Waeco repairer in Mandurah WA
Submitted: Monday, Dec 28, 2020 at 19:53
JohnHelen W
Just checked into a park in Mandurah where we'll be staying for several weeks. Our old reliable 50l Waeco has suddenly decided not to work though the motor runs.
Does anyone know of a good repairer in Mandurah we can contact/use?
Many thanks in anticipation.
Reply By: Kazza055 - Monday, Dec 28, 2020 at 20:43
If you are staying in a park,
check if they recommend someone. I have used this approach in the past and had good service from the recommendation.
I had my 40L Engel die on me and brought a 60L Brass Monkey for $499 from Jaycar.
634536
Reply By: bobsabobsa - Tuesday, Dec 29, 2020 at 09:41
Check that it is the compressor running , If it is then it will 1 of 2 things wrong 1 lost gas or 2 compressor not pumping , either way it is a throw away , by the time you pay for a fridgy to look at it
you are on your way to a new fridge , Gas leaks are hard to find and it is more than likely the evaporator and not repairable , and changing a compressor is not worth it
634537
Reply By: Life Member - Duncan W (WA) - Wednesday, Dec 30, 2020 at 13:07
I'm not in Mandurah, but I had
mine repaired at Battery World In Maddington, maybe the Mandurah branch of Battery World does likewise. BTW it took ages to get
mine repaired as they were absolutely snowed under at the time.
634560
Reply By: Geoff K4 - Sunday, Jan 03, 2021 at 11:57
Please clarify not working? not on 240V or not on 12V
634622
