HELP NEEDED ASAP OME SUSPENSION
Submitted: Tuesday, Jun 27, 2023 at 11:58
ThreadID: 145922 Views:3051 Replies:7 FollowUps:1
Hi All
Does anyone know how these pins come out? Given it a wack, nothing. Are they threaded in? Surely not.
Greasable on other side.
Any suggestions appreciated
Lyndon
Now is the only time you own
Decide now what you will,
Place faith not in tomorrow
Reply By: Member - lyndon NT - Tuesday, Jun 27, 2023 at 12:03
Inside nut
AnswerID: 643982
Follow Up By: Member - lyndon NT - Tuesday, Jun 27, 2023 at 12:07
Just found an online image. Seems the nuts come off both ends.
So it becomes just a pin.
Thought you could tap in inwards, but maybe the nipple and nut have to be removed and it taped out??
FollowupID: 923862
Reply By: Member - Racey - Tuesday, Jun 27, 2023 at 13:39
contact OME direct
AnswerID: 643983
Reply By: Member - Warren H - Tuesday, Jun 27, 2023 at 15:34
Bit hard to see in the picture, but are you sure that the nut doesn't have a tack weld on it, my camper trailer does. Looks suspiciously like one at ~8 o'clock by the pic.
NT Pajero
2007 Goldstream Crown
AnswerID: 643987
Reply By: RMD - Tuesday, Jun 27, 2023 at 19:15
Lyndon
With a nut on the inside, either welded there or just tight, the pin obviously has to be removed outward because IT MUST HAVE a shoulder on the inner end of the parallel pin. So, by simply screwing two nuts onto the outer end and using same as a locked to pin nut , the pin should be able to be unscrewed outward.. Maybe if not welded on inside the inner nut would have to be held and locked there by spanner to allow a rotary removal. Shame the leaves as re broken. Not a good advert for the supplier. Should be quite easy.
AnswerID: 643995
Reply By: Member - nickb boab - Wednesday, Jun 28, 2023 at 09:48
I would imagine you have got it sorted out by now but these bolts can get seized to the rubber bush at times and can take a fair bit bashing to remove , if you can still pump grease into them then you would imagine that they would come out fairly easy which was the case of mine about a month ago changing Springs often the grease tubes get blocked and you cannot get grease into them. .The other thing you may need to do is put a bit of upward pressure under the diff to take the pressure off the bolts and Springs .
Cheers Nick b
AnswerID: 643998
Reply By: Andrew L - Wednesday, Jun 28, 2023 at 12:59
you need to take the weight off the rubber, which is very hard to do without taking the leaf spring off the diff. Put the jack under the diff that side and lift a bit, pin comes out from grease nipple side, take nipple off first, hit or lever or jack even to break rubbers hold on leaf
AnswerID: 644001
Reply By: Terry B2 - Monday, Jul 03, 2023 at 13:37
I would imagine that you have it figured out by now, but these bolts can sometimes get seized to the rubber bush and can require a fair bit of bashing to remove.The second thing that you may need to do is provide a little amount of upward pressure under the differential in order to release some of the pressure that is being applied to the tunnel rush bolts and Springs.
AnswerID: 644035
