UHF aerial repair
Submitted: Monday, Oct 25, 2021 at 17:23
IKnowNothingAbout4WD
Don't let the name fool you, I know less than nothing...
My UHF aerial snapped off in some bushes. The aerial looks fine, but the screw bit is where it snapped. Am I able to replace just the black screw bit or does the whole unit need replacing?
snapped-aerial-img-1
snapped-aerial-img-2
Apologies for the large *.pdf files,
forum wouldn't accept the *.heic or *.png image files..
Thanks very much.
Reply By: Member - LeighW - Monday, Oct 25, 2021 at 18:56
Very much doubt you will get the part to repair it.
638400
Reply By: Member - Dick L - Monday, Oct 25, 2021 at 19:06
Try a 4X4 wreckers in your area
638401
Reply By: Bob Y. - Qld - Monday, Oct 25, 2021 at 19:23
No, that’s rooted! For best performance get a new one.
Prestige Communications have a good selection
here.
638402
Reply By: IKnowNothingAbout4WD - Monday, Oct 25, 2021 at 20:48
Thanks very much for the responses, everyone.
I’ll find the original receipt and look to replace like for like.
638406
Follow Up By: RMD - Monday, Oct 25, 2021 at 22:28
I would find an aerial which has a light weight upper stainless top above the cylindrical section, instead of the solid unforgiving thicker one as pictured. The thin stainless usually have a centre open coil which adds flexibility. If replaced with same then same is what will happen.
916814
Follow Up By: Member - peter_mcc - Saturday, Nov 06, 2021 at 22:27
We have a 150 diesel Prado and found that the fully metal ones wobbled a lot more than the fibreglass ones. When I broke ours I bought a cheap replacement at Repco in
Alice Springs - it lasted about 5kms on a corrugated dirt road before it broke off! There are definitely a quality difference between a cheap no-name one and something more
well known.
916975
Reply By: Member - Racey - Wednesday, Oct 27, 2021 at 13:57
The top section of the aerial is detachable from what was the base. I suspect that that base section may contain a coil which is not physically connected to the lead. The wire protruding from the base excites the coil which is connected to the mast.
I suggest unscrew the mast and confirm the above. If correct, straighten the protruding wire and re-attach the the top section with a good adhesive (leave the mast off until set). You have nothing to loose.
Racey
638426
Follow Up By: RMD - Wednesday, Oct 27, 2021 at 19:08
That protruding wire IS connected/soldered to the threaded section onto which the top aerial is screwed onto. Just replacing it isn’t going to solder it again is it? ie, no electrical contact. If not connected the energy reflection on transmit will fry the output transistors. Have to be FANTASTIC glue to hold the mass and bending forces and impact forces the whole top section imposes on the coil mast. Won’t work.
916846
Reply By: Member - Outback Gazz - Wednesday, Oct 27, 2021 at 21:24
For what it's worth and my 2 cents worth - I always carry a spare antenna whip in case of situations like this !
They aren't expensive and are easily stored without taking up any space !!
Happy safe and enjoyable travels
Gazz
638428
