Need a new wheel rim 145 r10 - 74N
Submitted: Sunday, Jul 24, 2022 at 17:09
Richard M29
It is to suit my on road NZ built Campomatic Campertrailer. It is a 4 stud pattern, 100mm apart, with a 50mm hub center. My original wheels are magnesium, but the wheel I want to replace is steel( rusted out near valve). I could have either a mag, steel or gal. wheel . Anyone know where I could get one?, Online is only showing up in NZ and Europe, very expensive to buy and deliver from there. Multi Fit wheels wont fit.
Reply By: OzzieCruiser - Sunday, Jul 24, 2022 at 18:05
They should be the same as Morris Mini 10" rims - same PCD not sure about hub diameter.
See Gumtree
HEREMINIMOKE WORLD
641239
Reply By: Richard M29 - Sunday, Jul 24, 2022 at 20:37
Ozzie Cruiser, they are virtually the same, but a much larger hub center on the mini, only gives me 30mm, between the hub center hole on the wheel to the out side of the wheel hub. I have gone all over the mini wheels, I could probably adapt one, as the spare currently, has had the hub center, already cut out on it to make it 60mm. I have also decided to replace all of them with steel, as the two wheels being used are magnesium, and quite old by now, and the do have nicks/chips due to gutter running by previous owner, so that could cause me issues down the track. Normally I wouldn't hang on to a camper, this old but, it is in very good condition, has been garaged all it's life, and the original 22 oz canvas and zips, are as new, as the previous owner, had only used it for a year and a half then garaged it until I bought it. It is a
barn find.
641242
Reply By: Member - Outback Gazz - Sunday, Jul 24, 2022 at 21:22
G'day Richard
You could try here
https://www.facebook.com/groups/171347500118800/
Gazz
641243
Follow Up By: Richard M29 - Sunday, Jul 24, 2022 at 23:26
Thanks just spent a lot of time viewing there, as not a member of facebook, eventually they shut me out. But did find someone to talk too, will get my wife to join, so I can contact them hopefully. It is another wheel in the cog, so may be helpful.
920308
Reply By: Michael ( Moss Vale NSW) - Monday, Jul 25, 2022 at 06:59
I just google Car wheel PCD and car wheel fitments and lots of lists came up. Seems a lot are very comprehensive, look for cars that are available in Australia and you should be able to find something suitable. You may have to buy a pair to to get the same rim width. Michael
| Patrol 4.2TDi 2003
Somewhere you want to explore ? There is no time like the present.Member My Profile My Blog Send Message |
641246
Follow Up By: Richard M29 - Monday, Jul 25, 2022 at 13:13
Had a return phone call this morning, looks like I have found some, just need to send a
pic of the wheel to the mini parts supplier, $120 each, not really cheap, but cheaper then the others. He will do a return for $45 return freight , if they are not, but they are 74N's so they would fit. I could get some cheaper then that on gumtree, but risky going that way Thankyou all.
920309
