Hilux Ln106 leafs
Submitted: Friday, Sep 02, 2022 at 17:15
ThreadID: 144738 Views:4040 Replies:4 FollowUps:5
G'day everyone.
I'm looking at replacing some sad looking front leafs on a '93 ln106 diesel and just want to see if anyone's done it before and got recommendations for brands. Looking for a 2" lift to match the old ones.
Reply By: qldcamper - Friday, Sep 02, 2022 at 17:17
Ever thought about getting your existing springs reset?
AnswerID: 641568
Follow Up By: Nate B - Saturday, Sep 03, 2022 at 09:19
I think the ones on here are too far gone, they're basically upside down after a few weeks on corrugation. Might be an idea if I can't find parts though ??
FollowupID: 920813
Follow Up By: OzzieCruiser - Sunday, Sep 04, 2022 at 17:42
Reset springs normally loose their reset after an short period, particularly if worked hard.
FollowupID: 920820
Reply By: Bob Y. - Qld - Friday, Sep 02, 2022 at 18:13
We had an ‘82 dual cab Hilux & after a year or two, put a set of Lovells under it. The transformation was amazing, rode well with plenty of clearance. Don’t recall what shockies I used, but may have been Monroes?
AnswerID: 641569
Cheers mate I'll suss these out
FollowupID: 920814
Reply By: Batt's - Friday, Sep 02, 2022 at 19:45
You might be able to fit coil springs for a better ride
AnswerID: 641570
Reply By: Peter J4 - Sunday, Sep 04, 2022 at 06:45
The front springs on the earlier Hilux's often went reverse camber, toyota leaves never broke though just sagged.
You may find it cheaper in the long run to buy a replacementsuspension kit on , I fitted a full kit for a later model Hilux with IFS including all new fastenings , U bolts, shocks and bushes etc which was just a bolt on job for around $1300 including shocks and bushes. It was on ebay and I rang and discussed the normal loading with the seller and he suggested a lighter pack than what was on offer, sorted it all out and it turned up a few days later.
It's now been fitted for a couple of years and hasn't sagged and still rides well.
AnswerID: 641573
Follow Up By: Nate B - Sunday, Sep 04, 2022 at 10:10
Thanks mate sounds like a good option. I didn't think they would be snapping any time soon but it's riding low enough to hammer on my steering on the bumps. Will look for an upgrade that'll last :)
FollowupID: 920818
Follow Up By: Peter J4 - Sunday, Sep 04, 2022 at 10:16
Even cheaper now see item 253180570188 on ebay.
As I said the kit I used had greasable shackles and wasn't much more but it was leaves at the rear and struts with coils at the front.
FollowupID: 920819
