Adding portable solar to existing fixed solar.
Submitted: Saturday, Dec 17, 2022 at 18:40
Member - Outback Gazz
G'day All
I have a 110 watt fixed panel running through a redarc 1225d on my camper trailer.
I also have a 120 watt folding blanket with its own regulator I would like to add on occasions.
Is it best to connect the folding blanket direct to the battery through its own regulator to avoid any issues with the other panel and redarc or is it possible to run them both through the redarc without issue ?
Gazz
Reply By: qldcamper - Monday, Dec 19, 2022 at 07:27
Just use 2 controllers and get them in the sun, dont bother trying to achieve theoretical perfection as that is impossible.
When batteries are low or load is high both controllers will go their hardest and when the battery voltage comes up the 2 controllers will switch through their different stages at different times and have an affect on each other but at that stage it doesnt matter as the battery is nearing full, or full enough to last till morning.
I have two seperate systems, the car and the camper, each with their own battery, controller and panel, fridge is in the car.
If the car battery gets low I just link the two together with my 10 metre 6mm(automotive) extention which many here refuse to accept actually works, and let the electrons flow where ever they want. The law of physics sorts that out for me. Both systems charge but the redarc in the car goes into float before the victron in the trailer.
As yet havent run out of power for either the fridge or electric blankets but both of those never get pushed hard at the same time but works for me.
By the way, batteries are an 80ah AGM in the trailer and a 100ah AGM in the car and I consider low to be 11.5 volts while the compressor is running.
642354
Reply By: Member - Andrew C11 - Monday, Dec 26, 2022 at 20:15
Gazz,
The simplest way is to add an additional MPPT controller, the best are Victron. If you also get the smart controller then you can also Bluetooth to them for data and upgrades, you can also setup a network between them to balance charging needs.
I have two setup like this, one for the permanent panel and one for the external. This way you can get maximum charging from both panels, and if one is in the shade the other will still work correctly (the network allows them to control the charge rate, so if the battery is full they'll start to shutdown).
I'd recommend for a simple setup the 75/15, it'll take up to 260watts, this should be plenty for most requirements.
Not sure if I'm supposed to to recommend, websites but I've brought lots of gear from Outbackmarine. They are a good source of gear and information.
Victron COntrollers
Andy
642400
Follow Up By: Member - Outback Gazz - Wednesday, Dec 28, 2022 at 09:50
Thanks Andrew for the reply
Sounds good but as I mentioned I would only use the solar blanket on the odd occasion so the simplicity of a double anderson on the redarc suits my KISS philosophy !
Last
camp I did with mates who run set ups with bluetooth connectivity spent half the time on their stupid effin phone monitoring their batteries and panel output - which annoys the crap out of me !!
The way I
check my battery level is to get a beer out of the fridge and if it's cold the battery is still good and after 2-3 days I grab a beer out of the fridge and it's not cold then I know the battery needs charging.
Thanks again
Cheers and cold beers
Gazz
921955
