GPS signal - external antenna
Submitted: Friday, Apr 26, 2024 at 15:54
ThreadID: 147592 Views:1637 Replies:6 FollowUps:21
I have a windscreen that impedes GPS signals, therefore I can't get a consistent gps signal to run the maps. I have just installed a passive GPS re-radiating antenna with a 14db gain, but I think the gain is lost in the cabling, so it does not seem to have made any difference.
Can anyone recommend an active re-radiating antenna as a possible solution. I have seen some that seem to get a 24db gain. But I don't want to waste more money if that's not the solution.
thanks for your help, cheers Geoff
Reply By: RMD - Friday, Apr 26, 2024 at 19:31
G'day Geoff
What feature of your windscreen restricts GPS signals? Is it metallised in some way? With the reradiating unit, where is it situated. I would imagine, any unit like that would solve the problem. Is it also placed on a dash area where IT TOO is restricted by the invisible force pr under the rim of windscreen so it has a restricted view of the sky?
AnswerID: 645730
Follow Up By: Member - Geoff A11 - Friday, Apr 26, 2024 at 22:27
The windscreen shields the sun's rays somehow. However it does it, it impedes gps signal (the etag has to be positioned in a small part of the windscreen that is clear). I run an ipad bluetoothed to Garmin Glo2. I thought I solved it with the re-radiating antenna but I think the gain it achieves is then lost in the cabling, but it is a passive re-radiating antenna.
FollowupID: 926094
Follow Up By: Nomadic Navara - Friday, Apr 26, 2024 at 22:37
Which window did you plant it on? If it was the windscreen, then you have precisely the same problem as you do with the direct signal. If You did mount it on the windscreen, try one of the other windows.
FollowupID: 926096
Follow Up By: Member - Geoff A11 - Friday, Apr 26, 2024 at 22:48
I have an antenna bracket which sticks out from the side of the bonnet and have double sided taped it there. Not an ideal position but its outside the car and in full view of the sky
FollowupID: 926097
Follow Up By: Nomadic Navara - Sunday, Apr 28, 2024 at 21:17
Geoff, please drip feed us some more about your setup. Tell us about your antenna system. What is the brand and model of your system? Where does the 14db gain come from? Is it the antenna gain, or is there an amplifier involved? Is the in car unit a coil at the end of the coaxial cable or is it a proper resonant antenna.
Way back when hand held mobile phones were not particularly sensitive, there were similar devices sold for in car use with phones without antenna ports. The in-car unit was a coil that had to be placed behind the phones inbuilt antenna. If the coil was not in the right place, the external antenna was of not much use. Your device may be similar.
FollowupID: 926120
Follow Up By: Member - Geoff A11 - Monday, Apr 29, 2024 at 13:16
Peter, I guess drip feeding and dribbling come with age!!
The antenna is a Pro Gin SBG-190 Re radiating antenna (Taiwan)
The antenna specs are here: https://www.ja-gps.com.au/GPS-Express/re-radiating-gps-antenna
It is a passive re-radiating antenna, not an active re radiating antenna - ie there is no amplification and hence my original question - would an active re radiating antenna be worth a shot?
The in-car antenna is not a coil, it is about 100mm rod. The position of this is under the dash in the driver's footwell (and this position may be less than ideal - I assumed that once the signal was inside the car it would be picked up easily - proves I don't know much about gps!!)
thanks, Geoff
FollowupID: 926124
Follow Up By: Member - Warren H - Monday, Apr 29, 2024 at 14:11
Since you have an external gps why not put it next to the re radiating antenna as a trial to see if it works. Since it's a Bluetooth connection there's no reason it couldn't be mounted in close proximity unless that causes attenuation to the Bluetooth signal.
NT Pajero
2007 Goldstream Crown
FollowupID: 926126
Follow Up By: Member - Geoff A11 - Monday, Apr 29, 2024 at 14:16
Definitely worth a try thanks
FollowupID: 926127
Reply By: Member - LeighW - Friday, Apr 26, 2024 at 19:50
Interesting, I assume your using your phone or a tablet and your windscreen has heater wires in it? I don't have a windscreen that blocks GPS but then my phone sits on the centre console down low so it doesn't have a view of the windscreen so I assume there is enough GPS signal bouncing around in the car for it to work.
My HF radio has a GPS which sees the sky through the rear window which has heater wires in it and it works ok, so would seem just luck of the draw.
Looks like your only option may be an active repeater as you say but unfortunately can't help in that regard though there appear to be a few available.
If your using a tablet maybe you can get a bluetooth or other external GPS and use that.
AnswerID: 645731
Follow Up By: Member - Geoff A11 - Friday, Apr 26, 2024 at 22:32
Thanks Leigh - I have an ipad blue toothed to a garmin glo2. The external antenna should deliver gps signal to its antenna inside the car so in theory the garmin glo2 can sit anywhere. It works but not consistently enough.
FollowupID: 926095
Reply By: Member - McLaren3030 - Saturday, Apr 27, 2024 at 07:55
Hi Geoff,
As per RMD’s response, unless there is some sort of metal impregnated in the windscreen, it should not impede a satellite signal. Also, I do not understand how it can shield the “Ray’s of the sun”. If you are talking about the “dots” that are close together at the top of the windscreen, I still cannot see how you cannot place your GPS in a position where these do not interfere with the satellite signal.
If as you say the windscreen is causing a disruption to the satellite signal, the only way around this that I can see would be to install an external antenna, and a signal booster.
Where is your vehicles AM/FM/DAB antenna? What vehicle do you have?
AnswerID: 645733
Follow Up By: Member - Geoff A11 - Saturday, Apr 27, 2024 at 08:30
Thanks Macca - I have a 2019 Discovery 5. Its windscreen is what LR call "solar attenuated" and I've never been able to find out exactly what that means!! I have run with a Hema HX2 on the dash under the windscreen for the last few years and its never worked consistently enough due to gps signal failure. That's why I am working on an external antenna as possible solution. The car's radio antenna is roof, rear, middle.
FollowupID: 926100
Follow Up By: RMD - Saturday, Apr 27, 2024 at 09:26
Geoff
WHY DIDN'T you tell us about the windscreen feature right at the beginning? having as much info as possible will help people to respond far better to what your situation is. Instead we get a drip feed of info as we go. Later we learn something which alters the intention of previous responses,
Is the reradiating unit under the bonnet near the receiving GPS antenna? sounds like it is. If so, it's signal will be stopped by bodywork.
FollowupID: 926101
Follow Up By: Member - David M (SA) - Saturday, Apr 27, 2024 at 10:05
To right RMD. If I was you I wouldn't bother.
Dave.
FollowupID: 926102
Follow Up By: Member - Geoff A11 - Saturday, Apr 27, 2024 at 10:09
Apologies RMD I thought I had made it clear in my original post that the windscreen impeded the gps signal.
The antenna is on a bracket bolted to the bonnet so sits beside the bonnet with clear view of sky. The other end is inside the car under the dash at the footwell. In this position it should fill the cabin with signal - or so I thought??
FollowupID: 926103
Follow Up By: RMD - Saturday, Apr 27, 2024 at 15:38
Geoff.
Yes you did say it impeded the signal but didn't say why. Knowing you had such a screen and the properties of it would seem to be most important in this case. Having a windscreen with a membrane impregnated with some metallized particles or substance would do that. Same as wrapping the GPS in foil.
You cannot be serious with the reradiating antennae down in the footwell. Radio signals are straight lines and maybe some reflection in some instances. Perhaps have the reradiating antennae where it is LINE OF SIGHT to the GPS enabled pad so it can SEE the thing. Radio signals are not like a gas and fills/permeates every crevice of the volume. Just look at how Telstra misses places where you can SEE the tower..
FollowupID: 926104
Follow Up By: OzzieCruiser - Saturday, Apr 27, 2024 at 21:41
But - I know other Disco 5 owners do not have this issue. They get GPS signals no problem at all.
FollowupID: 926107
Follow Up By: Member - Jim S1 - Sunday, Apr 28, 2024 at 07:03
Yes Ozzie , but do they have this special "solar attenuating" screen which I believe is optional ?
Apparently it works very well in keeping the interior temperature down.
Jim
"Sometimes I sits and thinks, and sometimes I just sits." A fisherman.
"No road is long with good company." Traditional
FollowupID: 926110
Follow Up By: OzzieCruiser - Sunday, Apr 28, 2024 at 17:25
Opticool windscreens are standard.
FollowupID: 926114
Follow Up By: Member - Jim S1 - Sunday, Apr 28, 2024 at 18:34
OK.
Jim
FollowupID: 926115
Follow Up By: Member - Geoff A11 - Sunday, Apr 28, 2024 at 18:48
Ozzie & Jim
The solar attenuated screen is an option
FollowupID: 926118
Reply By: Member - Jim S1 - Sunday, Apr 28, 2024 at 18:39
Are you sure the Hema H2X isn't the problem ? Hema have had some issues in the past.
Jim
AnswerID: 645748
Follow Up By: Member - Geoff A11 - Sunday, Apr 28, 2024 at 18:45
Thanks Jim
This year I bought exploreoz maps, running on iPad through garmin glo2
Same issue
FollowupID: 926117
Reply By: Member - Geoff A11 - Sunday, Apr 28, 2024 at 19:46
thanks to everyone for your input. We haven't solved it but got a few good thoughts. First time user and great forum!
AnswerID: 645749
Follow Up By: Allan B (Sunshine Coast) - Tuesday, Apr 30, 2024 at 17:48
Hang on a bit Geoff. You repeatedly insist that you bought a "passive re-radiating antenna" yet you state it is a "Pro Gin SBG-190" and post the specs of same. Well these specs clearly show a cigar-plug power connector and the specs state "Power required: 10-13VDC".
That is NOT "passive". It needs battery power….. no wonder it does not work. What did you do with the power module?… just leave it hanging somewhere unconnected?
FollowupID: 926136
Follow Up By: Member - Geoff A11 - Tuesday, Apr 30, 2024 at 18:25
Allan you are correct - I had assumed it was a passive antenna because I had seen an active advertised with twice the gain of this one. Apologies! However it is wired into to Aux system. I had not made the connection between wiring it in and 'active'. My ignorance.
FollowupID: 926137
Reply By: Member BarryG - Saturday, May 04, 2024 at 10:15
Hi Geoff,
Does your phone receive a reliable GPS signal inside the car? If so, the the problem is not caused by your windscreen.
Just a thought.
Barry
AnswerID: 645796
