Forget to check "I'm not a robot" - lose your post..
Submitted: Wednesday, Feb 24, 2021 at 10:08
ThreadID: 141124 Views:8184 Replies:5 FollowUps:5
Is it just my browser? If you forget to click "I'm not a Robot" prior to hitting Submit for a new forum post you lose all of your typed text.. it can't be recovered..
Reply By: Genny - Wednesday, Feb 24, 2021 at 10:42
Hitting the "Back" button on Firefox worked for me.
AnswerID: 635187
Follow Up By: Duncan2H - Wednesday, Feb 24, 2021 at 10:45
OK thanks.. Chrome is behaving differently. Text is lost.
FollowupID: 912721
Follow Up By: axle - Wednesday, Feb 24, 2021 at 12:43
And it s worse when your not the worlds fastest on the type writer, and have to go and rewrite everything again.....lol.
Cheers.
FollowupID: 912724
Follow Up By: ExplorOz - David & Michelle - Wednesday, Feb 24, 2021 at 19:46
Fixed it see my response below.
David
FollowupID: 912731
Reply By: Duncan2H - Wednesday, Feb 24, 2021 at 12:59
AnswerID: 635190
Reply By: ExplorOz - David & Michelle - Wednesday, Feb 24, 2021 at 19:46
Hum,
Glad I read through the forum today - this is not how it should be nor how I wrote it way back when I installed it.
I have had a look and found that an update to the reCapture software caused a problem if you forgot to check it. I have now coded around this and you will not lose you post.
David
AnswerID: 635198
Follow Up By: Member - Duncan2H - Wednesday, Feb 24, 2021 at 19:50
Good stuff.. thanks!
Tested.. and confirmed fixed!
FollowupID: 912732
Reply By: Nomadic Navara - Wednesday, Feb 24, 2021 at 23:44
I have been using an Addon on my Firefox called Textarea Cache. This records everything you type into your newsgroups and the like. If you do something silly or have a system crash and lose your typing you can recover it easily. The Addon puts an icon in one of the toolbars, you just click on the icon and then go looking for your text.
There are a number of other similar Addons for FF, If Textarea Cache is not available on your browser I'm sure there would be something similar for your browser.
AnswerID: 635208
Reply By: Bazooka - Thursday, Feb 25, 2021 at 12:26
Had something similar happen on Exploroz with the Preview option a while back. David was AGAIN very quick to fix the problem, caused by an upgrade oversight iirc.
I often ctrl-c before posting on some sites but occasionally forget. Found this Chrome extension
Typio Form Recovery
which might be useful to some
AnswerID: 635215
Follow Up By: Nomadic Navara - Thursday, Feb 25, 2021 at 23:25
That one is similar to the Textarea Cache I mentioned in my previous reply. In the link you supplied they make mention of Lazarus Form Recovery. I used that way back but its creator did not update it when Firefox suffered a serious update. It also did not translate to Win 10. There are plenty of similar Addons and I can recommend that everyone should have one of them installed to overcome mishaps.
FollowupID: 912769
