Friday, Aug 11, 2023 at 10:24
Hi Lainie, good to see you wanting to get out and explore, regardless of vehicle (many of us started seeing the "outback" in 2wd's, often going to
places now considered essential 4wd country).
The problem with wanting to go on "only 2wd" tracks is that the definition (and actual conditions) of such tracks is tenuous. Most general tracks travelled by 4wds can also be traversed with 2wd. The advantage of 4wd comes in when conditions are such that traction is compromised (most often when a perfectly reasonable 2wd track gets slippery due to rain). The four wheel drive then has an advantage, though this may be a matter of degrees. A track which becomes too slippery for 2wd can easily move to being too slippery for 4wd (many 4wds without lockers end up as 2wds, effectively making them 0wds in these conditions!).
The biggest advantage for so-called 4wds is clearance and durability (two quite variable characteristics).
I imagine you are not looking to tackle hard tracks in the
Vic High Country, the OTT on the Cape or soft sand tracks in the deserts? If not you will find most (not all) tracks are doable in a 2wd, so long as they are driven according to the conditions required, slowly and with lowered tyre pressures. Assessing the condition of the tracks prior to travelling (they can vary enormously over time) is of more importance. Communicating on forums such as this and making use of local sources (including government road condition sites) is the key. Along with sensible decision making and preparation... These come with study and experience, which is why initial trips need to be on less risky routes.
I'm not sure how the app could successfully differentiate 2wd vs 4wd tracks, other than providing a grading, which would be far too variable to be effective. I've certainly never come across such a facility, perhaps there is a way (admin can help here). The
Oodnadatta Track, for instance, has been travelled by thousands of 2wd-ers quite readily, but can quickly become difficult and then unadvised for
well set up 4wds if the conditions change (it's not just the ability to traverse the track, but the damage you can do to it in certain conditions, plus the risk of stranding, requiring others to assist). I should add that there are a few sites which do have grading for many tracks, 4x4 Earth being one.
The members here are a very good source of current and general information should you require it. The mapping app should provide your required needs with these additional supports.
Mark
644259
Follow Up By: Lainie C - Saturday, Aug 12, 2023 at 01:28
Thank you for this thorough reply. I'm really grateful for your considered and detailed response.
And I agree about keeping it simple to start with, especially being new to to this style of adventure.
I also got a satellite communicator. A Garmin GPSMAPS 66i. Was going to get the In Reach Mini2 or zoleo, and the guy in the
shop suggested the 66i ... but now I wonder if this would be doubling up with navigation software? I wanted to get it mainly for communication, and decided I liked the tracking & mapping features, though it seems this app would give me those things on my phone. Am a bit confused, and also grateful for such great technology.
924276
