Monday, Oct 30, 2023 at 18:47
"The above you describe is electric bakes or maybe some mechanical brake if it operates to some degree. I presume it died out very quickly. you are the only person I know to report of one."
RMD, you never give up do you. You just keep up having to justify yourself even when you are out of your depth, don't you. Firstly about me being the only person 'to report one.'
Well the OP raised the subject so he must have known about them (and there was a third person who has heard about then that replied just after you reply above.) The vans were produced 30 years or so ago so there are not many people on the
forum who were active around caravan that far back. The vans were not mainstream, their production was not for very long and there were not too many of them produced. In addition, I don't remember this being discussed online before. Most of the discussion I would have seen would have been in Q & A with Tom Olthoff in Caravan World. Have you heard of either of those?
Mechanical brakes were considered OK in their day. After all, they were produced when many of the the tugs had mechanical brakes. The only alternative back then was vacuum brakes similar to the ones used on semitrailers. When I first started towing vans there were no electric brakes. The only automotive electronics were the steam-driven valve radios. There were no electric brake controllers around until transistors developed that would handle the power required. The round trailer plugs only had 6 pins, not 7.
I retreated from vanning in the 1970s so I am unsure when electric brake controllers arrived but when I regained interest in the 80s they were around but they were very expensive and crude. The proportional controllers came in way after the first controllers did. At that stage electric brakes were a little better than mechanical brakes but their main advantage was the thumb control brake override.
In 1988 I regained interest and started hunting around and we got our van in 1990. At that time, most of the large vans had progressed to electric brakes but the smaller ones were still being produced with mechanical brakes. My Nipper had mechanical brakes and at the time I was not concerned about that. A couple or years on I commenced looking at new vans, that's when I noted the dual system brakes. When I eventually purchased the bigger van (still under 16') it had electric brakes but the synchroniser brake controllers were still all the rage.
As far as your description of the effectiveness of mechanical brakes go, I have not found them that poor. The first van I towed was a
Franklin Hunter with hydraulic brakes. The difference in braking between having the reverse lock on and off was similar to the electric brakes with the trailer plug in and the trailer plug forgotten to be inserted. Or to put it in simple terms, the feeling when braking in the two vans with and without brakes was similar.
During the time I had my Nipper I was living in the ACT. We had annual vehicle inspections there and the brakes were thoroughly tested. The first generation tester had 4 individual wheel areas that were topped with expanded steel on the top. When you drove over them you were given the signal to brake hard. The forward movement of the pads pumped up individual columns of coloured liquid. That showed how effective your brakes were. I was surprised how this test demonstrated the effectiveness of the override brakes. I thought the van would have been so light that its tyres would not have gripped the pads very
well. The height of the column was much higher than my Morris 850 produced. The second generation tester employed a pair of driven rollers that each wheel sat between. With that test they asked you to reverse the van up against the rear roller and the result was displayed in 7 segment display tubes. Again the brakes performed
well, both in the override mode and applying the handbrake tests.
I therefore have to disagree with you on the effectiveness of override brakes. We have progressed to electric brakes not because the override brakes were so poor, but because the electric brakes are better. You were sounding like the brakes of the day were poor, but they of the standard of the day, and the manufacturers should have been using the brakes we now have available.
On the subject of mechanical brakes, here is something for you to mull over -
Mechanical vs. Electric Brakes. Mechanical brakes have also improved since those days, not just electric ones.
924817
