bad tasting water!
Submitted: Saturday, Oct 23, 2021 at 22:10
eric s4
I have searched for answers, but still nothing.
my van has 2 separate
water systems, the
tankwater which is plunged to the sink always tastes good, even though the
tank has never been cleaned, and is always filled with a crappy garden hose.
the mains
water system, which uses a separate tap, always tastes terrible. I use a drinking grade hose, a filter, have replaced all the copper with polypipe, with no change to the taste. the only component which hasn't been changed is the sink tap, so could this be the culprit?
Reply By: Member - shane r1 - Sunday, Oct 24, 2021 at 07:34
That’s just weird!
Just drink from the tank tap ?
638374
Follow Up By: eric s4 - Sunday, Oct 24, 2021 at 11:43
that's what we have to do, just want to get to the bottom of the issue!
916798
Reply By: Nomadic Navara - Sunday, Oct 24, 2021 at 07:53
Pure
water has no taste, so maybe the unfiltered
water from the tank has something in it that makes it taste better to you however your filter is removing that “taste” you like from mains
water.
638375
Follow Up By: eric s4 - Sunday, Oct 24, 2021 at 11:36
nothing i have done has changed the taste. first thing i did was change the drinking hose 3 times, then changed the piping, lastly adding a filter. no change in taste throughout the whole process!
916795
Reply By: RMD - Sunday, Oct 24, 2021 at 10:03
Eric
You mean "plumbed" to the sink it seems. Perhaps the tap sealing washer in the SUS system is degrading and tainting the taste. It might be easier to replace the sealing washer with an inert one to see. Always do the easy first. You seem to have done the hard stuff first.
Not a good idea to fill any vessel you drink from by using a garden hose. If sitting in the sun and not a FOOD grade hose, the plastic hose emits carcinogenic particles into the
water, which goes into your drinking
tank. Just not wise. Vets say that is the cause of many dogs having cancers by filling
water bowls from garden hoses left in the sun to degrade.
638376
Follow Up By: eric s4 - Sunday, Oct 24, 2021 at 11:40
might as
well just change the whole tap i think, that will eliminate everything. just think it's strange it could be the tap itself, as I've never had this taste from any other
water source!
916796
Follow Up By: Gronk - Sunday, Oct 24, 2021 at 21:02
Have you got a link to an article to say a garden hose emits carcinogenic particles ?
916803
Follow Up By: Batt's - Sunday, Oct 24, 2021 at 23:11
Do a search it doesn't take much also add birth defects poor learning abilities prem birth etc.
916806
Follow Up By: Nomadic Navara - Sunday, Oct 24, 2021 at 23:13
Health and safety - it is contained within this. Read all the subheadings under that heading.
Twenty five or so years back one of our caravan club members was a chemical engineer. Way back when food grade garden style hoses came onto the market he spent one night at one of our rallies explaining the situation.
916807
Reply By: Member BarryG - Sunday, Oct 24, 2021 at 10:04
I think it could be the tap! I once fitted an eBay tap (Chinese?) to out bathroom in the house. The
water from that tap tasted bad until I replaced it with a locally-made tap.
638377
Follow Up By: eric s4 - Sunday, Oct 24, 2021 at 11:42
yeah, i'm hoping this is the issue. the van is 30y/o, and it would still be the original tap!
916797
Reply By: tonysmc - Sunday, Oct 24, 2021 at 12:08
There could be a small critter got into the line at some stage and is stuck at the tap (small frog, caterpillar from wasp) I have seen this before. The other thing you said was you have replaced the
water hose 3 times. Was the hose from the same batch or purchased at different times or different supplier, as I have come across a bad batch of hose before and it made to
water undrinkable.
638380
Follow Up By: eric s4 - Sunday, Oct 24, 2021 at 12:16
quite possible there is something foreign in the tap, so i'll replace it anyway. iv'e had the van for about 6 years, and it's been the same ever since!
916800
Reply By: Oscar H - Sunday, Oct 24, 2021 at 16:58
If the tap is connected with braded lines , sometimes the bad taste is from those, even brand new ones can have a taste. If you van has been sitting for a while, run the tap for 5 to 10 seconds sometimes clears this up.
638382
Follow Up By: eric s4 - Sunday, Oct 24, 2021 at 22:28
no braided line, just poly up to the stem, and the taste hangs around regardless how often it's used!
916804
Reply By: Member - shane r1 - Sunday, Oct 24, 2021 at 22:17
Another thought
If you run the tap for a fair period of time , I would think wherever the bad taste is coming from would become far less, the taste should at least get better.
A bad washer or dead stuck bug or whatever couldn’t keep contaminating the
water to that extent.
Hope you can find what’s going on , it’d be bloody frustrating!
638384
Follow Up By: eric s4 - Sunday, Oct 24, 2021 at 22:31
yes Shane it is annoying, but as mentioned, i'll change the tap. planning on upgrading the van mid next year, so no big deal if i don't fix it, have put up with it for long enough!
916805
Reply By: Batt's - Sunday, Oct 24, 2021 at 23:26
Try emptying the tank you fill with the green garden hose, use the food grade one, flush a bit and try the
water see if it tastes bad like you're other tank to eliminate the food grade hose not adding that yummy chemical taste you may be use to from the garden hose. I put some lemon juice in a new tank once went for a drive so it mixed in let it sit for a day or 2 and flushed it out all good.
638385
Follow Up By: eric s4 - Sunday, Oct 24, 2021 at 23:30
guess i could just fill a jug straight from the food grade hose, and try it!
916808
Reply By: Member - Outback Gazz - Monday, Oct 25, 2021 at 07:55
Reply By: Member - Jim S1 - Monday, Oct 25, 2021 at 14:49
When you change your tap, before connecting it permanently try running some
water through and tasting it. Just might be the poly pipe for some odd reason.
Also check the 12v pump ....... something may be amiss there.
Good luck !
Jim
| "Sometimes I sits and thinks, and sometimes I just sits." A fisherman.
"No road is long with good company." TraditionalLifetime Member My Profile My Position Send Message |
638395
Follow Up By: eric s4 - Monday, Oct 25, 2021 at 21:01
I replaced the copper pipe with the poly pipe only recently, and unfortunately it made no difference.
cheers!
916812
Reply By: Geoff (Newcastle, NSW) - Tuesday, Nov 16, 2021 at 14:09
What happens if you taste the
water straight out of the tank, not running it through the hose and tap?
Just gravity feed out of the spigot on the tank into a cup or jug.
| Geoff,
Landcruiser HDJ78,
638622
Follow Up By: eric s4 - Tuesday, Nov 16, 2021 at 14:16
tank
water is fine, regardless of how it is filled, or how long it sits for.
mains
water always tastes weird, despite changing all components, and using a filter.
both systems are independent!
917168
Follow Up By: Geoff (Newcastle, NSW) - Tuesday, Nov 16, 2021 at 14:19
So it tastes weird straight from the tank is what you are saying?
Long before it gets to the tap.
| Geoff,
Landcruiser HDJ78,
917169
Follow Up By: eric s4 - Tuesday, Nov 16, 2021 at 14:21
nothing wrong with the tank
water straight out of it's own tap!
917170
Reply By: Peter N25 - Friday, Dec 03, 2021 at 21:04
G'day Eric, I learned during my years working on building sites NEVER to drink
water which has run through a garden hose. Not for the taste but for the fact that bugs grow in wet environments which can lead to illness. There are purifying tablets you can buy for your tanks.
638768
Reply By: Nomadic Navara - Wednesday, Dec 08, 2021 at 19:54
Eric, have you tried someone elses food grade hose and see if it is still the same. The fact that a hose is food grade does not guarantee that it will not taint the
water. All that you can guarantee with food grade hoses is that they will not introduce the same carcinogenics into the
water that Vinyl hoses do.
I have not heard of this happening lately. However, some years back this was a problem. Bunnings were supplying food grade hoses that tainted the
water. Using hoses from a different manufacturer cured the tainting problem
I suggest you try some different hoses. Perhaps you could use your garden hose. If you just use it for testing you should not get too much in the way of carcinogenic products (many of us used common garden hoses before the food grade hose came on the market and we are still alive.)
638787
