Engel Power draw as a freezer
Submitted: Friday, Apr 08, 2022 at 16:10
phantom
Doing a trial with the 40l Anniversary edition Engel as a dedicated freezer set to -14C.
Freezer is in the back of a Prado with solarscreens fitted to the rear windows
Having trouble keeping the battery charged up when sitting for a couple of days with overcast conditions. I charge the dual battery system in the Prado when at
camp through our camper which has 240W solar hooked up to it.
Questions:
Is this temp too low/too high?
What typical amps used over a 24 hour period in ambient temp of high 20’s should I expect.
Planning an extended trip next year and looking at ways to store bulk food.
I can always throw more solar at it if needed.
Thanks in advance
Reply By: kgarn - Friday, Apr 08, 2022 at 18:30
Surely you mean AmpHours (Ah) used over a 24 hour period.
Amps is the rate of current (or coulombs per second). You probably want to know how may AmpHours (Ah) are consumed over a 24hr period so that you can determine appropriate battery capacity and solar charging capacity. For a fridge/freezer it would be reasonable to assume Ah consumed = Fridge current(A) x Duty cycle (%) x Hours (24 hrs)
In order to give a reasonable answer we would need to know how much current the Engel draws when running, the duty cycle when operating in ambient of high twenties. Given these data, it is possible to estimate the total energy requirement of the fridge. Then the next question is what is your battery capacity and what other loads are connected to the battery.
-14C is probably OK for short term storage.
640127
Follow Up By: phantom - Friday, Apr 08, 2022 at 19:35
Hi kgarn.
Yes mate, you are correct.
What I don't know is the duty cycling of the Engel. Current draw when it is running is around 2.7 A.
It is a dedicated battery for the fridge in the car.
919185
Reply By: George_M - Friday, Apr 08, 2022 at 19:48
What bulk food do you need to store at that temperature?
If we're off the
grid for an extended period we get the local butcher to cryovac our meat. It lasts easily for four weeks at normal fridge temperatures. A lot of other stuff you can't freeze anyway - milk, vegetables, etc.
Our endurance off the
grid is usually limited by stuff other than what we could freeze. Like beer.
May also be a good idea if you had your 240w panels checked - maybe an ExplorOz auto lecky could jump I'm here. Your panels should theoretically produce 20a in good sunlight, less whatever inefficiency you have in the panels, controller and cable.
George_M
640131
Follow Up By: phantom - Friday, Apr 08, 2022 at 20:02
G’day George,
We don’t really need to store that much, just trying it out as a freezer to see how it goes as I’ve read about some people that do this.
Looking primarily storing at meat, fish, bread, icecream (??) pre cooked meals - fried rice, spaghetti, etc. We carry a Vacuum Sealer with us so we can seal food along the way.
Solar panels are 2 x 120 W Projecta folding blankets and will put out a total of 15 A on a sunny day. We have a 3rd panel that we take as
well to use if needed plus another 2 back at
home.
We’re pretty much full time on the road and we are just looking at the viability of having the Engel as a freezer which is not looking good with our current set up.
What we have now does work.
919188
Reply By: Member - McLaren3030 - Saturday, Apr 09, 2022 at 07:12
Hi Phantom,
Firstly, is there anything in the fridge or is it empty? Air is not a good conductor of heat/cold, so fridges will cycle less if they are something inside them.
Secondly, depending on ambient conditions, compressor fridges will draw between 3 to 6 amps per hour, so if you took an average of 5 amps per hour over a 12 hour period, that is 60 Amps, without any charge going back in, your 105 AmpHr battery is going to be down around 50% SOC at the end of the time. So this sounds about right.
640136
Follow Up By: phantom - Saturday, Apr 09, 2022 at 08:11
Hi Macca,
What you’ve said seems pretty spot on and we always try and keep the fridge as full as possible.
Need re-think of our set up if we want to run it as a freezer.
919192
Follow Up By: Member - Outback Gazz - Saturday, Apr 09, 2022 at 12:52
"Firstly, is there anything in the fridge or is it empty? Air is not a good conductor of heat/cold, so fridges will cycle less if they are something inside them."
One of the members on here, possibly Allan B did a comprehensive
test on that with one fridge full and one fridge empty and found almost zero difference in power use.
Gazz
919200
Follow Up By: Bazooka - Saturday, Apr 09, 2022 at 19:36
I expect that result would change significantly depending on ambient temp and the number of times the fridge was opened Gazz.
919209
Follow Up By: Member - Outback Gazz - Saturday, Apr 09, 2022 at 19:50
G'day Bazooka
I will try and find the post when time permits but from memory that was all taken into consideration in the experiment.
Gazz
919210
Follow Up By: Bazooka - Saturday, Apr 09, 2022 at 20:01
Found it, but yet to read it, Gazz.
Allan's Myth Buster
919212
Follow Up By: Bazooka - Saturday, Apr 09, 2022 at 20:15
Allan's experiment wasn't all "hot air" Gazz but I'm sure he wouldn't mind me saying that it wouldn't exactly pass scientific muster either. He did arrive at the conclusion usually mentioned as the big issue - the transfer of hot and cold air on opening. If bubble wrap reduced power use then we could likely expect that a fridge full of cold items might do something similar, moreso in hotter conditions.
919213
Reply By: Member - lyndon NT - Sunday, Apr 10, 2022 at 19:38
I have the same fridge and live in the Top End. Ours is generally just used for drinks. These go in the fridge with an internal temperature of 35-40c. So fridge runs FLAT OUT 24/7. Continuous draw is 2.5A @ 12v.
What does this mean. In simple terms in mean 1 x 100ah/hr battery will run the fridge for 1 day.
I have had the following discussion before on EO and everyone has their own opinion. Why do you need to freeze anything? Get you meat Cryovaced. No need to run your fridge as a freezer. Keep at a couple of degrees. Store meat in a large Tupperware container and rotate the meat within this container to keep a constant temp (so the stuff near the edge doesn't freeze). Marinated chicken should be good for a week, lamb a little longer. Beef, ages, taken steaks back
home after 6 week trips and put them in the freezer.
Lyndon
640157
Follow Up By: Member - Bigfish - Monday, Apr 11, 2022 at 10:25
Why freeze? Quite simple. How do you bait fresh for fishing when camped for a week or longer. How do you keep you catch fresh to take
home? Bread also freezes
well and wont stay fresh otherwise.
919229
Follow Up By: Member - lyndon NT - Friday, Apr 15, 2022 at 19:13
Hi Bigfish
We aren't usually lucky to catch enough to take
home :-)
But seriously, bait, vac packed, cast net on the day or pots. So we have no need to freeze this.
Bread, never going to happen, bit like ice cream. Needs minus 20c and getting that in the back of a 4x4 in the Top End is a REAL ask. But hey, each to their own.
Many people get their meat vac packed and then try to keep it frozen whilst traveling................
Can't see the point, but again, folks want the hassle of that then that's up to them.
Lyndon
919289
Follow Up By: Member - Bigfish - Friday, Apr 15, 2022 at 20:22
Lyndon. I live in FNQ and always travel with a freezer. Milk , bread and bait as
well as meat stays frozen no worries at -18 in my fridges. Have camped for several weeks at a time in 37 + days and fridges work fine. Spent 20 years in
Darwin and Gove so know the area
well. Visited dozens of remote aboriginal communities via chopper, light plane or 4wd. I actually found it easier to just buy the food, freeze it and then eat when ready. Dont bother with the cryvac anymore. Also as I tend to be a reasonable fisherman I manage to always bring a few fillets
home and freezing is the only way to do this. As you say..each to their own for me its handy having freezer on site. Cheers.
919290
Reply By: Member - Captain (WA) - Thursday, Apr 14, 2022 at 12:12
I can easily run a 40L Engels as a fridge with 100W of solar (105A/hr battery), but when I add in a second 40L Engels as a freezer (longer trips), it cannot last overnight (~16 hours without solar).
Fridge and Freezer
I have added in a second battery (now 235 a/hr total) and a second solar panel (300w) and can keep up with the 2 Engels, as long as its only partially cloudy.
I reckon the fridge uses over 40 a/hr and the freezer over 60 a/hr per 24hr period.... over 100a/hr.day in total. Theoretically the 105A.hr battery should survive (just!) but does not.
640190
Follow Up By: phantom - Thursday, Apr 14, 2022 at 13:29
Cheers Captain,
I’ve dropped the Engel back to -1 and now have no problems with it keeping up, even on overcast days.
If I was to use it as a dedicated freezer in the future, then I would go lithium with a 200w solar panel on the roof and a portable as a back up for when parked in the shade.
With ambient temp of 25C during the day and 10C overnight, it’s using average around 30 per 24 hour
919278
Follow Up By: Member - McLaren3030 - Friday, Apr 15, 2022 at 09:48
Hi Phantom and Captain.
-1 is not considered to be an appropriate temperature for a freezer, very easy for it to periodically slip into the positive temperature range and back to negative again. This is a recipe for food spoilage leading to possible gastric problems.
Food Standards Australia recommends -18 for frozen food, and +4 for refrigerated food. These temperature recommendations are there for a reason. Now obviously there is some “overkill” safety built into these temperatures, and you can safely get away with a higher freezer temperature, but -1 is definitely not a good number.
Also, depending on a couple of things, a 40 Ltr. Compressor fridge is likely to draw around 40 to 50 amps over a 12 hour period, so overnight, you could see your 100 amp battery down to 50% SOC by the morning. Not usually a problem with a LiFePo4 battery, but certainly could be with an AGM battery. So it is no wonder your battery is pretty much flat when trying to run two fridges overnight. A second 100 amp battery will help, particularly if both are LiFePo4 batteries, but you need more solar capacity if you intend remaining stationary for any length of time.
A good rule of thumb is that for every battery amp you have, you need double the watts of solar capacity.
919286
Follow Up By: phantom - Friday, Apr 15, 2022 at 17:05
Thanks Macca,
Appreciate the
feedback.
All our food is vacuum sealed so we’ve dropped the temp. back to just use as a fridge, not a freezer. This was a trial before our next extended trip.
919288
