Mirror Width - Another Regulatory Question
Submitted: Friday, Aug 18, 2023 at 23:50
ThreadID: 146129 Views:5781 Replies:7 FollowUps:23
Q?: What are the rules on the maximum protrusion of mirrors from the vehicle? Or, maximum width of a vehicle, including mirrors?
I haven't been able to locate anything authoritative for vehicles under 3.5T GVM.
Background:
I've recently heard a lot of discussion (a.k.a hearsay) about authorities 'targeting' towing mirrors, saying most are too wide and must be removed if you aren't towing anything.
Initially I figured this was only for temporary 'clip-on' mirrors, but some are saying they've been advised to remove their Clearview/MSA replacement mirrors.
The only references I can find mentioning mirror width/extension are in regs for heavy vehicles, relating to vehicles with GVM greater than 3.5T (which excludes most cars/4x4s). These rules state mirrors may only protrude 150mm from the side of the vehicle, or up to 230mm if they are foldable. So for a standard width truck at 2.5m, total width would be 2.8m (rigid mirrors), or 2.96m (folding mirrors).
If a police officer were to issue a ticket/defect notice, what reg/law/section would you be ticketed against?
Reply By: Member - John - Saturday, Aug 19, 2023 at 06:41
Beatie, have no idea what reg/law would be broken, I found the following from VICROADS, which is not very helpful or specific.
"Make sure your car is ready for towing
Not all cars can tow a caravan.
Check that your car:
has enough power to tow your caravan
is regularly serviced and is in good mechanical condition
has good rear vision when the caravan is attached, you may need to fit extension mirrors to your car
(extension mirrors must be removed when not towing)
I can find references to ADR's, Over Dimensional Rules, but no specific rule or regulation regards towing mirrors having to be removed.
As can be seen in the three images, the standard Nissan GU mirror is wider than 150mm and the Clearview Compact is 71mm wider with the Originals another 76mm wider when closed. To my mind, strictly by the rules, ie nothing 150mm wider than the vehicle, they are illegal?
From the Clearview website, "Clearview Towing Mirrors® Are Legal in All Australian States And Territories
All of our Towing Mirrors have been tested and approved as compliant with all applicable Australian Design Rules. Which ensures their legality in all states and territories of Australia."
Be interesting if anyone can find the correct reg/law?
John and Jan
AnswerID: 644303
Reply By: Member - McLaren3030 - Saturday, Aug 19, 2023 at 07:04
Hi Beatle,
This question comes up from time to time, unfortunately the incorrect information continues to be spread by albeit well meaning, but ill informed people.
Both Clearview and MSA replacement mirrors are legal “folded in” when not towing. If you leave them out when not towing, you can be fined.
If you look in the ADR’s I think you will find the definitive information you are looking for. From memory the wording is something like: nothing can protrude from the widest part of the side of the vehicle by more 150 mm. The important words here are “the widest part of the vehicle”. The widest part may actually be the mudguards, and not the door pillar where the mirrors are mounted. When your caravan or trailer is connected to your towing vehicle, the trailer or caravan is considered to be part of your vehicle, so the measurement should be taken using the side of the trailer or caravan.
With respect to class of vehicle, if you have had a suspension upgrade to greater than 3.5 Tonne GVM, then your vehicle falls into the category of a light truck, so “light truck” rules apply. Still on a “car licence”, but your vehicle must comply to the light truck category such as Cat 6 side indicators. Some Clearview mirrors have indicators built in so that they actually comply with this standard. If your vehicle has not had a suspension upgrade to greater than 3.5 Tonne GVM, then your vehicle does not not need to comply to the light truck regs, so Cat 6 indicators are not required.
AnswerID: 644304
Follow Up By: Beatle Bayly - Saturday, Aug 19, 2023 at 10:21
Thanks Macca. I agree that for the purposes of this discussion, 'width of vehicle' would include any (legal) fixed bodywork on the tow vehicle, and the width of a trailer while attached to the vehicle.
Most caravans would be around 2400mm wide not including awnings, sidelights, antennae etc?
FollowupID: 924314
Follow Up By: Peter_n_Margaret - Saturday, Aug 19, 2023 at 10:24
Awnings must be included in the "actual" width, side lights are not, from memory.
FollowupID: 924315
Follow Up By: Beatle Bayly - Saturday, Aug 19, 2023 at 12:39
Thanks Peter. In that case the LH mirror can stick out further than the RH..... :-)
FollowupID: 924317
Reply By: Beatle Bayly - Saturday, Aug 19, 2023 at 10:15
Thanks for the responses. I believe I may have answered my own question as I've found a more complete/current version of Australian Design Rule 14/02 – Rear Vision Mirrors (2006).
Reference: https://www.legislation.gov.au/Details/F2014C01366
Section 15.2 seems to have the requirements and I distill this to:
a. Mirrors limited to 250mm beyond the width of the vehicle, and
b. Mirrors may exceed vehicle max width rules.
From the ADR:
15.2.2.5. Mirrors shall not project beyond the external bodywork of the vehicle substantially more than is necessary to comply with the requirements concerning fields of vision laid down in paragraph 15.2.4. below.
15.2.2.6. Where the lower edge of an exterior mirror is less than 2 m above the ground when the vehicle is loaded to its technically permissible maximum laden mass, this mirror shall not project more than 250 mm beyond the overall width of the vehicle measured without mirrors.
15.2.2.8. Subject to the requirements of paragraphs 15.2.2.5., 15.2.2.6. and 15.2.2.7. above, mirrors may project beyond the permissible maximum widths of vehicles.
Time to get the tape measure out.......... :-)
AnswerID: 644305
Follow Up By: Beatle Bayly - Saturday, Aug 19, 2023 at 14:45
For the record:
Vehicle:2003 HDJ100 Landcruiser GXL
Nom vehicle width (from factory sec sheet): 1940mm
Mirrors: Clearview Next Gen
Measured mirror width retracted: 2335mm = 395mm wider than vehicle (allowance = +500mm so meets
requirements)
Measured mirror width extended: 2650mm = 710mm wider than vehicle (exceeds requirements).
However my van is at least 2400mm wide (not incl awning), so 2650-2400=250mm, well within the ADR
requirements.
FollowupID: 924320
Follow Up By: RMD - Sunday, Aug 20, 2023 at 10:34
GOOD to see the word RETRACTED instead of FOLDING being used, because if using mirrors, when you don't need them for a wide trailed vehicle, FOLDING them means NO mirrors in use for the tow vehicle, whereas, slid in or out or extended and retracted means different to FOLDING.
Many people speak of folding as being retracted for some reason, and everyone is expected to know what is being meant.
FollowupID: 924324
Reply By: Andrew L - Saturday, Aug 19, 2023 at 15:15
may i ask where you got 3.5t from? (Its 4.5t in NSW)
AnswerID: 644308
Follow Up By: Beatle Bayly - Saturday, Aug 19, 2023 at 20:00
Andrew, what are you referring to when you say 'Its 4.5t in NSW'?
There are a lot of requirements that change at a GVM of 3.5T.
Specifically, for mirrors, ADR 14, sect 3.3 APPLICABILITY TABLE describes the different ADR Vehicle Codes depending on GVM (and other criteria)
This one is QLD-specific but likely similar in all States:https://www.legislation.qld.gov.au/view/pdf/2013-08-01/sl-2010-0192 Refer sect 24 & 25 for mirrors.
Now this presents an interesting, and I'd say unintended consequence.
EXAMPLE:
If we had two identical Landcruiser wagons (MD1 vehicle code, Ref ADR 14/02 sect 3.3. ) they are allowed mirrors that sit 250mm further out than the width of the vehicle (ADR 14/02 sect 15.2.2.6.)
However, if we then do a GVM upgrade on one 'Cruiser such that it's GVM is now 3.5T-4.5T it becomes an MD3 vehicle code and restricted to mirrors of only 230mm (folding). Refer APPENDIX C – ADR 14/02 - REAR VISION MIRRORS para 4.3
FollowupID: 924321
Reply By: IvanTheTerrible - Friday, Aug 25, 2023 at 22:20
We have had a customer pinged and defected for retractable mirrors on a Ranger. He tried putting it in to get it cleared without removing them and they wouldn't pass it. In Victoria
AnswerID: 644333
Follow Up By: Beatle Bayly - Sunday, Aug 27, 2023 at 18:21
I'd be interested to see the wording on the infringement notice. It would at least be worth writing a well-written letter to see if he can get off without needing to contest it in court (that would depend on the wording of the infringement notice though). However, even if he can get the defect cleared, he may still be at fault if he had them extended without a trailer on.
FollowupID: 924403
Follow Up By: IvanTheTerrible - Sunday, Aug 27, 2023 at 18:46
They were over width while retracted.
FollowupID: 924404
Follow Up By: Member - PhilD_NT - Sunday, Aug 27, 2023 at 19:40
Do you know what brand they were?
FollowupID: 924406
Follow Up By: Member - McLaren3030 - Monday, Aug 28, 2023 at 06:42
Ivan,
It would be interesting to know where the width of the vehicle was measured that determined the mirrors were over width when retracted.
The wording in the ADR’s state the mirrors can be no more than 150 mm wider than the widest point of the vehicle when retracted. The widest point of most 4WD’s is between the out edges of the mudguards, as they are generally flared. If you have permanent “add on flares”, that would make the vehicle even wider.
It sound like the person who inspected the vehicle for compliance, may have made a mistake.
FollowupID: 924409
Follow Up By: IvanTheTerrible - Monday, Aug 28, 2023 at 20:16
Measurements are to vehicle factory spec. You cant modify something and then use that as the base. Adding flares doesn't make a vehicle legal.
FollowupID: 924413
Follow Up By: IvanTheTerrible - Monday, Aug 28, 2023 at 20:21
Clearview mirrors are 427mm retracted. Thats nearly 1/2 a metre and can I ask Macca what your automotive qualification is?
FollowupID: 924414
Follow Up By: IvanTheTerrible - Monday, Aug 28, 2023 at 20:37
ADR 14
2.3.1.2. Mounting - The mirror mounting shall provide a stable support for the mirror and neither the mirror nor the mounting shall protrude further than the widest part of the vehicle body, except to the extent necessary to produce a field of view meeting the requirements of Clause 2.3.1.1. The mirror shall not be obscured by the unwiped portion of the windscreen, and shall be adjustable from the driver’s seating position. The mirror and mounting shall be free of sharp points or edges that could contribute to pedestrian injury.
FollowupID: 924415
Follow Up By: Member - McLaren3030 - Tuesday, Aug 29, 2023 at 06:48
Hi Ivan,
I do not have to have any automotive qualifications to read what is required in the ADR’s. I will need to recheck the wording of the remaining section of the ADR’s that you have posted, as I seem to recall there was a figure quoted with regard maximum protrusion of the external mirrors, of course, I am happy to be corrected if I have misread this section.
The Next Gen Clearview mirrors when retracted are 351 mm from the mounting point. The mounting point of the mirrors is not necessarily the widest point of the vehicle, as I stated earlier it is generally the distance between the outer edges of the mudguards. In my case, the mudguards are more than 150 mm wider each side than where the mirror is mounted on the “A” Pillar. I do not have aftermarket flares on the mudguards.
FollowupID: 924418
Follow Up By: Nomadic Navara - Tuesday, Aug 29, 2023 at 17:42
Quote "Measurements are to vehicle factory spec. You cant modify something and then use that as the base. Adding flares doesn't make a vehicle legal."
There are vehicles out there where they have had to add flares so they do make them conform to the ADRs. This happens when longer axles are put under the vehicles or wider tyres were fitted. Are you telling me that is just not on and you can not modify a vehicle by adding wide tyres?
FollowupID: 924421
Follow Up By: IvanTheTerrible - Tuesday, Aug 29, 2023 at 19:30
Nomadic Navara: Longer axles require an engineers ticket and this has nothing to do with mirrors
McLaren3030: Clause 2.3.1.1. is to do with vision to the rear on a standard body. In a ute it would be the tub
FollowupID: 924422
Follow Up By: Beatle Bayly - Wednesday, Aug 30, 2023 at 09:17
Macca, Ivan, if you go back up to one of my prior posts you'll see where I've referenced the ADR for overall width of mirrors. It's up to 250mm each for an MD1 code vehicle, and 230mm each side for a MD3 code vehicle.
Furthermore, I'd be using the factory specification for the vehicle width (as I've shown in the calcs above for my landcruiser). I get it that people add flares to cover wider tyres etc, but in most cases that's simply to comply with the ADR relating to tyre coverage/mudflaps. Those 'mods' don't formally amend the recorded width of the vehicle itself (these things are never cut-n-dry unfortunately).
So for Ivan's customer, if the retracted mirrors total width is within 500mm of the total vehicle width, I'd be arguing it in court. He might still cop the original fine (because they were unnecessarily extended), but should be able to clear the defect with those mirrors fitted (and retracted).
FollowupID: 924423
Follow Up By: IvanTheTerrible - Wednesday, Aug 30, 2023 at 20:01
I'd love to see the link to the ADR that has a measurement because the ADR listed on the Federal Gov site doest have a measurement but has a formulae to work it out
FollowupID: 924426
Follow Up By: IvanTheTerrible - Wednesday, Aug 30, 2023 at 20:11
The whole ADR APPENDIX C – ADR 14/02 - REAR VISION MIRRORS
2. REQUIREMENTS FOR LEP; MA; MB; MC; AND MD1 VEHICLES ONLY
2.0. Any internal rear vision mirror fitted to a vehicle and intended to provide the driver with a view of following or overtaking vehicles shall have a flat reflecting surface i.e. of unit magnification.
2.1. An external mirror complying with the requirement of Clause 2.3 shall be fitted on the driver’s side of the vehicle. An internal rear vision mirror shall also be provided except where the design of the motor vehicle does not provide for internal rear vision. In any case where the field of view requirements of Clause 2.2.1 are not met the vehicle shall be equipped with a passenger’s side external rear vision mirror complying with Clause 2.3.2.
2.2. Internal Rear Vision Mirrors
2.2.1. Field of View - An internal mirror shall be installed that provides all drivers (with eyes located by the ‘95th Percentile Eye Ellipses’ tangent contours) with a view to the rear, with an included horizontal angle of at least 20 degrees and sufficient vertical angle to provide a view of a level road surface extending to the horizon beginning at a point not greater than 61 metres to the rear of the vehicle when the vehicle is occupied by the driver and 4 passengers or the designated ‘Seating Capacity’, if less, based on 68 kg average occupant mass. The line of sight may be partially obscured by seated occupants or by ‘Head Restraints’.
2.2.2. Mounting
2.2.2.1. The mirror mounting shall provide a stable support for the mirror, and shall provide for adjustment by tilting in both horizontal and vertical directions.
2.2.2.2. If the mirror is in the ‘Head Impact Area’, the mounting shall deflect, collapse or break away without leaving sharp edges when the reflective surface of the mirror is subjected to a force of not more than 400 N in any ‘Forward’ direction that is not more than 45 degrees from the ‘Forward’ longitudinal direction.
2.3. External Rear Vision Mirrors
2.3.1. Driver’s Side
2.3.1.1. Field of View - A flat external mirror shall be installed that provides all drivers (with eyes located by the ‘95th Percentile Eye Ellipses’ tangent contours) with a view of a level road surface extending to the horizon from a line perpendicular to a plane tangential to the driver’s side of the vehicle at the widest point and parallel to the longitudinal axis of the vehicle, extending 2.4 metres out from the tangential plane 11 metres behind the driver’s eyes, with the ‘Seat’ in the rearmost position. The line of sight may be partially obscured by rear body or wheel guard contours. A convex mirror complying with the technical requirements of Appendix A may be used instead of a flat mirror.
2.3.2. Passenger’s Side
2.3.2.1. Where a left-hand external mirror is provided in compliance with Clause 2.1 its mounting shall provide a stable support for the mirror. The mirror and mounting shall be free of sharp points or edges that could contribute to pedestrian injury. The mirror need not be adjustable from the driver’s seating position, but shall be capable of adjustment by tilting in both horizontal and vertical directions.
2.3.2.2. The mirror shall be flat or convex.
2.3.2.3. For ‘Convex Mirrors’ the reflective surface area is to be equal to or greater than that of a flat mirror required to meet the field of view requirements set out in Clause 2.3.1.1.
2.4. Mirror Construction
2.4.1. Reflectance
The reflectance value of the reflective film employed shall be at least 35 per cent. If a mirror is of the selective position prismatic type, the reflectance value in the night driving position shall be at least 4 per cent.
2.4.2. ‘Convex Mirrors’
Each motor vehicle using a ‘Convex Mirror’ to meet the requirements of Clause 2.3.2 shall comply with the following requirements:
2.4.2.1. the radii of curvature shall not deviate by more than plus or minus 15 per cent from the average radius of curvature when measured in accordance with the procedures specified in Annex 1.
2.4.2.2. the average radius of curvature is not to be less than 1,200 mm.
2.5. Test Procedure
2.5.1. Reflectance shall be determined in accordance with SAE document J964a "Test Procedure for Determining Reflectivity of Rearview Mirror", August, 1974.
2.5.2. The horizontal angle is measured from the projected eye point rather than the plane of the mirror.
3. REQUIREMENTS FOR VEHICLES OF CATEGORY LEG; NA AND MD2 ONLY
Vehicles of category NA, LEG and MD2 shall have mirrors which comply with Clause 2 or 4.
FollowupID: 924427
Follow Up By: IvanTheTerrible - Wednesday, Aug 30, 2023 at 20:14
The only measurement is for MD3 and they have to be capable of folding down to a max of 150mm
4.2 At least one such mirror shall be affixed to each side of the vehicle and may project 150 mm beyond the point of ‘Overall Width’ of the vehicle or the ‘Overall Width’ of any trailer it may be drawing-
4.3. The mirrors may project 230 mm on each side beyond the point of ‘Overall Width’ of the vehicle provided that the mirror is capable of collapsing to 150 mm.
FollowupID: 924428
Follow Up By: Member - McLaren3030 - Thursday, Aug 31, 2023 at 06:30
Thanks for copying the wording, I knew I had read somewhere in the ADR’s that there were actual measurements. Just couldn’t remember where, and I am in the middle of organising and packing for my trip to the Simpson Desert, leaving early this Sunday Sept. 3rd. so haven’t had time to go through it myself.
FollowupID: 924429
Follow Up By: Beatle Bayly - Thursday, Aug 31, 2023 at 07:48
Ivan, this is the link I've been referencing:https://www.legislation.gov.au/Details/F2014C01366
I believe a Landcruiser (wagon) or similar is an MC/M1 category ((Offroad Passenger Vehicle), not MD1/MD3 (light omnibus). Maybe that's a point of difference in our interpretations of the reg? Refer Applicability Table Para 3.3.
From para 15.2.2.6. : "Where the lower edge of an exterior mirror is less than 2 m above the ground when the vehicle is loaded to its technically permissible maximum laden mass, this mirror shall not project more than 250 mm beyond the overall width of the vehicle measured without mirrors."
And for para 4.3 of Appendix C, noting these are "REQUIREMENTS FOR MD3; MD4; ME; NB; AND NC VEHICLES ONLY." : "The mirrors may project 230 mm on each side beyond the point of ‘Overall Width’ of the vehicle provided that the mirror is capable of collapsing to 150 mm" .
I interpret 'COLLAPSING' to be folded back against the car if you hit something. So with the mirrors RETRACTED to their shortest extension, but still positioned so as to be useable, you have 230mm each side.
However, as para 4.3 App C doesn't apply to M1 or MD1 category vehicles, and as you say, there are no other width measurements in Appendix C, I would then default back to para 15.2.2.6 (250mm) for an M1/MD1 category vehicle.
FollowupID: 924430
Reply By: Dean K3 - Thursday, Aug 31, 2023 at 10:49
Its a mystery at times. One thing that should be noted if a vehicle at the maximum allowed width of 2.5 metres is transported on back of a flatbed trailer it becomes a over width load due to mirrors attached to vehicle.
I won't open the can of worms as far as signs and NHVR is concerned
i see the need for wider mirrors for towing even some ute tray bodies are wider but I don't believe a set of elephant ears wide enough to be hazards need to be fitted either
AnswerID: 644359
Follow Up By: Member - PhilD_NT - Thursday, Aug 31, 2023 at 12:24
Even my earlier model "elephant ears" can be folded in, albeit manually, so would never be wide enough to be an issue on a tray. Hopefully it never happens, but till that day one mirror gives a legal, stable and great view down the sides of the van and the smaller mirror allows me to visually monitor both the stonestomper and van tyres.
FollowupID: 924432
Reply By: Member - McLaren3030 - Friday, Sep 01, 2023 at 06:38
Yes Phil,
And those mirrors don’t vibrate, fall off or get blown back in by passing trucks and other larger vehicles.
AnswerID: 644362
