Understanding Tow Ball Weight
Submitted: Sunday, Feb 05, 2023 at 20:08
ThreadID: 145304 Views:6455 Replies:10 FollowUps:6
Our car has a towing capacity of 2500kg and a ball weight of 150kg.
When looking at caravan options I can find a few where the tare + load are within specs however all appear to exceed the max ball weight. In fact I cannot find anything that has a ball weight of 150kg or less.
I was looking at the following however it has a ball weight of 243kg
Am I missing something?
Reply By: Gronk - Sunday, Feb 05, 2023 at 21:26
You’re not missing anything, but a car or 4wd that has a 2500kg capacity and only 150kg ball weight is not really designed to tow 2500kg !!
No matter what the manufacturer says, if it really had the capacity to tow 2500kg, it really should have a ball weight of 250kg.
Generally, approx 10% of van weight is engineered into a van for ball weight.
AnswerID: 642799
Reply By: Member - Mark (Tamworth NSW) - Sunday, Feb 05, 2023 at 21:43
I speculate that if the van has a ball weight of 243kg that would probably mean the van has a tare weight around 2400kg.
A tare weight means absolutely bare bones, no water in the tanks, empty gas bottles, no linen, clothes/luggage food or water. You can add at least 200kg if not closer to 400kg for those items when packing for a 2 weeks trip which means you are likely to exceed your vehicles towing capacity.
I've done silly things in ignorance in my younger years and got away with it exceeding my vehicles Gross Combined Mass (van + vehicle), but if I had an accident my insurer would not have covered me.
Some say the sensible towing capacity is 80% of the stated towing capacity, especially if towing on rough/dirt roads.
Best of luck.
AnswerID: 642800
Reply By: Member - Phil 'n Jill (WA) - Sunday, Feb 05, 2023 at 23:54
From memory my first tow vehicle - a 2004 Pajero - had the specs in the handbook showing a 150 kg towball limit on a standard tow hitch which put the wind up me until I found a plate on the hitch showing it was a weight distribution hitch which was legal for 250 kg. ( I bought it second hand in 2007).
Might pay to check your handbook specs. Good luck.
Regards - Phil
AnswerID: 642801
Reply By: Phil G - Monday, Feb 06, 2023 at 08:50
Not good to only be allowed 150kg on the ball and my concern is that your vehicle and caravan will be an unstable combination. 150kg is what you find on most camper trailers.
Ball weight is a variable though and actual ball weight depends on water tanks and how you load the caravan. It usually gets heavier. My 2.5T caravan had 140kg at tare and is 180-240kg when loaded. A mate's 2.5T van has 208kg on the plate and is 300kg when loaded.
AnswerID: 642803
Follow Up By: Member - Bigfish - Monday, Feb 06, 2023 at 15:49
Vast majority of even 2 tonne forward fold campers have a ball weight well in excess of 220kg..
FollowupID: 922411
Reply By: Peter_n_Margaret - Monday, Feb 06, 2023 at 15:17
You need a dog trailer style.
AnswerID: 642805
Reply By: Member - nickb aka"boab" - Monday, Feb 06, 2023 at 16:09
First of all you need to know the full weight of your tow vehicle ..fully loaded full tanks people gear then you need to know all this jargon
below I have been using Jackson's 4 x 4 tow vehicle calculator for the weights
My guess would be that you would only be able to tow a camp trailer or light caravan legally
AnswerID: 642806
Reply By: Member - Andrew - Monday, Feb 06, 2023 at 16:57
The 10% of the trailer weight is a convention in Australia apparently followed by most trailer manufacturers, and appears to have been derived initially from American practice.
European vehicles guidelines are usually based on 5%, so my VW has a 2000kg tow limit with a 100kg ball weight.
The European trailer industry seems to therefore build around these lower ball limits despite their higher road speeds.
The arguments around ball weights concerns a lot of anecdotal experiences with trailer stability.
The problem as I see it is that most of our stuff is built big and heavy instead of smart ,strong and stable.
Trailers move in three dimensions so height and shape, ie roll centres, centre of gravity, suspension type and aerodynamics all play a part in stability, not just the two dimensional aspect of ball and trailer weight.
With some vehicles you may get away with exceeding your ball weight, however that brings in other factors such as .
Stressing the structure of the rear of your vehicle.
Overloading your tyres
Overloading your rear axle and or wheel bearings.
Interfering with the actions of stability controls, ABS and traction controls.
Causing your bum to drag.
You may also find that trying to compensate by adding load levellers is not recommended by European manufacturers due to the stresses that places on the rear floor pan via the towbar.
So what is the answer? Well if we push trailer (caravans, campers etc) to build smarter not heavier, then we would have greater choice without having to change to heavier tow vehicles.
A
AnswerID: 642808
Follow Up By: Member - nickb aka"boab" - Monday, Feb 06, 2023 at 20:46
They have to be built strong & heavy to carry all the crap the people want in them on there travels
FollowupID: 922416
Reply By: Member - Jim S1 - Monday, Feb 06, 2023 at 17:51
Hi Andrew
An interesting observation.
I'm guessing that European roads are generally a lot better than Australian roads. Can't remember driving on a gravel road in Europe ........ many years ago.
Given our huge distances, and many poor /rough surfaces, corrugations, washouts etc that Aussie trailers very often have to deal with, I would guess that obvious thing to would be to build stronger and necessarily heavier.
Just an uneducated guess about the difference.
Jim
"Sometimes I sits and thinks, and sometimes I just sits." A fisherman.
"No road is long with good company." Traditional
AnswerID: 642809
Follow Up By: Peter_n_Margaret - Monday, Feb 06, 2023 at 18:07
Stronger does not require heavier, it requires more appropriate material and design selection.
FollowupID: 922413
Follow Up By: Member - Jim S1 - Monday, Feb 06, 2023 at 18:13
I agree Peter, but often light but strong is also more costly. Carbon fibre boats are light and strong .......... but cost an arm and a leg or two. And a bit brittle.
Tricky getting the cost v strength bit just right.
Jim
FollowupID: 922414
Follow Up By: Member - Bigfish - Tuesday, Feb 07, 2023 at 14:49
People don't need the bloody great Mcmansion towed behind a vehicle at its absolute limit. Most wouldnt have a clue about their vehicles weight. Ignorance is bliss for many. People need to get rid of their egos and settle for smaller vans without all the bullshite extras.
FollowupID: 922418
Reply By: Allan B (Sunshine Coast) - Tuesday, Feb 07, 2023 at 09:57
When I read of all the confusion/ignorance/disregard of the factors about towing it scares the hell out of me when I get anywhere near these rigs on the road at Vr (rotation speed).
AnswerID: 642811
Follow Up By: Member - McLaren3030 - Wednesday, Feb 08, 2023 at 07:34
Totally agree Allan. On my trip from Melbourne to Cape Leveque last year, came across a “convoy” of three large vans travelling up the Stuart Highway. All large dual axle, 20+’ long travelling close together. They all had WDH’s, but where still heavy on the ball judging by the way they the cars were “bum down” and “head up”. And not a UHF radio between them. Doing 85 to 90 kph without much of a gap in between each van. I was fortunate enough to be able to pass them on a long straight section, but the trucks behind me were absolutely not going to get past for several kms.
No idea how to travel in convoy, and oblivious to other road users.
FollowupID: 922422
Reply By: Batt's - Thursday, Feb 09, 2023 at 12:13
I was looking a few yrs ago at the weight of on road vans and they have gotten very heavy these days especially with all the extras people want in them. I found Jergens vans to be lighter than most.
AnswerID: 642821
