Motorised caravan jockey wheel
Submitted: Sunday, Oct 08, 2023 at 09:26
Uncle Arthur
Because of my age and physical limitations I am looking at purchasing a motorized jockey wheel to maneuver the van through 90 degrees off the loose gravel bitumen driveway into its carport
parking position. To date have been able to push it with the assistance of my wife. The unit I am thinking of is the T-REX Powered Jockey Wheel Heavy Duty Electric Motorised 12V 350W for Caravans Trailer Boat.
Looking for advise on suitability from other users. Thank you in advance.
Reply By: Member - PhilD_NT - Monday, Oct 09, 2023 at 00:55
I have a different style of electric mover, a Parkit360, that I bought about 10 years ago. Fairly expensive though but does the job.
https://parkit360.com.au
I'm using it to maneuver a 2.7 tonne dual axle van.
This can either attach to a towball, or in the case of an offroad style swiveling hitch it attaches to a bracket on the A frame, and this is how I'm using it. I use it with a large battery sitting on the mover itself but could be fed from the van house battery with suitably sized cabling and fusing. I use a separate battery though. I optioned it with fairly aggressive tyres as most of the area I need it for is lawn.
This earlier model is reasonably slow and noisy, but I believe that the current models are a lot better in these respects.
In my experience I doubt that it would fare
well on gravel as it does dig into the lawn when altering direction a bit. Might be better with single axle vans and I'm hoping to find out as we'll probably replace this van for a slightly smaller single axle one in the next few months. I might even try a tow pin on the front of the vehicle and see it that works as a better alternative for the new van.
644586
Reply By: Peter J4 - Wednesday, Oct 11, 2023 at 07:22
If using a ride on mower be very careful if there is any slope involved as the mower brakes will not hold the van.
I watched a friend do it on his small hobby
farm and all went
well until the van got onto the slope and away it went , the look of horror on his face as the van took over was priceless.
Fortunately in his case there was nothing to hit and a gentle up slope stopped the van without damage but it was a wild ride on the rideon as it went for about 50 metres before stopping.
644597
Follow Up By: Member - PhilD_NT - Wednesday, Oct 11, 2023 at 14:02
My Parkit360 came with a switch on the handle and a plug that connects to the van input so I can activate the van brakes. Seems like a wise addition for any mover.
924735
