C:\ Drive full - can I move ExplorOz traveller
Submitted: Tuesday, Mar 19, 2024 at 12:23
ThreadID: 147281 Views:1483 Replies:7 FollowUps:5
I need to find some space on my system drive on the computer (c:\ ) as it is full. Have found some space by emptying caches, temp etc, but need some more.
ExploreOz traveler is the second-highest space concumer (8.57 GB) after Photoshop (9.29 GB).
I assume because all the maps are stored on the C: drive.
Microsoft indicates that ExplorOz T can be moved but I don't always trust this advice. So my question is, can I safely move the program to the D: drive?
Reply By: Member - Jim S1 - Tuesday, Mar 19, 2024 at 13:51
Stephen , your best and fastest response will be from David and Michelle.
The HELP desk, at the bottom of the page.
Jim
"Sometimes I sits and thinks, and sometimes I just sits." A fisherman.
"No road is long with good company." Traditional
AnswerID: 645506
Reply By: Member - Stephen R16 - Tuesday, Mar 19, 2024 at 14:30
Cheers ... have sent to help desk.
AnswerID: 645507
Reply By: Member - Bigfish - Tuesday, Mar 19, 2024 at 16:18
I put mine on my D drive..no problems
AnswerID: 645509
Follow Up By: Member - Stephen R16 - Wednesday, Mar 20, 2024 at 09:49
Sounds promising. Did you use a fresh install or use the Microsoft move option?
FollowupID: 925812
Reply By: Kazza055 - Tuesday, Mar 19, 2024 at 17:41
Am I missing something, why not just upgrade your C drive to a larger size?
There is plenty of info on the net on how to upgrade to a bigger drive without needing to re-install everything, just copy to the new larger drive maybe using a SSD.
AnswerID: 645510
Follow Up By: Member - Stephen R16 - Wednesday, Mar 20, 2024 at 09:48
Can do that, but I am trying to avoid that cost and hassle.
FollowupID: 925811
Follow Up By: Kazza055 - Wednesday, Mar 20, 2024 at 18:02
If you are that close to filling the drive, patching it with a bandwidth is not really fixing the problem, it is just hiding it and it will come back some short time in the future.
Hard drives and SSD are very cheap these days, the last drive i bought was 4TB for around $150.00
FollowupID: 925818
Reply By: Member - peter g28 - Tuesday, Mar 19, 2024 at 19:42
I might be wrong..
Is it not, that the ExploreOz on the computer is a web based application, so have your web browser is on the D drive as a copy, then this will open up the ExploreOz web based app.
What you will have to do, is sign in again and complete the various steps to authorise the web app..ie update & sync etc..
If you are a full member, all your data that is in the app..your folders etc is kept on the ExploreOz server..so when you update and sync all the data will be there within the web based ExploreOz app.
Note:..I use Apple and their latest OS for their Mac's..so this may be slightly different with Microsoft as they use now a web based OS..but the help desk will put you on the right track regardless.
AnswerID: 645513
Follow Up By: Member - Stephen R16 - Wednesday, Mar 20, 2024 at 09:50
Can use it on-line. I use the downloaded version as my internet is crap.
FollowupID: 925813
Reply By: Member - LeighW - Tuesday, Mar 19, 2024 at 20:50
If you only have one hard drive and it is partioned as two partitions why not just increase the size of partition C: if you have plenty of space left in d:
AnswerID: 645519
Follow Up By: Member - Stephen R16 - Wednesday, Mar 20, 2024 at 09:56
I have 2 drives. ExplorOz and all the maps are stored on the C:\ drive which I usually keep as a dedicated systems drive. I also have a NAS on a home LAN so use that for additional storage, backups etc. On the laptop I try to avoid partitioning these days (no real need), windows can handle pretty large drives without the need for partitioning.
FollowupID: 925814
Reply By: RMD - Friday, Mar 22, 2024 at 19:19
I am not a computer expert but seeing you have space on D drive, simply migrate the crap you don't need on C to D and use the D space for non essentials. One minute you ask how and then say you can solve it anyway. Cost is always involved!
AnswerID: 645531
