How to run 12v ARB Air compressor off 240v
Submitted: Monday, Oct 25, 2021 at 10:40
Member - Steve R (NSW)
Perhaps this is simple but I thought I would reach out to the brains trust. I have a 12v ARB air compressor and there are occasions when I want to use it in my garage to pump up various inflatables. My car does not fit anywhere near my garage so I am seeking to use the compressor with a 240v source. What product do I require please?
Reply By: Stephen L (Clare) SA - Monday, Oct 25, 2021 at 11:10
Steve
The most cost effective way is to take the items to your car and then pump them up there.
Car air compressors use a lot of power and I doubt that you would be able to find a power Supply that would safely handle 30 plus amps
638387
Reply By: Member - LeighW - Monday, Oct 25, 2021 at 11:38
You need a 240V AC to 12V DC power that can handle the current draw of the compressor. Had a quick scan of the net but couldn't find the actual current draw of the ARB units.
The following gives examples of upto 66A:
800W power supply
638388
Reply By: Member - nickb boab - Monday, Oct 25, 2021 at 11:41
Most simple way surely would be a 12 volt battery and charger but you could also use a transformer ??
638389
Reply By: Member - peter g28 - Monday, Oct 25, 2021 at 12:18
You could use as someone was saying previously..a 240v - 12v battery charger as a power supply with Anderson plugs so you could connect up to the compressor. I believe Victron have 240v -12v battery charger that can be put into power supply mode via the Victron Connect App for the device..something like this.
Victron 240v Battery Charger..you will need to
shop around as they start at about $250.00..
638390
Reply By: Peter_n_Margaret - Monday, Oct 25, 2021 at 13:20
You could probably buy a 240V compressor for $150 or less.
I bought one for the OKA for under $100 16 years ago. Changed it for a 12V PX07 10 years ago to save some weight and put the 240V one in the shed. Still going
https://www.bunnings.com.au/products/tools/power-tools/air-compressors
OKA196 otorhome
638393
Reply By: Member - wicket - Monday, Oct 25, 2021 at 14:13
Reply By: Bushranger1 - Monday, Oct 25, 2021 at 16:07
G'day Steve.
I leave my 12v compressor in the 4wd & like you have items (wheelbarrows, Garden trolleys, hand trolleys, ride on mower etc) to keep aired up around the garden.
I bought the larger Ryobi 18v compressor for all those things & as I have a Ryobi drill I just use that battery.
Even use it to top up the trailer tyres when its parked right up the back of the yard & it handles it no problem.
I am sure whatever brand battery
tools you use would have a similar battery compatible unit.
Means that I won't forget to put my 4wd compressor back in the truck when I am done or have to lug a battery around the yard to power it.
Stu
638396
Reply By: Gramps - Monday, Oct 25, 2021 at 16:35
What's wrong with an
el cheapo foot pump? Buy two for less than $30 and get some exercise as
No need to over complicate things.
638397
Reply By: Frank P (NSW) - Monday, Oct 25, 2021 at 17:16
I'm always being asked to pump up kid's bike tyres, basketballs, soccer balls etc -my own grandies and also the neighbourhood kids. Word got out somehow :-)
I've kept an old AGM crank battery for the purpose and keep it charged with a small Ctek.
If you can get hold of a battery I think that's the way to go. There are other ways like power supplies, but with a 40amp output they will be expensive.
638398
Reply By: Allan B (Sunshine Coast) - Monday, Oct 25, 2021 at 21:19
Hi Steve,
The ARB compressor will draw something like 30 Amps or more, so a 240/12volt power supply of that size would cost a couple of hundred dollars.
But an alternative could be to keep the compressor at the car and run a length of air hose from there to the garage.
638407
Reply By: Member - Steve R (NSW) - Tuesday, Oct 26, 2021 at 08:45
Thanks for all the suggestions - much appreciated.
638409
Reply By: Member - Cuppa - Tuesday, Oct 26, 2021 at 11:38
x2 for a cheap 240v compressor, far more convenient.
638412
Reply By: Kazza055 - Tuesday, Oct 26, 2021 at 13:04
A very cheap 12V power supply can be made using the computer PSU's. I have just finished making up a dual 12V to run 2 fridges in the back of the car when I have access to 240V. The PSU came out of an old PC that I was no longer using and has 2 x +12VDC supplies at 17A each, if these are connected in parallel you should get double the current.
Here is one on eBay that has 2 x +12V outputs at 34A each -
850W ATX Cooler EXTREME Power Supply Silent Fan PSU Desktop Computer PC Gaming and is only AU $76.50 each.
I agree with other that a cheap 240VAC compressor would be easier but the above is a reasonably cheap option.
638414
