AI box
Submitted: Thursday, Jan 11, 2024 at 19:35
ThreadID: 146804 Views:1497 Replies:2 FollowUps:2
Can someone please advise me if these various AI boxes that are recommended to use to display the required Android apps on the modern-day head units of for example the Landcruiser 300 series have an inbuilt GPS?
I changed out the head unit in my 200 series for an Android head unit specifically so I could use Exploreoz Traveller for my mapping and navigation etc.
I have a 300 series on order and what I am trying to get my head around is if I purchase one of these Ai boxes how does it access a GPS for navigation?
VKS 1341
Reply By: Member - LeighW - Friday, Jan 12, 2024 at 08:49
As far as i'm aware an Andriod Auto interface is just that, it interfaces your android device to a cars android auto supported car display radio etc.
You use the interface to display exploreoz on your phone onto the cars screen, the apps running on the phone and the GPS is in the phone.
AnswerID: 645079
Follow Up By: Member - bungarra (WA) - Friday, Jan 12, 2024 at 11:50
Thanks, but you have misunderstood my question. Android Auto is basically useless as very few apps are compatible.
My query was how does the AI box access the GPS when using it for navigation. If you see David & Michelles answer you may get a better understanding of why AI boxes are the way to go.
VKS 1341
FollowupID: 925329
Reply By: ExplorOz - David & Michelle - Friday, Jan 12, 2024 at 09:18
The factory headunit in the 300 series has built in gps built in but restricts your selection of apps as it isnt a full open Android operating system (only Android Auto/CarPlay) so doesnt give access to the Google Playstore where apps like ExplorOz Traveller are found. The Android AI Box Adapters simply enable that. The apps you download from Playstore get stored on the AI BOX but display on the headunit and use the gps in the headunit. For around $250 its a much cheaoer solution than replacing the factory headunit with an aftermarket Android headunit. Hope this helps
Regards Michelle
(Typos fixed in edit)
Currently Mapping in the Field Across Australia Fulltime in 2024 - 2025
AnswerID: 645080
Follow Up By: Member - bungarra (WA) - Friday, Jan 12, 2024 at 11:47
Thanks, you have covered the AI boxes well in previous posts along with good reasons why you're not making Exploreoz Traveller Android compatible.
My confusion was the GPS use and you have answered that clearly.... thanks again.
VKS 1341
FollowupID: 925328
