Best route to the dig tree
Submitted: Wednesday, Feb 15, 2023 at 22:34
jindivik
We are considering the best way to head to the Burke and Wills dig tree, looking at
Port Augusta to
Lyndhurst and on to
Innamincka or go in from
Longreach down to
Windorah then to
Innamincka, I will be towing a small caravan, on other sites I’m getting a lot of conflicting
information on road conditions, won’t be heading there till mid July I reckon.
Reply By: Member - McLaren3030 - Thursday, Feb 16, 2023 at 07:45
Hi Jindivick,
The condition of outback roads can change very quickly, so what it is like now will be very different to what it is like in 5 month time, so impossible to answer your question specifically.
How
well built is your small caravan? Does it have good
suspension?
I have travelled to
Innamincka from both the directions you have stated, towing an 18’ full off road 2.6 Tonne caravan. Each direction has its challenges including narrow rutted tracks, and large trucks.
You may get some better information regarding the road conditions if you contact the
Innamincka Hotel closer to your travel time.
642870
Reply By: Member - DOZER - Thursday, Feb 16, 2023 at 10:32
The best all whether road in is via
Cunnamulla-Durham, over the
bourke and wills
bridge. Your decision should include how much time you have to traverse to
Innamincka from PA, road and whether conditions, and ground clearance of van. Its beautiful country, but roads can get corregated, washed out etc. When last there the road from
Innamincka to
the dig tree was dirt and all corregated, worst road of all we were on, (old Streslecky was better)
642878
Follow Up By: Allan B (Sunshine Coast) - Monday, Feb 20, 2023 at 11:20
Yep, so the 'Black Top' has finally reached
Innamincka. Watched it crawl there over the years. The place will be full of Winnebagos now!!!
The bitumen is also processing along the Strzelecki. Much of it is sealed. The Old Strzelecki section is untouched of course but may not be good for some caravans.
922483
Reply By: Member - Wooly - Sunday, Feb 19, 2023 at 22:10
A lot can change in the time frame you are looking at but I was at
the dig tree 3 days ago and the road in was a reasonable gravel road, you would have had no troubles on it towing at 40 - 50 KPH
Strezleki is good, plenty of tar being applied, won't be long and it will be sealed all the way. (a year or 2?)
The old Strez between Merty Merty and the Moomba road would be ok even with an off road van right now. Not sure what it will be like by the time you get there.
The top of the old Strez which is in the regional reserve would be problematic for towing however, so probably best avoided.
642904
