Kakadu Croc Problems
Submitted: Wednesday, Jun 07, 2023 at 12:04
ThreadID: 145733 Views:2060 Replies:3 FollowUps:10
Some popular pools are still closed.
https://www.abc.net.au/news/2023-06-07/opening-kakadu-sites-delay-maguk-jim-jim-twin-falls/102447490
Warrie
Reply By: Stephen L (Clare) SA - Wednesday, Jun 07, 2023 at 14:58
Sorry Warrie, the link is not working
This should Work
Smile like a Crocodile
AnswerID: 643788
Follow Up By: Nomadic Navara - Wednesday, Jun 07, 2023 at 17:25
Why can't members learn to use the link tab? Are they just too lazy. If you use the link tab your links don't break like that one.
FollowupID: 923569
Follow Up By: Stephen L (Clare) SA - Wednesday, Jun 07, 2023 at 17:58
Hi Peter
Are you referring to me or Warrie
The reason I did it like I did as when you click on work, the link is not broken and opens to the correct details.
FollowupID: 923571
Follow Up By: Nomadic Navara - Wednesday, Jun 07, 2023 at 18:48
Stephen, your link worked because you used the Link tab. I was commenting on the broken link. If members spent a little more time using the proper function their links do not break if they copy and paste the correct info into the function as you did.
FollowupID: 923572
Follow Up By: OzzieCruiser - Wednesday, Jun 07, 2023 at 19:44
But then if this forum format was not an orphan in forum world there would not be an issue. Most forums accept quite happily a cut and past of a link but this forum truncates it - so the insert link menu has to be used.
Not come across any other forum that you MUST use it and all other forums I use accept a cut and paste link.
Time to move into the 21 st Century.
FollowupID: 923573
Follow Up By: Stephen L (Clare) SA - Wednesday, Jun 07, 2023 at 19:50
Thanks Peter
FollowupID: 923574
Follow Up By: Nomadic Navara - Wednesday, Jun 07, 2023 at 22:54
Ozzie, Your experience is not my experience. I am on a few forums, they are powered by different software including XenForo, GiantMedia, ProBoards and phpBB. They all provide a feature where you can insert a link with a meaningful name and a link that does not break. They all handle short links extremely well. However, they all do not handle long URLs well at all. The phpBB software seems to break long links as frequently as does this forum
Back in the days of Usenet newsgroups the forums handled the direct insertions of URLs very well. But in those days the users file system were simpler than they all are now. The URLs have to dredge down through the hosts file system to get to the page required. The more complicated the file system is, the longer the URL is and the more tendency that it is likely to be broken. Every forum system shorten the links, otherwise we would have some links occupying several lines of text. If you use the link insertion tool, you determine the length of the link and all the URL is stored in its own container, thus it does not get broken because the forum software does not attempt to shorten anything. I think the structure of the URLs is what makes some links break.
Also, If you can provide a meaningful title for your link it is more likely to be read by readers glancing through the text.
FollowupID: 923578
Follow Up By: Batt's - Friday, Jun 09, 2023 at 08:58
It's only a link that didn't work it's not like the sky is falling and anyone can easily look things up these day unless you're to lazy. It's just a regular thing people wanting to travel to croc areas and whining about them and how they are so rudely inconvenienced by there presence in their natural environment. Leave them be and keep the people out.
FollowupID: 923597
Reply By: Member - Warrie (NSW) - Wednesday, Jun 07, 2023 at 20:35
I must be the lazy 1 with a capital L. Brickbat to Mr D for dumping like a ton of bricks and a bouquet to Ozzie C who reminded us all of the fiddleyness of adding a link on this forum. Thanks to Stephen L for saving my a$$ with his link fix. LOL
The point is that Kakadu still has all the good places shut and its June, nearly 3 months since the wet ended. I was up there in May last year and went no further east than the jumping crocs on Adelaide R. Same venues are still shut in 2023 and it's a month later, to say nothing of the Gunlom fiasco, now in it's 5th year. Some say it's Kakadon't -- I wonder why? Mick O's Rudall R adventure is far more appealing.
Warrie
AnswerID: 643796
Follow Up By: Member - Bigfish - Thursday, Jun 08, 2023 at 09:09
I agree. The sooner the bloody governments learn how to properly control the wet season weather and its associated road closures, river heights..etc.etc....the less whingers we will have.......
FollowupID: 923582
Follow Up By: Member - silkwood - Thursday, Jun 08, 2023 at 15:42
Thanks for that info, Warrie (I believe that's the correct type of response ??).
Mark
FollowupID: 923592
Reply By: Peter_n_Margaret - Thursday, Jun 08, 2023 at 17:52
We spent almost 3 weeks in Kakadu in 2021. It was not our first time there.
Kakadu is truly a world class piece of country.
It is unbelievably run down and an embarrassing mess. We should all be ashamed.
AnswerID: 643804
Follow Up By: Batt's - Friday, Jun 09, 2023 at 08:53
Only the people that let it run down should be ashamed.
FollowupID: 923596
