Article Comment: ExplorOz Traveller
Submitted: Tuesday, Aug 25, 2020 at 21:14
Member - Warren H
Following a discussion on another
forum about how to determine whether a road is paved or unpaved, I thought I'd look up the map legend for EO Traveller in the Reference manual (p12). I discovered that the resolution is too low to clearly resolve difference between the lines used. Could the pdf be updated with a higher resolution legend?
Reply By: ExplorOz Team - Michelle - Wednesday, Aug 26, 2020 at 09:17
Use the original legend for full size resolution ie. from a raster map sheet or tap the symbol in bottom right of the online
EOTopo map.
Essentially solid red lines are sealed and dashed are unsealed with different thicknesses for major/minor.
633117
Follow Up By: Member - Warren H - Wednesday, Aug 26, 2020 at 16:12
The resolution of these isn't really any better as the thin dashed lines are too pixelated, if I remember correctly the recommendation for line art is 600dpi, not sure how this translates for screen viewing. I found a useful document on the
GA website.
910049
Reply By: Member - wicket - Wednesday, Aug 26, 2020 at 17:08
Different colours would be the best solution
633127
Follow Up By: Member - Warren H - Thursday, Aug 27, 2020 at 10:52
There are national/international standards for map production including colour, line width, dash spacing. I just couldn't find it in a hurry as I wanted to be accurate, see below, all values in mm. When creating a pdf you can select the resolution of images and line art separately, but I understand that the line art has to be a vector not raster image which I presume why the legend images are pixelated and the spaces between the dashed lines are blurred.
Topomap road symbols
910066
