The difference between GQ 2.8td and GU 2.8tdi
Submitted: Sunday, Jun 27, 2004 at 19:05
Patrol22 (Queanbeyan
Hi Everyone - apart from the obvious intercooler addition what are the main differences between the engine in the two models? Is it limited to the engine management system or are they significantly different?
Ta
Pete
Reply By: Nino & Kerry (VIC) - Sunday, Jun 27, 2004 at 20:28
Hi Pete,
I think i'm right in adding that also the flywheels, glow plug system, engine managment, turbo boost control (waste
gate versis pop off valve), inlet/exhaust manifolds,
However i'm lead to beleave that the "long motors" are the same.
When
mine blows,if i still have it i'd consider a Chev 6.5 td conversion.I'm dreaming....Probably.
Cheers Nino.
65413
Follow Up By: rolande- Sunday, Jun 27, 2004 at 21:52
Nino,
Check archives about chev V8 diesel's in US, may not be the answer you are looking for :)
Rolande
326383
