UHF Aerials
Submitted: Tuesday, Apr 02, 2024 at 15:57
Member - Gary T4
Do UHF aerials use a generic connector to connect to the UHF head unit?
I am looking at an ecoxgear aerial and are wanting to plug it into a GME head unit.
Thank you.
Reply By: Stephen L (Clare) SA - Tuesday, Apr 02, 2024 at 16:55
Your GME head unit will need one of these
A standard UHF PL259 plug
645593
Follow Up By: Member - Gary T4 - Wednesday, Apr 03, 2024 at 13:48
Will that just slide onto the existing connector or will it have to replace the existing connector?
925878
Follow Up By: Stephen L (Clare) SA - Thursday, Apr 04, 2024 at 08:39
They are the most common screw on connector and should screw straight onto the UHF.
You will find most quality aerials will have no connection on the end of the coax to allow the cable to be fed through the vehicle easily and then when in place, an easy job to solder the plug to the coax.
925895
Reply By: Loddo48 - Tuesday, Apr 02, 2024 at 18:24
If you get one of those antenna's it will come with the required connector for your radio.
645594
Reply By: cookie1 - Tuesday, Apr 02, 2024 at 19:14
Some Radios will come with a SO259 Socket and others an FME socket - that caught me out when I changed my Icom for the GME XRS390C which has an FME Socket
FME connectors are easy to pass through the firewall given their small size but you need to be careful not to put too much pressure on the connector when pulling through.
PL259 are easier to pass the cable through and then solder the connector on
I put a dab of nail polish on the connectors once nipped up (not overtightened) so they don't work loose easily.
645595
Follow Up By: Member - Jim S1 - Tuesday, Apr 02, 2024 at 19:52
Another idea for my list ....... thank you .
"I put a dab of nail polish on the connectors once nipped up (not overtightened) so they don't work loose easily."
Jim
| "Sometimes I sits and thinks, and sometimes I just sits." A fisherman.
"No road is long with good company." TraditionalLifetime Member My Profile My Position Send Message |
925871
Follow Up By: RMD - Tuesday, Apr 02, 2024 at 20:09
Cookie,
I hope the nail polish colour doesn't clash with the interior trim.
Seriously, though, I used clear nail polish on ALL the nuts and plugs to be moved during a vehicle first service. A very small dob on the flats of nuts/plugs on/near the peak of the Hex on the undoing edge face. Any service person would instantly remove them with a spanner or socket. Dealer manager wasn't happy when I told him NO item had been touched, some not even on pre delivery with factory paint marks unmoved. Photographic evidence of before and after aways helps in dealer wrangles.
925872
Follow Up By: Member - McLaren3030 - Wednesday, Apr 03, 2024 at 06:43
Hi RMD,
Not wishing to hijack this tread, but I once put a mark on the oil filter when putting my car in for service many years ago. When I checked after the service, the brand new oil filter had a smiley face on it.
925873
Follow Up By: Bob Y. - Qld - Wednesday, Apr 03, 2024 at 11:06
Great idea, Cookie! I’ve used Loctite 222 for the same purpose, one drop only, on units that difficult to access. For remote travellers, certainly wise to use on all communication equipment.
925875
Reply By: Mercedes B - Wednesday, Apr 03, 2024 at 18:18
This post has been read by the moderation team and has been moderated due to a breach of The Spamming Rule .
Forum Moderation Team
645602
Reply By: Dean K3 - Wednesday, Apr 03, 2024 at 20:44
Probbaly bit late with response -ten years exp in commercial short term hire and project with WA Police number years ago.
Majority of UHF CB radios will use a PL259 screw on plug.
However GME at one stage had their coax cable unterminated and trust me they need to be terminated properly.
You can imagine how I choked on cornflakes when a mechanic said to myself and the senior technician, we used pair of broad pliers to crimp the connector on and they wondered why they had bad radio comms (commercial freq and power output 25 w )
To allow easy install some antennas manufacturers (GME for one now use a smaller FME connector as used on a mobile phone coax cable connector and then use a interseries adaptoer to screw onto back of the radio.
Bit of clear nail polish will assist in holding the threads together but only apply to threaed parts nothing else. - used this on a diplexer after tuning it to frequency so they didn't self adjust with vibrations in transit
Some high tier radios - ie dumbed down power wise radios may have a different connector fitted BNC in particular. -this looks similar to a bayonet globe fitting
645606
