making a trek using snailtrail/breadcrumbs
Submitted: Monday, Apr 03, 2023 at 15:46
ThreadID: 145503 Views:1793 Replies:1 FollowUps:6
Hi, I just bought the ExplorOz package last week and I'm new to it all
I just did a short test trip today and would like to convert the bread crumbs into a trek.
How do I do that please?
ive been viewing the tutorials but cant work it out
thanks
MC
Reply By: TrevorDavid - Monday, Apr 03, 2023 at 21:39
CW
You can’t convert your bread crumbs (snail trail ) into anything, it is there to see where you have been or are wishing to back track.
But
You can go to export positions in the left hand side menu, enter start /end dates, crop it to whatever start / finish times, name it, save it, in will then be saved in track logs. It needs to be done from the device you were using for your trip as the data is automatically saved onto that device.
Members also have server tracking but that’s another story.
TrevorDavid
dontyajustluvit
AnswerID: 643250
Follow Up By: Cant wait - Monday, Apr 03, 2023 at 22:12
Thanks Trevor
FollowupID: 922881
Follow Up By: Frank P (NSW) - Tuesday, Apr 04, 2023 at 18:39
TrevorDavid is right, CW, he is an expert user of Traveller.
But you need to be aware of the difference between a Track Log and a Trek.
A Track Log is a record of where you've been AFTER you've travelled the route. You cannot use it to get navigation instructions, though at a later date you could just follow the recorded line it makes on the map.
A Trek, on the other hand, is a plan of how to get to where you want to go BEFORE you start travelling. It will give you turn by turn instructions, either spoken or in text.
With that terminology in mind, at this stage there is no method to create a Trek from a snail trail or Track Log. It would be nice if there was :-)
FollowupID: 922892
Follow Up By: Member - Cant wait - Tuesday, Apr 04, 2023 at 18:43
Turns out that i had to buy another package with the tracker
i have since made a few test treks and have played with them
Hopefully, i wont have to buy more bits to use the app fully
FollowupID: 922893
Follow Up By: Member - Kia1 - Thursday, Apr 06, 2023 at 14:02
I also wanted to save the snail trail to a Trek/log and tried zooming in and using the new ruler system to place points then saving. This gave me a track to follow either way later. I was able to then clear the snail trail.
I hope this helps.
Baz
FollowupID: 922920
Follow Up By: TrevorDavid - Thursday, Apr 06, 2023 at 20:50
Baz
Export positions does this for you, type in start & finish dates, then crop the the times. It’s all there for you. In fact if you haven’t deleted the App and then reinstalled, it will be there from yonks ago. You just have to use the same device that you used when travelling. It’s there even if you’re not using the snail trail.
TrevorDavid
dontyajustluvit
FollowupID: 922923
Follow Up By: Member - Kia1 - Friday, Apr 07, 2023 at 11:36
Thanks TrevorDavid,
I tried the export method to save the snail trail and I like it. Much easierand quicker.
Learning something new every day.
Baz
FollowupID: 922928
