Toyota 79 series fuel tank breather
Submitted: Friday, Sep 09, 2022 at 12:11
ThreadID: 144778 Views:9723 Replies:3 FollowUps:1
Been having a issue with gurgling sound when removing fuel cap, either one, on my 2011 79 series ute. The breather is in the fuel cap. Both were full of dirt. The photo with the 2 drills shows the holes that were clogged. I think a better long term fix would be to tap into the line that connects the 2 tanks and run a separate breather hose.
Back Expand Un-Read 1
Reply By: Member -Pinko (NSW) - Friday, Sep 09, 2022 at 16:08
Hi Kevin
I bought a new cab / chassis in 2007 it has gurgled since new when the cap is removed.
AnswerID: 641612
Follow Up By: Bob Y. - Qld - Saturday, Sep 10, 2022 at 13:04
I can’t remember any Landcruisers that didn’t gurgle when removing the fuel cap, at some stage of their lives. Have also read lately of blokes fuel tanks being sucked in, due to blocked breathers, though I feel this may only have occurred with the later 130L tanks, on both single & dual cab models?
During the ‘70’s, some more senior gentlemen than I, and more experienced too, were often concerned about another valve/breather that is hidden away above the main tank. This little gizmo vented into the chassis, and was often blocked by mud in the chassis or broke away and filled with, mud, dust or wasp nests. Don’t recall if any tanks imploded but do recall these senior gents were more concerned about poor performance from the early asthmatic, Toyota diesel engines.
Have added a couple of images of this hidden valve for those unaware of it’s presence.
FollowupID: 920855
Reply By: Member - Markthemilko (WA) - Tuesday, Sep 20, 2022 at 23:33
Yep, quite normal. I have a 2007 79series ute V8, with two standard 90 lt tanks and it gurgles when removing the cap and always has.
Happy 4WDriving
Mark
VKS 737 mobile 0401
AnswerID: 641689
Reply By: @Yackandandah - Tuesday, Sep 27, 2022 at 21:04
I have done approximately 3k since I have cleaned the breathers in the fuel caps & have had no “gurgling” when removing either fuel cap.
Kevin
AnswerID: 641742
