H55F Gearbox/TC rebuild
Submitted: Saturday, Mar 11, 2023 at 10:02
ThreadID: 145410 Views:6008 Replies:6 FollowUps:5
Hey folks,
just been quoted 7700 to remove rebuild and reinstall my gear box in my hzj75 troopy!
I know its not a small job but this seems a little high to me!
can anyone shed any light on this or recommendations on a place in perth that would be able to do it?
cheers!
Reply By: OzzieCruiser - Saturday, Mar 11, 2023 at 12:04
A friend of mine was charged $3500 to rebuild his Troopy gearbox and transfer case BUT he had to remove and reinstal his own gearbox etc - so not the same but gives an idea of the cost of the actual job.
AnswerID: 643053
Follow Up By: Richard H29 - Saturday, Mar 11, 2023 at 12:27
Cheers mate,
Yeah that’s the rough feed back I’m getting in the gearbox which is okay,
Shop has quoted 4K as an estimate as they’re outsourcing the rebuild
But 3700 for removal installation? Most people I’ve had a response from have been about 1200-1600 for the labour
FollowupID: 922706
Reply By: Mikee5 - Saturday, Mar 11, 2023 at 17:04
Does the price include new clutch, machine flywheel, replace rear main bearing oil seal etc? A lot to consider.
AnswerID: 643054
Reply By: Member - Duncan2H - Saturday, Mar 11, 2023 at 17:40
Wow they don't want the work.. unless they make a motza on it, which they will.
Considering that brand new H55F gear boxes have recently been available out of Sydney for approx $3500 the quote is ridiculous.. even if a clutch, throwout bearing, pilot bearing and flywheel machining are included. A complete rebuild of an H55F/Transfer is generally around $3-4K parts included. You also risk them doing a very very basic rebuild and ignoring a lot of parts that may well be due for replacement.
Sorry I dont know anyone in Perth.. I would ask in some of the 70 series/Landcruiser Facebook groups.
AnswerID: 643055
Follow Up By: Gronk - Sunday, Mar 12, 2023 at 21:49
If a new gearbox can be sourced for 3.5K, why would you let some mob do a rebuild ??
Source a new clutch and find a good mechanic to throw the new box in !
FollowupID: 922711
Follow Up By: tonysmc - Monday, Mar 13, 2023 at 16:48
Hi Duncan, Just wondering what the name of the company in Sydney selling the H55F's for $3500. I only rebuilt my transfer and while my gearbox seems ok for now, it might be good to know some options for the future. I checked with Toyota a little while ago and they said they had none available. Cheers Tony
FollowupID: 922714
Follow Up By: mountainman - Monday, Mar 13, 2023 at 22:55
Toyota dealers are still selling them very sharp pricing too
FollowupID: 922715
Follow Up By: tonysmc - Tuesday, Mar 14, 2023 at 18:29
I just called Toyota today (14/03) and the guy said "Just shy of $5000" so I didn't bother getting him to email a quote.
FollowupID: 922719
Reply By: tonysmc - Monday, Mar 13, 2023 at 16:40
Hi Richard,
I just went through the process of rebuilding the transfer on my H55f a couple of months ago. While I did do all the work myself and saved a bit of money, if I had to do it again I would bite the bullet and get an exchange fully rebuilt one from either Gympie 4wd spares or 360 gearboxes. About $4700 for gearbox and transfer as one unit, but then you have to add freight for both ways for exchange only, so of course plus cost of fitting.
I looked into it quite a lot before deciding to do it myself and was going to go with 360 gearboxes. (No affiliation) I only did it myself as I enjoy doing that sort of thing.
The cost has gone up a lot lately for the H55f’s, as they are such an old gearbox, they are finding that they have to almost always replace more than just bearings. This means there is an added cost for replacing things like shafts, gears, synchro’s etc. With mine I thought it just needed a bearing kit and discovered I had to replace all the gears too, so a simple rebuild turned into virtually an entire replacement. The exchange units come with 20000 K/12 month warranty and they also put in the modified input gear which is a must. The reason I was going to go with 360 gearboxes is that they only do gearboxes and nothing else. I know you are in Perth but the companies I mentioned ship their stuff all around Australia so there’d be no problems getting it to you, you’d just need someone to install it if not doing it yourself. I would recommend getting an exchange unit as the cost is all upfront and shop around for someone to fit it. Did your quote include a new clutch as well, which may be worth doing while gearbox is out?
AnswerID: 643072
Reply By: Member - DOZER - Monday, Mar 20, 2023 at 10:44
I would consider putting a h150 behind the motor, look for an 80 series gearbox and transfer (part time) if i couldnt get a cheaper h55.
If the gearbox is ok, and you have lost drive, its most probably the transer main drive gear and the main shaft splines that have worn. You can buy aftermarket shaft with solid gear, a common issue for this transfer, which from the factory came with the option of a PTO. The new shaft negates the use of the PTO and makes the gear longer and stronger....im just theorising that is your issue, a competant mechanic could install it
AnswerID: 643097
Reply By: Richard H29 - Friday, Mar 24, 2023 at 14:18
For any of those interested!
So he misquoted the on the first quote.
Ended up coming in at $2464 in labour to remove rebuild and re- installed the GB/TC + $1607 for the rebuild kit for the box.
''Hi Richard, So the tech has stripped gearbox, t/case assy and found a few faults. Cluster shaft, input shaft, damage to 5th gear, dog, main and cluster, output gear, so price wise around what we thought. ''
Damage parts were replaced!
Asked to have an exchange box priced up from 360 and this was the response
''Hi Richard, I just spoke with 360 and there g/box, t/case $5350, plus freight around $600. Around a week to get here.''
Looks like a fairly neat and tidy job so fairly happy with what they have done, they've given a 2 year/20K warranty on the box as well.
AnswerID: 643159
