Patrol 4.2 Diesel
Submitted: Saturday, Jul 17, 2004 at 23:57
ThreadID: 14747 Views:2248 Replies:4 FollowUps:1
I'm buying a patrol ute turbo diesel 2002 era. I know there is a number of threads on this unit but can't seem to find much via the search engine. I found a couple of posts on overheating but not much detail and remeber one from a long time ago on oil filters causing the oil light to stay on for to long. Can find this post or much on these motors and model vehicle. Can anyone direct me to the right place or give me a brief run down on any problems to look for, mods I should do, etc, etc.
Thanks.
Reply By: zoom - Sunday, Jul 18, 2004 at 02:32
do yourself a favour and buy the last of the GQ's and turbo it yourself. Better vehicle, will save yourself money be a better vehicle, and will haul arse all over the factory gutless turbo.
AnswerID: 68218
Reply By: Truckster (Vic) - Sunday, Jul 18, 2004 at 12:02
TD42 will last you 500,000+ if treated well. Its common.
Try the patrol groups on yahoogroups.
patrol4wd
nissan_gu_patrol is the other
AnswerID: 68249
Reply By: Member - John- Sunday, Jul 18, 2004 at 23:41
I use a fairly well equipped 2001 GU 4.2TD coil cab for work in the Kimberley. Done 60,000km, lots of it on rough roads and tracks and very hot conditions. 5th gear failed as predicted for early GU's and the gearbox was rebuilt under warranty and is better than ever now. The new parts bring the gearbox back up to the robustness of the GQ box and unlikely to cause any further concerns. The front axle is stronger on the GU over the GQ as well.
Zero other failures except the original suspension failed after about a year and is now a full OEM system (beautiful!!)
It is important to keep the radiator free of insects and grass seeds lest you overheat on high speed runs. Easiest done by removing the radiator for cleaning once a year and using a shade cloth screen over the bullbar (for spinifex seeds) or a coarse mesh for grasshoppers.
Fuel economy is good up to 105kph on the highway, above that it gets bad pretty quick. It's a rugged, reliable, electronics free diesel that will never let you down provided you feed it clean diesel.
These 4.2 turbos respond very well to after mkt re-turboing and some excellent soltions exist if you want more power & torque with better economy. Expensive, so you need to be planning on keeping it for a few years.
I can recommend his truck. It is reliable, has great bushability and the coil cab with OME suspension rides like a limo on the rough roads.
JohnS
Derby, WA
AnswerID: 68356
Follow Up By: Austravel - Monday, Jul 19, 2004 at 09:12
Thanks for your comments. I'd thought it was only the 3.0l diesel that had gear box trouble, I'll have to keep an eye on it.
FollowupID: 328971
Reply By: Austravel - Monday, Jul 19, 2004 at 09:12
Thanks all for your thoughts.
AnswerID: 68383
