External Water pump - Joocla V2 Hotap
Submitted: Tuesday, Apr 26, 2022 at 09:33
Kris K
Hi All,
We love this Joocla, having hot showers anywhere is fantastic. I've been using a Milwakuee Transfer pump to pump water from near by lakes/streams into a 100Litre tub I sit under my van and we draw from this into the Joocla but setting up the Joocla pump is a PITA
I want to mount an external water pump under the van, permanently wired into the van power with some external water fittings.
Can anyone recommend a good 12V water pump that can be fitted under the van (and get filthy!) without issue?
Reply By: Member - Core420 - Wednesday, Apr 27, 2022 at 11:20
Most 12 volt water pumps have significant plastic components which would break when subjected to road
debris under a vehicle. As a minimum I would install it inside a protective housing.
I use a Seaflo pump. It's inside the vehicle in a protective housing so that moving luggage doesn't damage it.
640353
Follow Up By: Kris K - Wednesday, Apr 27, 2022 at 11:22
Thanks, ive ordered NorthStar 12V RV Fresh Water Pump 7.6 LPM , slightly above the LPM rate of the Joocla pump but within spec.
Mine must be external, so I guess I can make a metal shroud to protect it from
debris
919426
Follow Up By: Frank P (NSW) - Wednesday, Apr 27, 2022 at 14:22
If it's a diaphragm pump it may have a breather hole on the air side of the diaphragm that can get choked with dust. I had to put a piece of open cell foam as a filter over the breather hole on my small Jabsco external pump.
919429
Follow Up By: Kris K - Wednesday, Apr 27, 2022 at 14:57
Good tip, yes its a diaphragm pump so ill be sure to
check that out!
919430
