and is what you find on insects. In the radio field we have an antenna or antennas.
FollowupID: 926119
Follow Up By: RMD - Monday, Apr 29, 2024 at 08:08
William.
For my UHF aerial I have a simple plate which is held by two 6mm socket head set screws. Using a T handle hex tool it simply unscrews to an alternate horizontal position.
The lock pin and hinge arrangement could be fairly easily made to adapt the Codan Autotune to fold, if not commercially available.
FollowupID: 926121
