Recommendations for Lithium Battery to power Enerdrive 2000Watt Invert
Submitted: Saturday, Apr 23, 2022 at 11:10
Kris K
Hi All,
We will want to run our Nespresso machine at some point off this inverter, which typically draws around 1800 watts. As I understand it, the C rating is important for high current devices. Can anyone recommend a mid range battery that will assist?
We have the following setup
400 Watts of Solar (41 volt panels)
Enerdrive DCDC charger
I figured we'd need 200AH as we will power the espresso machine, some small lights (2 x LED strips), charge phones/tablets and also power a Quick Charger from Milwakuee
Thanks!
Reply By: Member - Bigfish - Saturday, Apr 23, 2022 at 11:23
Why not buy 2 x 120 Itech and run in parallel. Will do the job no worries.
640303
Follow Up By: Kris K - Saturday, Apr 23, 2022 at 11:26
I dont think it would be Bigfish...
919392
Follow Up By: Member - Bigfish - Saturday, Apr 23, 2022 at 11:30
They will do it easy. Each battery is only pulling about 70 a/h max for a couple of minutes when using the espresso machine. Each battery is capable of a sustained usage pull of 150a/h .............. 270a/h for 5 minutes (each!). Mate has 2 of these and we use the espresso machine half a dozen times a day at least and batteries are fine. He has a 3000watt inverter .
919393
Follow Up By: Kris K - Saturday, Apr 23, 2022 at 11:33
Point taken, thanks bigfish.
919394
Follow Up By: Peter_n_Margaret - Saturday, Apr 23, 2022 at 16:19
I assume you are talking AMPS there, rather than Ahr?
919398
Reply By: Frank P (NSW) - Saturday, Apr 23, 2022 at 11:24
Hi Kris,
We have 360 amp hours of lithium batteries in our van, an 1800 watt PSW inverter and a small Nespresso coffee machine.
When the coffee machine and the milk frother are running together, the inverter is pulling 160 amps from the batteries.
I don't think many AGM deep cycle house batteries would be happy with such a discharge, but am happy to take advice on that. There may
well be some that can handle it but I don't know them.
Lithium is a better option, but expensive. But lithium is increasingly the general trend these days.
Some lithium batteries with a reasonably high capacity have a max discharge current limitation much less than 1 C, so be careful if you go that way. Do your research.
I bought my batteries from
Ev-Power in WA. Their batteries are made from large cells that can handle the high discharge rates you need.
640304
Reply By: Kris K - Saturday, Apr 23, 2022 at 11:25
Thanks Frank, will look at EV Power!
640305
Reply By: Bob Y. - Qld - Saturday, Apr 23, 2022 at 11:47
Kris,
Check out Lithium Battery Wholesalers on Facebook, good batteries with decent discharge ratings, good prices & good service.
I’ve got 2 of their 100Ah batteries, been in use over 12 months.
Lithium battery selection
They do a few package deals too, but as you already have an inverter, these may not suit?
640306
Reply By: Member - Racey - Saturday, Apr 23, 2022 at 11:58
When buying any batteries including Lithium when running coffee machines or microwaves, pay attention to the max discharge current. Most of the AGM replacement style have low discharge currents and not suitable for what those appliances.
640308
Reply By: Member - DW Lennox Head(NSW) - Saturday, Apr 23, 2022 at 14:26
Kris K,
I have all Enerdrive on board my caravan, AC/DC, DC2DC chargers, 2000 watt inverter and 200 amp hour lithium Btec battery, with 400 watts fixed solar.
Enerdrive advised me to go with the 200 amp hour with the inverter. I was going to go with 2 x 100 a/hr batteries. They told me than in the event of one x 100a/hr faltering under a big load, both may fail.
I believe their advice and support, above some other so-called “experts”. Give them a call or they are on Facebook on their page responding very quickly.
Duncan
640310
Follow Up By: Member - Bigfish - Saturday, Apr 23, 2022 at 16:13
I,d rather 2 batteries in a system than 1. If one fails then at least the chances are the other will get you out of trouble. Seen this many a time on the systems I have worked on. If your one and only battery fails...your up a
creek without a paddle.
1 x 200 a/h enerdrive is $2700 2 x 120 Itechs for 20% more a/h is $1800 and have capacity for larger amp output. No brainer in my book.
919397
Follow Up By: Member - McLaren3030 - Sunday, Apr 24, 2022 at 08:14
Hi Guys,
Renogy 100 AmpHr LiFePo4 batteries are currently on special at $639, x 2 = $1,278. Quality batteries from all the reviews I have read.
Macc.
919401
Follow Up By: Member - Bigfish - Sunday, Apr 24, 2022 at 09:10
I have a Renogy 100a/h as a spare
camp battery. 2 years old and often used by other mates for their fridges or for when something is required away from
camp (boat). Been very good and the ability to completely shut it down with an attached dongle is very handy. They also have a good reputation and others on various forums also sing their praises. Just ensure the specs match up with what amperage you want to pull. Same a s any battery. Cheers.
919403
Reply By: Peter_n_Margaret - Saturday, Apr 23, 2022 at 16:27
The limitations of discharge rate of Li batteries being talked about here are typically limitations of the battery management system employed, not of the battery itself.
Batteries and BMS's can be purchased seperately to get what you need for special applications.
640311
Reply By: Member - PWS - Sunday, Apr 24, 2022 at 20:54
Have a look at the Power Paul Scout 280 Ah lithium …. 250 amp discharge rate I have one and it runs a toaster …induction hot plate small air fryer no problems hand made battery in
Melbourne with top grade components….very good to deal with and competitive price stands by his product
640321
Follow Up By: Kris K - Monday, Apr 25, 2022 at 08:06
Nice, but the lead time is too long before our trip
919407
