Different batteries for power
Submitted: Tuesday, Mar 16, 2021 at 08:18
Geoff K4
Could a Lithium battery in a vehicle add power to a Lead Acid battery via cable and Anderson plugs in a caravan? The lithium in vehicle is solar charged independently so hoping to just add power to the caravan house battery while
bush camping. Batteries being different types I don't think it's going to be a problem while separately charged. Am I right or wrong?
Reply By: RMD - Tuesday, Mar 16, 2021 at 09:58
Geoff
As QLD camper said, with a DC DC unit running off the Lithium to the Lead acid it will work with some loss of energy of course. You would have to ensure the drop out voltage of the DC DC unit isn't going to harm the Lithium though. Best to
check what the lithium can safely deplete to in voltage and if that matches the Dc Dc unit's startup and dropout voltage. DC DC units typically run off an alternator or solar source which is higher voltage than a static lithium. Because the batteries have vastly different characteristics of amp flow and voltage retention it would be unwise to simply connect a Lithium to an AGM or Start battery as you would have no control over the current flow from and into. Others will have more info of possible use too.
635606
Reply By: Allan B (Sunshine Coast) - Tuesday, Mar 16, 2021 at 19:33
Hi Geoff,
Simply connecting the lithium battery directly to the lead-acid battery and its connected loads in the caravan will safely provide energy to those loads. It will not however provide a charge transfer to the caravan battery as the lithium voltage is insufficient. Use an adequate wire gauge for the link cable and fuse it at each end.
You would of course need to supervise the discharge voltage of the lithium just as you would if it was discharging into its own connected loads. And break the link between the two batteries during charging.
635618
