New LPG cylinder valve transition
Submitted: Wednesday, Jan 20, 2021 at 20:08
ThreadID: 141004 Views:8468 Replies:3 FollowUps:1
Apparently there are new safer gas cylinder valves on the way. ( Thanks Kathy from Ultimate Owners )
https://www.commerce.wa.gov.au/announcements/new-lpg-cylinder-valve-transition
Jim
"Sometimes I sits and thinks, and sometimes I just sits." A fisherman.
"No road is long with good company." Traditional
Reply By: Member - Racey - Thursday, Jan 21, 2021 at 09:44
Thankfully the existing appliance connectors are compatible with the new valve assembly and will still be legal for use with cylinders with up to 25 liters of water, nominally 10kg cylinders , up until the hose or pigtail needs to be replaced. In which case the new connector must be used.
Racey
AnswerID: 634864
Reply By: bobsabobsa - Thursday, Jan 21, 2021 at 10:41
It looks as if the nose has to push the valve open when screwed in , what a great idea
If your hose comes loose the flow of gas stops. I have never had one do this , but can see the merit in its safety
AnswerID: 634865
Reply By: Jarse - Thursday, Jan 21, 2021 at 13:45
They've been used in the USA for yonks.
AnswerID: 634873
Follow Up By: bobsabobsa - Thursday, Jan 21, 2021 at 15:12
That valve configuration is in Australia , more that likely from USA , they are dual with POL and this outside thing ,although I dont know if they have the shut off valve, I will look next time
FollowupID: 912270
