More on batteries
Submitted: Monday, Aug 21, 2023 at 08:54
ThreadID: 146135 Views:6051 Replies:10 FollowUps:72
Almost predictable.
https://youtu.be/vRcSPuBob-I
Reply By: Member - Duncan2H - Monday, Aug 21, 2023 at 11:04
I had the same reaction to that video.. it was a folly to begin with. He took one for the team to prove it though I guess.
AnswerID: 644311
Reply By: qldcamper - Monday, Aug 21, 2023 at 11:43
I've had a similar run with AGMs under bonnet and went back to a cheaper calcium flooded battery for under bonnet about 8 months ago.
Makes you realise how superior AGMs performance is but too expensive to replace every 2 years.
AnswerID: 644312
Reply By: Allan B (Sunshine Coast) - Monday, Aug 21, 2023 at 13:51
Well, I warned him but he did not seem to take my advice.
No battery is happy to be located in a hot location. Even flooded lead-acid are happier if not heated.
So, our friend has spat the dummy on the benefits of lithium by being unwilling to allocate a little space in the rear of his vehicle. His choice of course, but in my mind…. pitiful!
AnswerID: 644314
Follow Up By: Member - William B - Monday, Aug 21, 2023 at 15:19
Hi Allan,
To be fair to Stefan he has owned his mistake. ( a few caveats thrown in) I have a itechworld lithium which is warranted for under bonnet use, his loss is my gain as I won't be fitting it under the bonnet. I'll stick to my lead acid battery in the front of the Prado.
William
FollowupID: 924336
Follow Up By: qldcamper - Monday, Aug 21, 2023 at 16:02
That's what happens when people take advice from sales people and ignore common sense.
He is lucky he decided to test them before they let him down.
I think a lot of people that think their u- beaut deep cycle battery they bought "X" amount of years ago and is still going strong would be supprised if they tried running it without the 500 watts of solar connected all day so the battery only needs 10% of its rated capacity would find their battery isnt as good as they think.
I know I was.
FollowupID: 924340
Follow Up By: Member - Bigfish - Tuesday, Aug 22, 2023 at 07:02
He took his advice from a manufacturer ..not a salesperson.
FollowupID: 924346
Reply By: Member - LeighW - Monday, Aug 21, 2023 at 17:02
Interesting to watch, my DCS extreme has been under the bonnet in the Prado for 4 years and still test as new. Will be intersting to see how long it lasts for. As an aside never got longer than 4 years out of any aux under the bonnet the way I use them so the DCS is doing well.
AnswerID: 644315
Follow Up By: Member - Bigfish - Tuesday, Aug 22, 2023 at 05:35
Can you post up the current state of condition? Drain it and then see how much capacity is actually in the battery. 4 years of engine heat can,t be a good thing. 4 years and test as new....pigs might fly!
FollowupID: 924343
Follow Up By: cookie1 - Tuesday, Aug 22, 2023 at 06:54
To be fair though Stefan probably does a few more kilometers than most so that would accelerate the demise of the batteries notwithstanding the jarring & jolting of where he gets to
FollowupID: 924344
Follow Up By: AlbyNSW - Tuesday, Aug 22, 2023 at 06:59
True Cookie but the auto electricians installer’s daily driver Prado had one as well and that suffered the same fate
FollowupID: 924345
Follow Up By: Member - LeighW - Tuesday, Aug 22, 2023 at 09:29
Bigfish,
Tested it 12 months ago, capacity on the test sheet from the factory stated 81Ah, tested it last xmas and it was still 81Ah. My two 100Ah Lithiums in the van still test over 100Ah each after 9 years.
I'll do another test on the car unit in the next few days and post it up.
Car doesn't get driven daily though probably works out to around every couple of days and 3 - 4 months of high kilometer touring a year up in the sunny areas.
FollowupID: 924347
Follow Up By: Briste - Tuesday, Aug 22, 2023 at 09:41
I have had a 100Ah DCS lithium under the bonnet of my MY21 Prado for 18 months. I will also do a capacity test in the next few days.
Stephan blames heat, as do others. I spent some time early on monitoring the battery temp while driving via the DCS app, and it wasn't all that far above ambient temperature. It did rise after the vehicle stopped for a while, but not alarmingly so. The location of the second battery in the 150 series seems reasonably well ventilated while driving. However the installer's Prado suffered the same fate. Our capacity tests will be interesting.
FollowupID: 924348
Follow Up By: Member - Bigfish - Tuesday, Aug 22, 2023 at 10:30
9 year old batteries and still 100% capacity of new battery! What results do your load tests give? You must have 2 of the best batteries in the world. I don't know how you test but all batteries deteriorate over time.
FollowupID: 924350
Follow Up By: Briste - Tuesday, Aug 22, 2023 at 10:40
I'd also be interested in how Leigh tests battery capacity. I'm about to borrow a device from a friend that applies a load to a battery and measures the current used. I guess I could do something similar via one of those inline power analysers.
What I am concerned about is that draining a battery of any variety isn't supposed to be good for it. I have managed to flatten my DCS on one occasion accidentally, and have been trying to prevent a repeat episode, but I don't see how one can measure capacity without draining it quite low. How low does one go?
FollowupID: 924351
Follow Up By: Member - LeighW - Tuesday, Aug 22, 2023 at 11:18
Bigfish,
All batteries deteriorate over time but to date my are still testing over their rated capacity.
FollowupID: 924352
Follow Up By: Member - Bigfish - Tuesday, Aug 22, 2023 at 12:08
The testing does not make sense. I,ve never seen a battery test 12.62 volts at 0%. Your testing is flawed.
FollowupID: 924355
Follow Up By: Member - LeighW - Tuesday, Aug 22, 2023 at 12:16
Briste,
Generally I don't go lower than the stated capacity of the battery which as you can see above occurred at 12.62V
The DCS battey in my case is quite small at 80Ah, from memory I think it got down to about 12V at 80Ah last time I checked it. 10V is consdered 0% SOC but personally I would stop at 12.5V with a small discharge current being applied.
FollowupID: 924356
Follow Up By: Member - FLNGO - Tuesday, Aug 22, 2023 at 12:34
Hi Leigh,
I suspect you are getting good results due to the low discharge rate you are using (5A). Expect the original specs would have been set based on 0.5C or 1C discharge rate.
The link below shows the discharge curves for the cells with discharge rates of 1C & 2C (130 & 260A equivalent), at those rates the voltage drops of at approx 12.4-12.6V, going any lower seems pointless to me.
https://www.deepcyclesystems.com.au/product/ultimate-dcs-12v-260ah-dual-battery-system-lithium-land-cruiser-200-series/
FollowupID: 924358
Follow Up By: Member - LeighW - Tuesday, Aug 22, 2023 at 13:06
Most of the time my load on the van batteries will be below 5A unless the heater is starting up or wer'e using the induction cooket top off the inverter so that is the current I do the capacity test at for the van.
There is very little capacity difference between discharging at 5A comapred to 100A with my cells, around 2Ah for the CALB cells I'm using. CALB show the capacity of the cells at 110Ah @ 1C and 2.5V respectively but again I stop the discharge at the cells rated capacity which was 12.62V so they would still have had a few Ah left in them.
In the case of the car the max discharge rate is again usually around 5A unless I'm running the winch which doesn't happen that often so that is the current I do the capacity test at. DCS don't provide discharged curves for the extreme so have no idea how efficient the cells are just know the original capacity at 5A discharge was 81Ah to around 12V and they showed the tested capacity as 81Ah too.
FollowupID: 924361
Follow Up By: OzzieCruiser - Tuesday, Aug 22, 2023 at 13:27
Typical ExploreOz - my d$%K is bigger than yours.
A member makes a statement that someone disagrees with - great it is a forum. Make your point and move on dont carry on and on and on and on.
FollowupID: 924363
Follow Up By: Member - LeighW - Tuesday, Aug 22, 2023 at 13:55
Bigfish,
As I wrote if you bothered to read it, test was stopped at 200Ah discharge point, the test is not flawed you just aren't comprehending the results correctly. I never wrote it was at 0%SOC, the discharge test was stopped once the discharged Ah reached 0% of the batteries rated capacity. As I also wrote above the was still a few Ah left in them.
FollowupID: 924364
Follow Up By: Member - Bigfish - Tuesday, Aug 22, 2023 at 14:16
Here is the official DCS graph for their 110 a/h battery. 12 volts at 85% spent. I,ll stand by my statement that your testing is flawed.
FollowupID: 924365
Follow Up By: Member - FLNGO - Tuesday, Aug 22, 2023 at 14:28
Hi Bigfish,
Would you mine explaining (I may have missed it) why LeighW's test is flawed?
Note: not trying to be smart, just attempting to understand the logic.
The graph you posted shows you can get more capacity from the battery (AHr) using a lower discharge rate (2C vs 1C). LeighW's test was conducted at 5A (0.045C) thus I would expect him to have the higher AHr result.
FollowupID: 924366
Follow Up By: Member - LeighW - Tuesday, Aug 22, 2023 at 14:30
First point, the graph I supplied is for a EVpower battery pack.
Secondly the point you keep missing is the discharge test was stopped at the rated Ah of the battery ie 200Ah. The battery was not at 0%SOC it was at 0%SOC of its rated capacity. There was still Ah left in the battery!
Thirdly, the battery voltages shown above are at a 110A discharge or 220A discharge. Mine is at a 5A discharge rate!
Again the test is not flawed.
FollowupID: 924367
Follow Up By: Member - Bigfish - Tuesday, Aug 22, 2023 at 14:36
The test is flawed for a good reason. The battery is marketed as 200a/h. Now he has taken the battery down to 12.6 volts which would equate to anywhere from 15 % depleted to 60% depleted. This means that if he chose to he could say that his battery can supply him 270 a/h if he chose the 15% depletion. 5a discharge on a 200 a/h is not going to give a true indication. The only real way to test is to discharge till the battery turns itself off. Charge a little more then deplete again. It should now be at 100% depleted. Now start charging again (20,30,40,50 amps. whatever) and see exactly how many amps the battery will take. This will give the true condition of the battery.
FollowupID: 924368
Follow Up By: Member - LeighW - Tuesday, Aug 22, 2023 at 14:43
Still wrong, even with as little as 2% left in a lithium battery the terminal voltage at very low discharge rates will still be around 12.5V, it will only collapse near 0% SOC.
Obviously you don't have a Lithium battery setup.
FollowupID: 924369
Follow Up By: Member - Bigfish - Tuesday, Aug 22, 2023 at 14:59
I actually have 3different lithium battery set ups. 200a/h in boat, 220 a/h in camper and 120 in car.. You see the issue is you say that they haven't lost capacity. Now their 200 a/h is advertised at 200amp hour . . Use the battery say for two years and then retest using the method I said. 5 amps will tell you nothing. It is no real indication of the batteries true capacity..every battery, regardless of type, degrades. Flatten completely and then measure how many amps it takes to fully recharge. Do it while putting 20 or 40 a/h charge back in. I,ll guarantee it wont be 100% capacity. It might make you feel better but its not what is happening in reality.
I,ve said my piece Leigh so I,ll bow out now. Cheers, Bigfish.
FollowupID: 924370
Follow Up By: Member - LeighW - Tuesday, Aug 22, 2023 at 15:43
Sorry but I never wrote they have not lost any capacity, I wrote they still test as new which they both do being able to supply their nominal Ah capacity.
"Flatten completely and then measure how many amps it takes to fully recharge. Do it while putting 20 or 40 a/h charge back in. I,ll guarantee it wont be 100% capacity. It might make you feel better but its not what is happening in reality."
Sorry but that makes no sense, the discharge print shows the two 100Ah batteries in parallel supplied 200Ah before the test was terminated. Your saying if I was to then charge them back up which is what happens after the test the charger isn't going to put over 200Ah back into them, but next time I discharge them I'll get 200Ah back out of them again. If that was the case they would be more than a 100% efficient. I don't think so.
The batteries get tested yearly before each major outing and to date have always supplied their nominal rated capacity without any issues.
I would be interested to know what the tested capacity of your batteries are?
FollowupID: 924371
Follow Up By: Briste - Tuesday, Aug 22, 2023 at 15:57
I have borrowed a battery discharge testing device, and discussed how to use it with my auto-electrician. He suggested discharging until the BMS shuts the battery down. Any reason you did not go this route Leigh?
FollowupID: 924372
Follow Up By: Member - LeighW - Tuesday, Aug 22, 2023 at 16:18
It's upto you, most consider a Lifepo4 to be 0%SOC at 10.5 volts, personally I would not go that low normally I try to keep the battery above 20% SOC.
I don't know what the cut off limit is for the DCS batteries, I have the discharge tester running at the momment and have set it to stop discharging at 12.5V
I'll probably start it again and run it a bit lower will depend what Ah I get out of it to the 12.5V point and how quickly the voltage is dropping. I wouldn't want it sitting around at very low voltage for any length of time.
FollowupID: 924373
Follow Up By: Briste - Tuesday, Aug 22, 2023 at 16:49
I did accidentally flatten my DC just recently. I was a bit surprised that it happened, hence my interest in capacity testing. I think once it had got small amount of charge back in there sufficient to restart the bluetooth connection then it said 11.5V. Actually I probably didn't flatten it completely, just enough for the bluetooth connection to be turned off, which is how I knew I had a problem.
I like your idea of only discharging enough to see that you have rated capacity. Pushing it too low too often can't be good for battery life. But my discharge tester on loan will discharge down to a pre-set voltage, so the question is, what to set it at? Perhaps I'll try 12V.
FollowupID: 924374
Follow Up By: Member - LeighW - Tuesday, Aug 22, 2023 at 17:52
My xtreme is rated at its limit ie 81Ah, it is not a big battery but less voltage sag means you can keep a fridge running longer than you can with a 100Ah lead acid for instance. I work on around 60 useable Ah at 2Ah average drain so 30 hours battery life. You should be able to get a couple of days out of yours with a smallish freezer.
I installed the extreme as an experiment to see how it handles under bonnet temperatures, I really didn't expect it to last this long but thought I may as well give it a try as privious lead acids only lasted about 3 years so had nothing to loose trying the Lithium.
Like you temperature for the battery hasn't been a big issue, generally not much hotter than ambient when driving. A bit of heat sink when the engine turned of so will be interesting to see how it fares with this test. A lead acid would require replacement about now.
The guy in the video indicated he used them for winching, hot engine bay with the car stationary and heavy load on the batteries would most likely see his batteries getting a lot hotter at times. Compeditive winch teams I believe use Lithium but long battery life would not be a high priority for them.
In my case even if the capacity is down to 70% its still around the same useable Ah than a lead acid would give me with less voltage sag. If it gives me 7 years for the convenience of being able to house it under bonnet makes it worth it for me.
FollowupID: 924375
Reply By: Member - FLNGO - Tuesday, Aug 22, 2023 at 10:54
I'll be watching this thread with interest!
My scenario - LC VDJ200 / twin 130Ah DCS under the bonnet connected in parallel with LVD to ancillary loads / 100Ah VoltX slim in the rear charged via 20A DCDC from the DCS's under the bonnet.
With this system I no longer need to worry about SOC or carry solar panels with me to top up batteries if parked up for a couple of days. Previously I could only get 2ys from either lead acid or AGM's under the bonnet, by this stage capacity was very low & batteries had bulged.
DCS's under the bonnet have now been in service 22mths, 38kkm. Plenty of outback travel in this time, NSW, SA, QLD, Simmo etc.
The DCS App also displays individual cell voltage and to date when charge each cell is within 0.01V of its group, suggesting they are balancing well.
This chemistry degrades quicker at high & low voltages, thus I don't run alternator voltage boost diode with the DCS's as the system has ample capacity without needing to be fully charged, I just place a Victon charger on the DCS's 1 or 2 times a year and take it to full charge to reset the SOC calc. in the BMS.
Whats the simplest way to do a load test?
Fabio
AnswerID: 644317
Follow Up By: Member - LeighW - Tuesday, Aug 22, 2023 at 11:27
FLNGO,
The OP indicated the don't rely on the BMS for checking the SOC as it is wrong. My extreme battery is one of the first units and doesn't have the the bluetooth functionality, I assume the app records Ah in and out of the battery so not sure why he couldn't do a test using the BMS app.
If it does show Ah what is the most you have taken out of your batteries in one session?
FollowupID: 924354
Follow Up By: Member - FLNGO - Tuesday, Aug 22, 2023 at 12:21
Hi Leigh,
The App unfortunately is not that smart, basically provides instantaneous data & SOC %.
The info on the app is shown in this link next to the spec sheet: https://www.deepcyclesystems.com.au/product/ultimate-dcs-12v-260ah-dual-battery-system-lithium-land-cruiser-200-series/
FollowupID: 924357
Follow Up By: Member - LeighW - Tuesday, Aug 22, 2023 at 13:08
That's pretty poor BMPRO do the same, not much point having a battery monitor if it doesn't record Ah in and out. I installed a Victron smart shunt in the car to monitor the battery.
FollowupID: 924362
Reply By: Member - Bigfish - Wednesday, Aug 23, 2023 at 07:38
Smart way of testing
AnswerID: 644322
Follow Up By: Member - LeighW - Wednesday, Aug 23, 2023 at 08:25
I don't know what others are using but the device shown is similar to what I use, its just a constant current sink with a monitor attached the same as any other battery capacity/load tester.
FollowupID: 924378
Follow Up By: Briste - Wednesday, Aug 23, 2023 at 11:05
The device I borrowed and which is in use as I type is identical to the one with the red fan that you first see in detail in that video at the 2:45 mark. I am discharging at a rate of 5A, and I assume that's roughly accurate as the DCS app also reports a 5A discharge rate. The voltage reported by the device is 0.4-0.5V too low, as both a multimeter and the DCS app are reporting a higher battery voltage, which makes setting the cut-off a question of judgement.
The testing is nearly complete. The results look like they will be interesting and not what I was expecting. I'll report them later today.
FollowupID: 924379
Reply By: Briste - Wednesday, Aug 23, 2023 at 21:17
I ran a capacity test on my 100Ah under-bonnet DCS Lithium. It's been under bonnet for over 18 months. At a discharge rate of 5A it took close to 20 hours to extract 97.25Ah. So no sign of any heat-induced loss of capacity. Which is not a surprise, as in my currently model Prado 150, the DCS does not get hot when driving.
I could have extracted bit more, but I opted to stop when the bluetooth switched off at 11.3V . I wasn't intending to go that low, but in light of Leigh's experience I though I may have had a chance to get to 100Ah. However I thought it prudent to stop when the voltage started falling too rapidly. I probably should have stopped a bit sooner.
But wait ... there's more! The SoC reported in the app was nonsense. For each 5Ah extracted, the SoC only declined 1% or 1Ah. This was a consistent discrepancy. So by the end it was just above 80%. Once the bluetooth reappeared when I started to recharge, it had fallen to 0%. Moreover there was implausibly low growth of the SoC as I started to charge - the SoC was climbing much more slowly than the input current suggested that it should. I had this exact same experience when I recently accidentally flattened it. The SoC was very slow to climb, but once it got to around 20% it suddenly jumped to 100%. This suggests a 1:5 ratio between changes in the app and reality. Which makes a mockery of the DCS claim (on their website) that the SoC is highly accurate.
From this I conclude that my recent experience of an accidental flat battery was not due to a heat-induced loss of capacity, because there wasn't any. I now think that the appliances I was using were actually drawing a lot more of the battery's capacity over time than I had led to believe from the displayed SoC, and thus the real SoC was a lot lower than displayed in the app, and eventually fell to too low a level.
As it stands, I'm going to have to install a shunt, as I need an accurate measure of SoC.
AnswerID: 644324
Follow Up By: Briste - Monday, Aug 28, 2023 at 21:53
I'm going to have to walk back the observation about the inaccurate SoC measure in the DCS BMS & app.
I've done some real-world testing at the behest of my sparkie and found that when I did that the SoC was pretty accurate. I fully charged the auxillary battery and plugged in the freezer, and got a broadly accurate SoC reading with it running (checked against a somewhat inaccurate inline power analyser). So I recharged again and then ran the capacity tester via an Anderson plug in the rear of the Prado in a couple of 1 hour bursts with a one hour gap, and the discharge amount in the app closely matched the device all the way through the process.
So that's good news all round. I have no idea what caused the inaccurate SoC readings in the initial test and the 1:5 underestimation ratio. The test was done slightly differently, but it's hard to see that those differences would have made much difference to the result, but something must have so I'm going to watch the SoC much more carefully in the future.
I'm going to post this twice, since I've reported this in two separate sub-threads.
FollowupID: 924416
Reply By: Member - LeighW - Thursday, Aug 24, 2023 at 15:47
First off my battery is older than I thought, it was installed on the 4/12/2019 so is nearly 4 years old.
Battery is a DCS extreme. The battery is located in the right hand battery position under the bonnet and is charged directly off the alternator via a VSR.
Nominal battery capacity is 80Ah, it tested 81Ah when new out of the box and now tests 79Ah with a terminal voltage of 11.5V. So in 4 years it has lost about 2 Ah compared to out of the box but when tested new it was in summer so the temperature would have been warmer a lot warmer.
Car has travelled 37000Kms since then mostly pulling a 1750Kg camper and a good deal of the Kms off road. Battery has mainly been used to supply a 40Ltr waceo used as a freezer, has on a couple of occassions run a drill connected to a 1500W inverter and the battery also powers radio's HF etc and winch though I have only used the winch to pull over a few trees.
Battery is coping with the under bonnet temperatures and has outlasted all other lead acids I have had in that position.
Briste,
I watched a video of the app on the DCS website, it implies it measures Ah in and out even if it only displays it as "SOC". The one in the video seems to track the Ah in and out ok. Are you sure the battery Ah capacity has been correctly entered into the App?
With regards to the original video, I can't see anyware on the DCS website where it indicates capacity loss under bonnet will only be around 1% a year that the presenter quoted. DCS warranty states:
"The battery will be determined to be defective if it fails to deliver less than 70% of it’s rated capacity during the warranty period when installed inside engine bays or engine compartments." Warranty period is 3 years for under bonnet so 10% per year.
They also state in the installation instructions, at least they did in mine not to overtighten the battery hold down clamps. If clamps are tightened to the point where it deforms the case then the warranty will be void. I noticed that one of the battery cases in the video was badly deformed, have no idea why they would have tightened the hold down clamps to that point unless they did fit properly and if that was the case why wouldn't you modify the lamps to suit? I wonder if that was the one that was done to 50% capacity?
AnswerID: 644327
Follow Up By: Member - FLNGO - Thursday, Aug 24, 2023 at 17:15
The SOC on the App does not appear to reflect reality, here is yesterdays example.
2 x 130Ah DCS batteries under the bonnet of LC200, connected in parallel.
No load voltage on DCS App 13.17V per battery.
DCS App SOC 98% per battery.
15A Victron charger applied for 4h43m, 72Ah added according to charger (assume 36Ahr per battery).
36 / 130 = 27.7%, does not compute with a battery that started at 98%SOC.
Some time in the future I will try a similar test starting with a fully charged battery, drain then recharge to see if the problem is just SOC drift over time.
FollowupID: 924381
Follow Up By: Member - LeighW - Thursday, Aug 24, 2023 at 17:35
What resets the SOC, is it a specific voltage and tail current?
FollowupID: 924382
Follow Up By: Member - LeighW - Thursday, Aug 24, 2023 at 17:49
Seems you have to charge it to 14.6V for it to reset the SOC to 100%, pitty then didn't include a manual reset I certianly wouldn't like having to charge my battery to that voltage regulary.
FollowupID: 924383
Follow Up By: Member - FLNGO - Thursday, Aug 24, 2023 at 18:53
I think we are missing a no load or low charge current SOC curve for these cells which would give us an understanding of when the cells are above ~90% SOC (the upturn in the curve).
Due to flat nature of the SOC curve it is difficult to determine from DCS's 1C charge curve at what point the ~90% mark is in voltage terms for a lower charge rate.
FollowupID: 924384
Follow Up By: Member - LeighW - Thursday, Aug 24, 2023 at 19:09
Charging off solar or AC I rarely go above 13.8V, only if I want the cell balancers to balance the cells.
Charging off car I bump it up to 14.4V as I usually want to put as much back in as I can in the drive time.
FollowupID: 924385
Follow Up By: Briste - Thursday, Aug 24, 2023 at 21:09
Leigh - there's nothing to configure in the DCS app, other than giving the battery a friendly name. I think the app is either pre-configured with the existing battery types, and/or is just reporting whatever the BMS is broadcasting.
My tests suggested that the amps in or out reported by the app seems broadly accurate in as much as it matched what the discharge device was reporting. The voltage in the app was about 0.4V higher than the discharge device, but as a multimeter matched the app I was more inclined to believe that.
But I don't think that amps in and out are used to calculate the SoC. That's clear from my testing. The website says "SOC% estimate using impedance tracking – the App learns the SOC after the first 10 cycles", whatever than means.
"Seems you have to charge it to 14.6V for it to reset the SOC to 100%". That's consistent with my experience, and something similar for 0%.
I'm having a conversation with my sparkie about how much testing is required in order to raise the issue with DCS, who must be under siege at present after the release of that video.
FollowupID: 924386
Follow Up By: Member - LeighW - Friday, Aug 25, 2023 at 08:54
Honestly don't know why companies persist with using voltage or other than recording Ah determine SOC as they are never very accurate.
The DCS system makes no sense, it has a shunt in it and measures the current in and out accurately then only reason I can think of that it doesn't record Ah in and out is they don't want to pay the extra for the memory required to keep track. Just doesn't make sense.
FollowupID: 924387
Follow Up By: Allan B (Sunshine Coast) - Friday, Aug 25, 2023 at 09:20
Equating Amp-hours out and in is not an acceptable way to absolutely determine a battery's SOC. Due to innate inefficiency, a battery will require more Ah in than it has discharged in order to return it to the original state. As I understand it, in-out Ampere counting is used in the short term but will progressively introduce an error so the report is reset at each arrival at 'full charge'. This value is determined by observing the current reversal at the 'peak' voltage and only after the learning of say 10 cycles.
FollowupID: 924388
Follow Up By: Briste - Friday, Aug 25, 2023 at 09:32
I'm going to partly walk back what I said about not accurately reporting SoC. The app did track the discharge from 100% correctly, but divided it by 5. So 93% SoC, for example , was displayed after a discharge of 35Ah, or 35% from my 100Ah battery, but the app only reported 35/5 = 7% discharge.. This factor of 5 was utterly consistent across the entire discharge process. Every 5Ah pulled from the battery dropped the SoC 1%, or 1Ah from my 100Ah battery. I can't be absolutely sure that the same division by 5 occurred when charging from zero, but the behaviour was consistent with it. Weird!
Before contacting DCS, my sparkie wants me to partly discharge the battery via a more normal process, e.g. via a fridge freezer with bursts of current draw, and then leave it in a partly discharged state to see whether it normalises. I can't see that that's going to happen, if it is accurately tracking discharge but then applying a factor of 5.
FollowupID: 924389
Follow Up By: Member - LeighW - Friday, Aug 25, 2023 at 10:02
Alan I fail to see the point of your post, yes it will gradually drift but as you wrote a good quality monitor reset to 100% when the battery is fully charged. In my monitors the user sets the battery voltage and tail current at which the monitor will reset to 100% SOC.
FollowupID: 924392
Follow Up By: Allan B (Sunshine Coast) - Friday, Aug 25, 2023 at 12:24
Well Leigh, you did say…."Honestly don't know why companies persist with using voltage or other than recording Ah (to) determine SOC as they are never very accurate." so my post was to offer a reason why using Ah counting alone was insufficient to reliably present SOC. It is adequate to display SOC during a discharge and on the way back but then the monitor uses terminal voltage to declare 100% SOC and reset the cycle.
If you still do not see my point, then ignore it. I have better things to do than join a debate or fret over the precision of my battery monitor. It displays the SOC near enough for me.
FollowupID: 924394
Follow Up By: Member - LeighW - Saturday, Aug 26, 2023 at 15:37
People are generally worried about how many Ah are left in the battery, if the monitor resets each time the battery is fully charged then with a 100Ah battery for instance you know exactly how much of the 100Ah you have used and what is left.
On the other hand if the monitor is using voltage to determine what is left in a Lithium then you may as well not have a monitor at all.
FollowupID: 924397
Follow Up By: Andrew L - Sunday, Aug 27, 2023 at 21:03
Last time i spoke to DCS, it was about both my batteries (130) reading different percentages. Their response was the solar battery will charge both to 14.6, whereas the alternator will go as far as 13.7. (heat under bonnet the reason for the difference.) Fast forward and they have obviously reset at 14.6 as they both read thesame now (%)
FollowupID: 924408
Follow Up By: Briste - Monday, Aug 28, 2023 at 21:55
FollowupID: 924417
Reply By: Member - McLaren3030 - Sunday, Aug 27, 2023 at 08:03
From all of the discussions on this “post”, perhaps it should be renamed “Battery Wars” :-)
AnswerID: 644339
Follow Up By: AlbyNSW - Sunday, Aug 27, 2023 at 08:19
Funny you say that, I am following this thread to expand my knowledge
The thing I have learned so far is no one can even agree on how much capacity a battery has. It appears to have gone the say way as gender identity, you have as much capacity as you feel you have lol.
FollowupID: 924399
Follow Up By: Member - FLNGO - Monday, Aug 28, 2023 at 17:09
My take on this issue to date is;
- OP video states LiFo batteries will not last (degrade quickly) in under bonnet use.
- ExploreOz forum data to date suggests negligible loss of capacity :)
I will add my data in a couple of weeks when my load tester arrives, would be good if other members with DCS batteries do likewise to get a larger data set.
Fabio
FollowupID: 924412
Follow Up By: Member - FLNGO - Thursday, Sep 14, 2023 at 17:17
Finally managed to load test my 2 under bonnet batteries (DCS Ultimate 130 x 2)
Tested with 12A load (limit of load tester).
Both batteries tested effectively the same as per the graph below.
Assuming they started at 130Ahr capacity, now at 109Ahr, thus lost ~ 16% capacity in 2 yrs / 40kkm.
FollowupID: 924504
Follow Up By: Member - FLNGO - Friday, Sep 15, 2023 at 06:55
During this test I also noticed the DCS App SOC% did not drop below 90% until battery voltage was below ~11.8V, at this point it went to 0%, indicating SOC not calibrated.
Found the answer to this issue in the DCS FAQ section as per below extract;
When the battery pack is discharged down to 11.50V the BMS resets to 0%SOC and now is placed in a relearning state - the pack must be fully charged continuously without stopping to calibrate again. Charge it on a mains charger to 14.60V.
Depending on the usage pattern, best to fully cycle the batteries once every 3 months to give the cells a refresh. To fully cycle a 12V pack discharge to 11.50V and charge to 14.60V.
FollowupID: 924506
Follow Up By: Briste - Friday, Sep 15, 2023 at 08:41
That is an excellent find FLNGO. I'm embarrassed that I didn't find it myself. It pretty much explains the behaviour of my system, and means I can stop worrying about whether I can trust the SoC now that it seems to be behaving normally. The only thing it doesn't explain is what load caused it to go flat in the first place.
I am surprised about the advice to fully cycle the batteries every three months.
FollowupID: 924507
Reply By: Allan B (Sunshine Coast) - Thursday, Sep 14, 2023 at 18:07
I use a somewhat esoteric but reliable way to determine if my batteries are still providing adequate power after some extensive use.
It goes like this….. 1) Open fridge and remove a beer. 2) open beer and take a good sip. 3) Consider if the beer is cold enough for my desires. 4) If answer is yes then both the fridge and the battery pass judgement. 5) continue to sip remaining beer and marvel at the wonder of the science that can keep it at close to zero degrees Celsius and within my reach. Otherwise known as "All is Good With the World". Ahhhhhhhhhh.
When you are finished with your meticulous scientific battery testing wander over and sample some of my chilled refreshment.
AnswerID: 644415
Follow Up By: qldcamper - Friday, Sep 15, 2023 at 04:35
Could always use a dip stick Allan, insert a metal rod through the length of the battery and if it comes out several inches shorter then the battery still had plenty of go left in it.
By the way, if anybody is thinking this is a serious post, please do not try it.
FollowupID: 924505
Follow Up By: Member - Outback Gazz - Tuesday, Sep 19, 2023 at 07:14
I have been using that method since I purchased my first 12 volt fridge 35 years ago !
What annoys me about these new lithium batteries is when I go camping with people who have them they spend half their free time staring at their stupid phone monitoring the batteries SOC etc. The time they waste doing that I can get another couple beers down lol
Gazz
FollowupID: 924532
Follow Up By: Allan B (Sunshine Coast) - Tuesday, Sep 19, 2023 at 09:03
Hahaha Gazz, Grab a couple of cold beers out of my fridge Mate and come sit over here with me.
FollowupID: 924533
Follow Up By: Member - Outback Gazz - Tuesday, Sep 19, 2023 at 13:52
G'day Allan
I'm planning to retire next year or at least semi retire, so with my trusty Campomatic XTC in tow I will be doing a few trips to here, there and wherever so our paths may cross at some stage for couple coldies !
Gazz
FollowupID: 924536
Follow Up By: Allan B (Sunshine Coast) - Tuesday, Sep 19, 2023 at 14:27
That would be great Gazz, but with my Sprinter van now replacing the Troopy I don't get on the rough tracks anymore. But you never know…………?
FollowupID: 924538
Follow Up By: Member - Outback Gazz - Wednesday, Sep 20, 2023 at 18:37
"I don't get on the rough tracks anymore"
Yeah me too sort of - depends who I travel with. Some of my friends still do hard stuff, other friends the easy stuff and now the majority, due to age and health just like to travel and tour, see the sights and have a camp somewhere.
So there is still the possibility that we may catch up somewhere for a couple coldies !
So how is the sprinter going and how are you enjoying the extra creature comforts over the Troopy ?
Gazz
FollowupID: 924555
Follow Up By: Allan B (Sunshine Coast) - Wednesday, Sep 20, 2023 at 19:40
.Well Gazz, understand firstly that the Sprinter motor-home was Roz's idea. Having carted the poor girl over many thousands of km in a basic Troopy she had enough! The Troopy was comfortable (sort of) with Stratos suspension seats and had a comfortable double bed, but that was about it...... no toilet!!!
The Sprinter is much quieter and has an INSIDE TOILET and shower. And you know what they say about a 'happy wife'. It certainly is comfortable and has tons of power. Copes well with unsealed roads and corrugations but I wouldn't want to subject it to an excess of that as it was designed and built as an urban delivery vehicle. So far we have been to Innaminka and down the Strez and Borefield Track. The big trip was from home in Qld toExmouth via the Nullarbor but that was all blacktop and easy.
Loaded with heaps of technology, some of which I appreciate and some which drive me crazy. And I dread the thought of a minor sensor failure leaving me stuck in the middle of nowhere. The fencing wire and gaffer tape that I carried in the Troopy would not be of much help!
But you have to cope and be content with watchya got and we have explored a number of places that we previously drove through on our way to the deserts. So keep your eyes open for a silver 4WD Sprinter with a happy couple in the front seats, Qld reg 011CC6.
FollowupID: 924556
Follow Up By: Member - Outback Gazz - Thursday, Sep 21, 2023 at 08:22
"And you know what they say about a 'happy wife'."
Yep, that's why I very very very rarely take mine - her idea of roughing it is a motel with no room service !
She can stay home and be happy lol.
Re: creature comforts - it was only about ten years ago I upgraded to throwing my DB swag onto a stretcher, ah heaven ! Then about three years ago I bought a 2006 Campomatic XTC rear fold camper, 150 litre water tank with 12 volt pump, 4 burner stove, mounted gas bottle, slide out storage drawers, 60 litre fridge, lights and numerous other goodies that my swag doesn't have AND a queen size bed - what luxury !!
Most of my friends have caravans with a few having motorhomes with one being a sprinter and they love it - main reason they didn't buy a caravan is because his wife will not tow a caravan but happy to drive the sprinter. Guess I will be making a decision which way to go when the time comes I need a shower and toilet out of the weather but for now the camper suits me fine - goes anywhere my Ford Ranger or 200 series can go !
Happy and safe travels in your sprinter
Gazz
FollowupID: 924563
Follow Up By: Member - FLNGO - Friday, Sep 22, 2023 at 16:58
Allan / Gazz,
Can I please request you refrain from adding non value add commentry to this thread on DCS batteries.
Fabio
FollowupID: 924572
Follow Up By: Allan B (Sunshine Coast) - Friday, Sep 22, 2023 at 17:14
Fabio,
Yes certainly, go ahead.
FollowupID: 924573
Follow Up By: Member - Outback Gazz - Friday, Sep 22, 2023 at 18:26
Does your Sprinter have DCS batteries fitted ?
If not what brand would you recommend ?
Gazz
FollowupID: 924574
Follow Up By: Member - Outback Gazz - Friday, Sep 22, 2023 at 18:31
Fabio
Not a problem at all - I will permanently refrain when my yearly membership expires end of the year !
Gazz
FollowupID: 924575
Follow Up By: qldcamper - Saturday, Sep 23, 2023 at 11:46
Wasn't aware that this thread was about DCS batteries, Just batteries in general.
FollowupID: 924578
Follow Up By: Allan B (Sunshine Coast) - Saturday, Sep 23, 2023 at 14:32
Well Qldcamper, it is your thread after all. Do you object to a bit of "off-topic" interaction between a couple of members….. around the campfire as it were?
I did refresh my memory of Forum Rules and although there is mention of "Foul Language, Personal Attack, Trolling, and Inappropriate" I found nothing about "Off Topic".
So I don't really consider Fabio's request to be reasonable, do you?
FollowupID: 924580
Follow Up By: Member - Outback Gazz - Saturday, Sep 23, 2023 at 17:41
I'm not looking for an argument with Fabio as he has his role on here but the way I see it is this thread was coming to an end with no replies for days and the thread will be archived shortly so where is the harm in a bit of friendly banter between members - which is what made this such a great site years ago !
Thread topics are dwindling, replies are dwindling and you can have an educated guess where this is heading.
Anyway I best go and see how my new pet I just got is going
I bought a pet termite so I called him Clint....... Clint Eatswood
Gazz
FollowupID: 924582
Follow Up By: Allan B (Sunshine Coast) - Saturday, Sep 23, 2023 at 18:18
Yeah, your'e right Gazz. This forum is not as jovial as it was. It's becoming like a couple of other forums I visit…. serious and brinksmanship. Maybe the whole world is going that way…. I dunno, haven't been out much lately.
But "Clint Eatswood"???? …. Gazz, your'e pathetic!
FollowupID: 924583
Follow Up By: qldcamper - Saturday, Sep 23, 2023 at 18:46
It really hasnt gone off topic Allan, the topic has just broadened a bit.
The DCS vid was just an example of all batteries and merchants bull crap trying to sell them.
The way people use them and how they perform is the only real test, not theoretical performance like the sales people use.
FollowupID: 924584
Follow Up By: Nomadic Navara - Sunday, Sep 24, 2023 at 08:12
I am also wondering what Fabio is on about. This sideline diversion is under its own separate reply thread and was not stuck into the more technical reply threads that would have disrupted the flow of them.
FollowupID: 924586
Follow Up By: qldcamper - Sunday, Sep 24, 2023 at 09:57
My current set up is almost embarrassing, well not really almost, it is, but it seems to be working pretty well but it is definatly not something I'd suggest setting up. I think it is only because of design inefficiencies that I deemed acceptable when designing the system allows it to work but needs to be managed, not the forget about it and let it do its thing type that it originally was.
Mainly due to the now mismatched battery chemistry due to me being a tight arse.
FollowupID: 924588
