Nissan Patrol dropping power
Submitted: Thursday, Feb 11, 2021 at 10:38
ThreadID: 141060 Views:6305 Replies:5 FollowUps:4
G'day this Nissan Patrol 3.0di is dropping power on acceleration and with a quick Tap on the accelerator pedal the power kicks back in but continues to keep droping out.
Reply By: Motherhen - Thursday, Feb 11, 2021 at 11:04
Yours may not be the same issue as ours, but worth checking. We had similar, and various Nissan dealers replaced all sorts of expensive parts to no avail. Son took it out for 10 minutes and discovered the accelerator switch was occasionally sticking. A bit of WD40 and it has been fine ever since.
AnswerID: 635027
Follow Up By: Bob Y. - Qld - Friday, Feb 12, 2021 at 06:56
Read this out to the mechanic at work yesterday. Straight away he said "accelerator pedal", before I'd read MH's reply to him.
FollowupID: 912496
Reply By: Bushranger1 - Thursday, Feb 11, 2021 at 13:32
G'day Ben,
A friends 3 L Patrol did a similar thing many years back & turned out the MAF (mass airflow sensor) in the intake was covered in soot.
He cleaned it with throttle body cleaner then the issue disappeared. After that it became part of his service regime & problem never came back.
Worth a try as its not hard to do. Plenty of video's on the internet.
Stu
AnswerID: 635029
Reply By: RMD - Friday, Feb 12, 2021 at 16:49
Wear and dust will wear the carbon track in the pedal/throttle position unit and if the LOSS is when only around one position, the most used position, then the wiper inside the unit may be losing contact with the carbon, similar to a volume control but most have three wipers for durability/life. Dust will wreck it and IF the vehicle has been swimming and pedal area wet the unit will suffer prematurely.
Obviously you can't keep accelerating so is it when you back off to normal the problem reappears? Any movement of the pedal will immediately alter the ECU signal and all would work/appear normal again until back to same.
Many can be opened for a look see.
AnswerID: 635049
Follow Up By: Member - Warren H - Friday, Feb 12, 2021 at 22:10
You could try an electrical contact cleaner with a lubricant (Jaycar).
NT Pajero
2007 Goldstream Crown
FollowupID: 912513
Follow Up By: Ben B14 - Saturday, Feb 13, 2021 at 16:07
it's on acceleration. And I think also does it when cruising like down the freeways
FollowupID: 912529
Reply By: James B27 - Saturday, Feb 13, 2021 at 00:31
Hi, my wife once had this problem we just bought her a Jaycar there something like an automatic windshield wiper, I advise you to try it!
AnswerID: 635058
Follow Up By: RMD - Saturday, Feb 13, 2021 at 11:43
AT 00:31 in the morning the engrish doesn't make sense James!
FollowupID: 912523
Reply By: Member - stephen n2 - Friday, Feb 19, 2021 at 21:22
Have a gq 4.2 we had a similar problem turned out to be dirty fuel which clogges up a little filter as the fuel enters the motor. Could be nothing like the problem but it definitely happened to us .Good luck.
AnswerID: 635131
