Desert travel
Submitted: Thursday, Dec 29, 2022 at 19:50
ThreadID: 145165 Views:5441 Replies:10 FollowUps:12
I'm purchasing a new dmax ute and I want to travel through the desert areas.. thoughts on set up (ie) swag, tent, slide on campers thoughts and suggestions please from those of you who have been fortunate enough to have had the experience
Reply By: qldcamper - Thursday, Dec 29, 2022 at 19:54
Travelling alone?
With your partner?
With another vehicle?
How remote do you want to get?
AnswerID: 642411
Follow Up By: Craig S20 - Thursday, Dec 29, 2022 at 20:37
With my wife, by ourselves,traverse Simpson desert
FollowupID: 921965
Reply By: Member - Jim S1 - Thursday, Dec 29, 2022 at 20:45
Hi Craig
A good start would be to check out the TREKS section of this website. eg
https://www.exploroz.com/treks/simpson-desert?s=Simpson
Plenty of excellent info and advice there.
Jim
"Sometimes I sits and thinks, and sometimes I just sits." A fisherman.
"No road is long with good company." Traditional
AnswerID: 642412
Reply By: Member - Wooly - Thursday, Dec 29, 2022 at 21:31
Hi Craig,
If you are comfortable with a swag or tent, then try that?
I think that the lighter you are, the easier the going will be.
Don't forget the fridge and the beers/wine
AnswerID: 642414
Follow Up By: Member - rocco2010 - Thursday, Dec 29, 2022 at 21:51
Good tip.
I started off travelling light because I couldn’t afford much.
Ute, swag and a fridge.
I’m still doing it pretty much the same way.
Good luck with the planning. It’s half the fun.
FollowupID: 921966
Reply By: Peter_n_Margaret - Thursday, Dec 29, 2022 at 22:42
Best advise is to get out there with whatever you have.
A couple of trips will soon sort what suits you and your partner, how you travel, your expectations and your budget.
We are all different. In the first instance, if you are not sure about something, leave it home. If you did not need it on the first trip, leave it home on the second trip.
Take a few shorter trips first, gradually becoming more adventurous. Probably not a good idea to start with the Simpson.
AnswerID: 642415
Reply By: Gbc.. - Friday, Dec 30, 2022 at 06:53
For a touring Ute do yourself a favour and order a dropside and a proper aluminium canopy. Tubs and fibreglass style canopies are an awful compromise.
For 2 people I’d also take the single/extra cab over the twin cab also for a much better layout and distribution of weight.
AnswerID: 642416
Follow Up By: Craig S20 - Friday, Dec 30, 2022 at 09:04
Thanks for your help I'm purchasing a single cab and I would like a canopy
FollowupID: 921967
Follow Up By: Gbc.. - Friday, Dec 30, 2022 at 09:38
Nice. For me I’d just put a lift off canopy on and head off. The Simpson doesn’t require a huge amount of prep work, you’d want to upgrade the tyres and throw a couple of jerry cans of fuel in. I use a swag on a stretcher but if I was doing a longer tour a roof top tent would be on the list. Don’t discount the Mazda version same car, nicer (subjective) fitout in the lower grades. I have the new XT twin cab. Nearly 2 years old now, very happy with it.
FollowupID: 921968
Reply By: Member - McLaren3030 - Friday, Dec 30, 2022 at 09:29
Hi Craig,
From your responses, I would suggest a single cab/chassis, or (extra cab) then put a solid alloy canopy on the chassis. You could have a canopy purpose built with a fridge and draws etc built in, or just an empty canopy and fit it out yourself.
I would also humbly suggest 100 amp LiFePo4 battery and 200 watts of solar capacity (or even 200 amp LiFePo4 batteries, 400 watts of solar capacity) with appropriate charger. You can then run a decent fridge, 60 or 80 Ltr.
An OzTent is easy to put up and down, but are heavy to carry around. Swags are good if you don’t mind sleeping on the ground, or you can get a swag/tent/camp bed combination. You could also try a Rooftop Tent, but at my age, I find them a PITA as I need to get up in the night for a leak. Also, they restrict where you can mount solar panels if mounting the panels on the roof.
On my last fishing trip from Melbourne to Broome, I used an ARB Dome Swag for overnight stops, and an OzTent RV4 and camp bed for the month I was at Middle Lagoon.
I have crossed the Simpson twice, first time I used the OzTent, second time the Swag. For me, the Swag was less work, and what I would use again.
AnswerID: 642421
Reply By: Bushranger1 - Friday, Dec 30, 2022 at 09:55
Hi Craig,
Just 2 of us & we have a 4wd DMax & Slide on camper having owned it for 4 yrs. Had a camper trailer prior & our needs changed.
Just the 2 of us so the single cab gives more room in the Slideon.
We travel remote & it suits us fine. . We don't sit in one spot for long but if you do bear in mind it has to be packed to go on day trips. If we feel the need to leave camp for the day we just leave a couple of hike chairs in our spot for our return.
To be honest that rarely happens as we usually find nice spots anywhere for the night as if you can park the car you can sleep in the camper. No need for flat cleared spots for tents.
Bear in mind the cost of suspension upgrade & carefully calculate all the weights. Best to put the rig on a weighbridge packed for trip with passengers so you keep below GVM.
There is no "best" set up just what suits your style of camping.
Stu
AnswerID: 642423
Follow Up By: Craig S20 - Friday, Dec 30, 2022 at 12:27
Thanks stu I have looked at slide on campers just trying to get some information on one atm sounds like a good option for long distance travel
FollowupID: 921971
Follow Up By: AlbyNSW - Friday, Dec 30, 2022 at 18:09
Whilst there is nothing wrong with a slide on camper I would highly recommend not investing in anything like this or a camper trailer until you have spent some time camping to understand what works for you.
Start with some basic gear and just get out there and do it or hire something in the first instance. By all means once you know what you want get advice from those with similar setups but until then it is like asking a stranger what you would like to eat for dinner.
FollowupID: 921982
Follow Up By: Bob Y. - Qld - Friday, Dec 30, 2022 at 20:12
Further to Alby’s advice, these are a few photos of the evolution of my desert vehicle.
Being a “bower bird”, I don’t practice minimalist!
FollowupID: 921984
Reply By: Member - Outback Gazz - Saturday, Dec 31, 2022 at 11:01
G'day Craig
A lot depends on your experience with camping, your budget and whether you prefer glamping or roughing it.
I agree with most who have replied that keeping it light and simple is the way to go but that can vary on where and how long your trips last. Full alloy canopies are great but I wouldn't be decking one out until you have had a few remote trips under your belt as I constantly hear from friends and other travellers with them that after a few trips they would all change their original setup to make it better.
I have different setups for different trips - both my vehicles have a 2.5 metre awning attached to the roof rack and like in Bob Y's pics I have an Oztent RV5 which is 2.4 metres wide so I can join the two awnings together for more shelter. On longer trips I take the Oztent side and front panels to create an annexe. The oztents are good but a bit cumbersome and take up space in a canopy so I have to lift them up onto the roof rack. I also have an oztrail10 tourer tent, pole in the middle type but the awning is basically useless but a quick easy tent to setup and measures roughly 1 metre x 1 metre x 200mm packed up.
I also have a 2.5 metre x 2.5 metre awning tent that attaches to the 2.5 awning creating a good size room but as yet I haven't set it up - it's light, takes up little space and it's there in case of bad weather. A few friends have and use these and praise them highly - they are not expensive either, depending on brand.
For ten years I ran a 4wd tour company specializing in the Simpson Desert and have only ever thrown my swag on the ground but a few years ago I upgraded to throwing my swag on a stretcher - best thing I've done in years re camping. Swags and stretchers can take up a fair bit of space but I think the ease of setting up a stretcher and just rolling a swag on it to have your bed ready in 2 minutes is worth it.
Here's a tip for you Craig - make sure you have a good bed/sleeping setup for your wife - because experience tells me that when most women wake up cranky after a lousy nights sleep they tend to be cranky all day :)
Most people I know reckon their roof top tents can be a pain in the r'zz - especially those who have injured themselves falling down.
Slide on campers - expensive but the people I know who have them swear by them - one couple in particular have been travelling around Australia for the last two years in theirs and they love it.
And as Macca suggested a good solar panel and battery setup is a must in this country as is a decent 12 volt fridge !
Another tip - the best thing you can take with you is a relaxed, care free nothing is a problem attitude !
Good luck with whatever you decide on and enjoy your travels
Gazz
AnswerID: 642440
Follow Up By: Allan B (Sunshine Coast) - Saturday, Dec 31, 2022 at 14:43
No Gazz, the best thing you can take with you is a relaxed, care free nothing is a problem WIFE. lol
FollowupID: 921988
Follow Up By: Member - Outback Gazz - Saturday, Dec 31, 2022 at 15:16
Howdy Allan
I'm sure I have posted before about my wife's idea of roughing it - her idea of roughing it is a motel with no room service and no day spa !
She very very rarely travels bush these days with me ( no insert smiley face available lol ) so most of my bush trips are with good friends and their good wives who enjoy 4wdriving and camping.
" the best thing you can take with you is a relaxed, care free nothing is a problem WIFE "
Nothing sexist here Allan - it's just that over the years I have seen many people stress out and work themselves up when things go wrong or don't turn out as expected when they have no control over the situation and then they often make poor decisions on what's best to do next.
I have a couple bush trips coming up in 2023 and the wife has organized an overseas holiday involving motels with room service and day spas - she doesn't complain about me going bush so I can't/don't complain when we go o/s to fancy motels ( no insert rolling eyes smiley face available lol )
Take care mate and have a good 2023 !
Gazz
FollowupID: 921992
Follow Up By: Allan B (Sunshine Coast) - Saturday, Dec 31, 2022 at 22:52
It was a joke Gaz!
FollowupID: 921999
Follow Up By: Member - Outback Gazz - Sunday, Jan 01, 2023 at 09:22
Howdy Allan and welcome to 2023
Yes I knew that - as after reading all your replies to everyone on here over the years I know you have a sense of humour !
I was just covering my backside so as to not get bombarded with replies from the overly woke and easily offended brigade on here that get offended at the unoffensive and lack a sense of humour !
Gazz
FollowupID: 922001
Reply By: Michael H9 - Sunday, Jan 01, 2023 at 09:44
From my experience, it should be whatever your wife can handle. A few short exploratory trips where there are other campers will let you gauge what takes her fancy. Going cold turkey into the desert isn't a great idea, some people think it's horrible.
AnswerID: 642447
Follow Up By: Richard M29 - Tuesday, Jan 03, 2023 at 17:06
My wife will follow me anywhere, so long as she has a stretcher bed. She has always camped in tents campertrailers, etc, but since a knee op, needs a bed off the ground now.
FollowupID: 922045
Reply By: Idler Chris - Wednesday, Jan 11, 2023 at 16:39
Some good advice here. Start with minimum and grow from there. Swags are a great start and so versatile. The camping stores away from the main cities are usually better anyway. D-Max is a great choice very reliable. Pay attention to the fuel you buy. Look for high volume sellers and name brand fuel. (BP, Shell, Ampol etc). You will have sometimes no choice and in such circumstances have a glass jar which you can squirt a bit of fuel every say, 20 litres, to see if it looks ok. I would also get a set of good quality (high load rating) wheels and mud tyres. This gives you two sets of tyres. Mud tyres maybe noisier, maybe not last as long, but when you are out there and things turn to sh*t you will be very glad to have them. Additionally, they are much stronger and less prone to being punchered. I have run alloy rims with heavy mud tyres for the last 8 years on my overweight D-Max for over 220k kilometres and never once have I had to change a wheel because of a puncture. I have had 4 punctures which were easily plugged. A must have is a PLB and if you find yourself in remote locations by yourself you need to weigh up the cost of a sat phone verses your personal safety. A gps navigation system not dependent on mobile coverage is also essential if you are travelling in remote areas. What you need is like asking how long is a piece of string. If you want to know more ring me on 0419846292 and I will try and help. Cheers, Chris
AnswerID: 642584
