Help!! F250 2006 7.3 litre Engine light no power
Submitted: Sunday, Oct 23, 2022 at 14:50
ThreadID: 144976 Views:4332 Replies:4 FollowUps:8
Just wondering if anyone has any ideas as to why our F250 continues to stutter and is running rough with little power. We have broken down on the M1 near Mooney Mooney
We have just replaced the cam sensor and still no go
Would appreciate any advice
Thank you
Shaun and Suzy
Reply By: Member - McLaren3030 - Monday, Oct 24, 2022 at 08:02
Hi Shaun,
Not being very familiar with the F250, but is it Petrol or Diesel? If Petrol, what grade of petrol are you using, 91 RON, 95 RON, 98 RON, or Ethanol blend?
AnswerID: 641902
Follow Up By: Shaun L - Monday, Oct 24, 2022 at 08:19
Thanks for your help Macca.
We have a diesel 7.3 litre.
Shaun
FollowupID: 921305
Follow Up By: Member - McLaren3030 - Tuesday, Oct 25, 2022 at 08:24
Shaun,
The problem as you describe it sounds suspiciously like a fuel related problem. First thing I would check is your fuel filter for either water or dirt.Check for possible loose connections where you could be getting an air leak. Then moving on to the injectors. Where did you fill your tank last prior to this problem occurring?
As age as a good Diesel Mechanic around Sydney, I would be calling Berima Diesel.
FollowupID: 921319
Follow Up By: Shaun L - Monday, Oct 31, 2022 at 21:54
Hi Macca,
The main issue was the power that goes to the injectors runs to a plug on the outside of the rocker cover.On the inside of the cover is another plug that had come loose hence no power to the injectors and once I had reconnected the plug it enabled the truck to fire up.
Thanks again for your help
Shaun
FollowupID: 921393
Follow Up By: Member - McLaren3030 - Tuesday, Nov 01, 2022 at 08:15
Hi Shaun,
Thanks for the update, it is nice to know how people resolve these issues when they post and ask for assistance. Some people do not always post what the resolution was.
FollowupID: 921394
Reply By: Member - Lloyd M - Monday, Oct 24, 2022 at 08:39
If there is nothing obviously wrong you will have to read the codes from the computer and go from there.
Lloyd Mac
AnswerID: 641903
Follow Up By: Shaun L - Monday, Oct 24, 2022 at 09:56
Thanks Lloyd,
The codes came up were P1316 and P0603
Just wondering if you know of any good diesel mechanics in Sydney?
FollowupID: 921306
Reply By: Rangiephil - Monday, Oct 24, 2022 at 10:43
Did you read this?
Link to Motoraudit article.
EDIT: Incomplete link fixed by ModSquad
AnswerID: 641904
Follow Up By: Member - Cuppa - Thursday, Oct 27, 2022 at 11:42
Also this from the same source.
Article for Code P0603
What a nightmare! One code potentially interacting with another, with complexities of including codes not available.
Could still be bad fuel.
Lucky you are not in a remote area.
Good luck with getting it sorted.
See 'My Profile' (below) for link to our Aussie travel blog, now in it's 6th year.
Classifieds: 4x4 Tow hitch receiver recovery point 4.7T, Bow Shackles 8.5t 1", Heavy duty Sherpa Winch Hook, Soft Shackle 9000kg, 12000kg Snatch Strap
FollowupID: 921339
Follow Up By: Shaun L - Friday, Oct 28, 2022 at 17:04
Hi Rangiephil,
Just want to say thank you so much for sending through the link on the codes.
It was invaluable information that helped get the truck going again.
We are truly grateful
Suzy and Shaun
FollowupID: 921348
Reply By: Shaun L - Friday, Oct 28, 2022 at 17:10
Hi Everyone,
We just want to say a big thank you to everyone who replied to the issue with our F250
We have managed to get the truck going again
The problem was solved with the link that Rangiephil sent to us as well as all your suggestions.
Thanks once again
Suzy and Shaun
AnswerID: 641935
Follow Up By: Member - McLaren3030 - Saturday, Oct 29, 2022 at 07:54
Hi Shaun,
Curious to know what the actual issue was.
FollowupID: 921349
