Several weeks ago in
Thread 146543 there was some discussion about the new Australian Standard AS/NZS 3001 - Part 2, titled Electrical Installations — Connectable electrical installations and supply arrangements. This came into effect on the 18th November.
I have now had the opportunity to peruse this Standard and would make some expressions about it and the effects it may have on our RV community.
The Standard is extensive and specific so I will not embark on a comprehensive review but some points are……..
1) For starters let's look at its application. The Standard applies to "Connectible Electrical Installations" which are defined in the Standard as being for (those vehicles) that are intended for connection to external low voltage a.c. by either a detachable supply lead or one directly connected to the vehicle. It refers to that term "connectable" repeatedly". So if your vehicle… car, trailer, caravan or motorhome does not have the facility to plug in to a power source e.g caravan
park power outlet, then I believe it is not subject to this Standard even if it has low voltage d.c.
services or a 230vac inverter installed. Provided there is no 'connectibility' to an external "low voltage ac power source". Of course, most camper trailer/van or motorhome do have such facility.
2) Installers of electrics will need to be
well informed and abide by the Standard where it is being referred to by State or Federal legislation.
3) In particular it lays down requirements for both the 230vac wiring and also some aspects of the dc installation.
4) I was confused by some expressions in Section 5 where it makes specifications for "Lead Acid battery requirements" and separately for "Lithium ion battery requirements". no mention is made of Lithium Iron phosphate batteries. Because it is expressed as "Lithium ion" and not simply "Lithium" I was left to wonder if LiFePO4 are excused from this Section. I have written to Standards Australia to seek clarification on this point.
5) In the earlier thread I referred to above there were some expressions regarding the 'legal' aspects when changing to a revised battery type. In general with electrical installations covered by the Australian Standards, upgrading the whole installation is only required when there is a 'substantial' change being made to the installation, however it is always moot as to what 'substantial' may mean. I would not believe that simply replacing the battery with a different type would require any upgrading with respect to the Standard. If however the location and housing arrangement of their battery was being changed then I expect that it would be viewed as necessary to adopt the requirements of this Standard.
So apart from some things such as battery housing and ventilation the Standard id mainly defining requirements which are already recognised as "Good Practice".
Part 1 of this Standard applies to the requirements for the power supply source such as van parks.
I'll post more when I hear back from Australian Standards about the Lithium confusion.
