12 volt compressor
Submitted: Friday, Aug 14, 2020 at 19:52
gizza
Looking to purchase 12 volt compressor
( don’t want Chinese made )
Recommendations please
Reply By: RMD - Friday, Aug 14, 2020 at 20:03
I think you will be hard-pressed to find one not made in China. No matter what brand name they have on them!
632962
Reply By: gizza - Friday, Aug 14, 2020 at 20:14
I know , I had a bush
ranger III but the plastic ring joining the hose to the unit over heated and broke hence the hose would not stay attached tried Pirtek but not able to fix it (cost) I was informed they used to be brass but replaced by plastic when sent overseas for manufacturing,
Need something reliable while traveling and something to inflate all tyres without struggling ??
632963
Follow Up By: Phil G - Sunday, Aug 16, 2020 at 10:13
Gizza,
Overheating at that point is a common issue which I fixed a few years back by adding a one metre rubber hose at the compressor end. I used 9.5mm Transmission oil hose because it was nice flexible rubber hose and can take the heat and 100psi working pressure. Made
mine up as an extension using Nitto fittings, same as the compressor.
909880
Follow Up By: Allan B (Sunshine Coast) - Sunday, Aug 16, 2020 at 13:02
I agree with Phil that heat on the hose where attached to the compressor is a problem.
Mine melted the plastic hose at that connection. I solved the problem in a similar way to Phil with an anchored Nitto socket at its end. Then replaced the 6m ARB plastic hose with one of quality reinforced rubber.
909883
Reply By: Michael ( Moss Vale NSW) - Saturday, Aug 15, 2020 at 03:12
I bought a Big Red compressor back in 2003, made in USA by Thomas and used in pneumatic bus doors and other commercial uses. It was about $350 then but seems now around $550. Also a black version is made to Australian specs. Its not the fastest but very reliable.
http://www.4wdworld.com.au/Big-Red-Air-Compressor.html
632965
Follow Up By: Michael ( Moss Vale NSW) - Saturday, Aug 15, 2020 at 03:42
Just to follow up, a friend of
mine has a PX07, probably the best and fastest compressor around but no idea where its made and the Boss compressor is a serious unit also but that could be Chinese made. By the way, I still have my Big Red and its still going strong. Regards, Michael
909867
Reply By: Member - McLaren3030 - Saturday, Aug 15, 2020 at 07:33
ARB Twin Motor Compressor. Very reliable, expensive yes, but gets very high ratings on all the tests. If you can afford the one in the case with the tank, it is the one to get. Also have a look at a twin hose deflater, I think the brand name is Indeflate. When connected correctly, it enables you to equalise/inflate/deflate two tyres at once, shortening the time it takes to reset tyre pressures.
632968
Reply By: Member - abqaiq - Saturday, Aug 15, 2020 at 08:35
For dependability look for one with a 100% duty cycle at at least 80 psig. That will probably rule out most of the junk. I have a Boss, 100% duty cycle@100psig and rebuild-able. I built up an engine driven one on our LC 80 in Saudi (the best-IMO) but that type usually won't fit in cramped engine bays. You want reliability outback.
632971
Reply By: Bob Y. - Qld - Saturday, Aug 15, 2020 at 09:42
I bought a Thomas “Blue Tongue” maybe 25 years ago, from Piranha in
Melbourne.
Has 100% duty cycle, but is very steady and certainly wouldn’t suit an impatient traveller. Recently purchased a Supercheap compressor as a back up, it works okay, but wouldn’t fit your criteria.
The set up Macca mentioned might be the way to go, twin cylinder ARB unit. I also investigated the twin hose thingys, there are at least 2 different brands available on eBay, at different prices. Good gear, and worth getting if regularly changing tyre pressures.
632972
Follow Up By: RMD - Saturday, Aug 15, 2020 at 12:48
Years ago I too bought one of those Blue Tongue compressors and it hasn't had much use but doesn't create more than 90psi at the best of times. Very slow, great motor but the compressor section I looked at. It consists of a very small piddly size piston in an aluminium liner and while in a huge housing the cylinder is alarmingly small in diameter. It works but best to make lunch and plan the evening meal while trying to inflate just 1 tyre let alone 4 tyres. A single cylinder ARB is ok and I use it with a small air receiver tank.
909872
Reply By: Member - Cuppa - Saturday, Aug 15, 2020 at 13:26
When choosing my compressor - an item which anyone travelling remote has to rely on, I was put off ARB units, even though plenty of folk recommended them. The reason - a few reports I read online about when things go wrong with them - in a nutshell - poor customer service. Fine so long as they keep working ok was the impression I got. No direct experience however.
At the time of buying that left me with two choices, already mentioned by others - Thomas - because I had had one in a previous vehicle , & like reported it was slow but reliable. The other - the Boss PX07. I went for the Boss based on recommendations from folk who travelled as I intended to, & whom I trusted. I have no regrets. Installed it with a 9 litre tank. They say they are rebuildable - I put that to the test - not a compressor failure, but the result of my own stupidity. I needed a new cylinder head. Emailed Boss for advice on a Friday evening & was amazed to get a phone call from them the next morning. The chap could not have been more helpful. Parts were dispatched at very reasonable cost, & the fitting of the new cylinder head was simple enough for anyone who can put a couple of Lego bricks together! It has provided reliable service frequently during the past two years we have been away from home. No idea where they are made, but Australian backup is good. One thing - use a brass adapter into the cylinder head, not the supplied hose with chromed fittings. That way you can avoid the damage I did to
mine should you ever need to remove it. ;)
632976
Reply By: Member - Supersi - Saturday, Aug 15, 2020 at 19:56
Another nod for the Boss PX 07. Expensive but does the job, quickly.
632979
Reply By: rumpig - Saturday, Aug 15, 2020 at 21:00
I have a TJM Heavy Duty compressor in my Cruiser, goes pretty good pumping up my 34” tyres from beach to road pressure, and is quite small in size.
632980
Reply By: AutoRepairs D - Saturday, Aug 15, 2020 at 21:35
This post has been read by the moderation team and has been moderated due to a breach of The Advertising/Self-Promotion Rule
Forum Moderation Team
632981
Reply By: Member - Boobook - Sunday, Aug 16, 2020 at 08:33
This should do the job, Not chinese and won't over heat.
Fast compressor
Not sure of your budget cause you didn't say.
632985
Follow Up By: Griffin - Sunday, Aug 16, 2020 at 09:03
A smiley would have helped there.
909876
Follow Up By: Member - shane r1 - Tuesday, Aug 18, 2020 at 15:07
That’s got some pretty good CFM rating for a 12 volt compressor , 8 cfm @ 50 psi is impressive , a lot of Tyre shops would only have 40 to 50 cfm running on 3 phase. But at 180 max amps you’d want wiring etc up to scratch.
909916
Reply By: Alloy c/t - Wednesday, Aug 19, 2020 at 09:49
Reliability ? Time ? If time is not important 'reliability' is easier to get , my old ARB single which was actually designed for air locker activation not tire inflation does my tires , 33" , from 14psi back to h/way pressures no worries , yeah it might take 5min per tire BUT it does the job and has done in the 3 different vehicles that I have had it mounted in ....
633040
