Kimberly Camper Limited
Submitted: Monday, Jun 13, 2022 at 09:40
ThreadID: 143858 Views:5162 Replies:6 FollowUps:12
Just bought a 2010 KK limited edition.
On the top of the electrical panel in the gullwing is a 10 breaker circled in yellow?.
dont look at the finger..i pinched pic from web...use the yellow circle.
The wiring diagram in the book does not show the 10amp breaker. Anyone know what its for?
The electrical diagram leaves a lot to be desired. Some of the switch names in manual do not match what has been marked on panel either.
Anyone modded the panel to do away with the pop rivets. To be able to get inside the panel one will need to drill out all rivets and remove entire box to be able to get access to some rivets that are otherwise obstructed by camper panels. It will be a pain if you needed to add a circuit or check.
Any one re-drawn the electrical diagram?
