ExplorOz Traveller on Windows Laptop/Notebook
Submitted: Thursday, Sep 01, 2022 at 16:23
ThreadID: 144723 Views:4436 Replies:3 FollowUps:1
Hi All,
I note that you can purchase ExplorOz Traveller on the Microsoft Store ( https://apps.microsoft.com/store/detail/exploroz-traveller/9NLSKRVT676L?hl=en-hk&gl=hk ).
In the notes on the app it stated you can run it on a windows laptop ..
An external GPS is required to show your position on the map as you travel when offline.
If you connect a serial or USB connector to add a GPS to your device for use in this app you will also need to install a GPS sensor driver (we recommend GPSComplete available from https://www.turboirc.com/gps7/). You can download and run this product in evaluation mode. Just follow the program prompts. TIP: Ensure you use your Windows Device Manager first to determine which COM Port your GPS is plugged into. This is required for the setup the GPS Complete program accurately.
Has anyone got Traveller installed on a laptop with external GPS connected. If so, does it operate OK?
Neil
Roadrunna
Reply By: TrevorDavid - Friday, Sep 02, 2022 at 06:24
Neil
A while back I used a Sony Vaio with a GPS via usb, worked fine. Now a iPad Air 4th Gen with internal GPS.
TrevorDavid
dontyajustluvit
AnswerID: 641564
Reply By: Member - 2208mate - Friday, Sep 02, 2022 at 11:36
Yes it works fine on my W10/11 machines.
The sensor I got off ebay and was model BU-353S4 the brand name is G-STAR IV
AnswerID: 641565
Reply By: Stephen L (Clare) SA - Friday, Sep 02, 2022 at 13:01
To save having cables in your vehicle, just use a Bluetooth GPS Receiver, problem solved
Smile like a Crocodile
AnswerID: 641567
Follow Up By: TrevorDavid - Saturday, Sep 03, 2022 at 09:14
Yep, it’s what I would do if I went down that path again.
TrevorDavid
dontyajustluvit
FollowupID: 920812
