Lithium battery limitation
Submitted: Monday, Aug 10, 2020 at 13:36
Member-George (WA)
I have a 2500w pure sine power inverter installed in our caravan,
I also have a 200Ah Lithium battery installed.
The instruction manual for the battery states that the inverter, connected to the battery, should not be greater than 1000w
If a larger inverter is used it could damage to battery BMS system
Question is, can I still use the 2500w inverter but limit any connected devices to require less than 1000w
Thanks in advance for any advice
Reply By: RMD - Monday, Aug 10, 2020 at 13:56
George
As I see it,
A 1000w load will be drawing
well over 80 amps from the battery, 12.5v X 80 = 1000, then there is losses in the switching and even more amps drawn than the basic equation, because of losses and not just the load. Do you know the acceptable discharge current for the battery and it's BMS? That constant battery discharge ability will govern it. A 2500 inverter may not be quite as efficient as a smaller unit and although possibly limiting the load to less than 1000w the power consumed from the battery may be more than 1000 anyway. A bit hard to quantify it all without
test gear.
I have a few
inverters and the smaller 300w Pure sine wave uses less current than the 1000w pure Sine wave while running the same load.
632894
Follow Up By: Member-George (WA) - Monday, Aug 10, 2020 at 14:11
Hi, thanks for your quick reply.
According to the battery manual, The maximum discharge current is 200A @ 25c
Pulse discharge current, 450A for 1.0s
Cheers, G
909812
Follow Up By: Frank P (NSW) - Monday, Aug 10, 2020 at 17:30
If the battery manufacturer says the max discharge current is 200A then I don't understand why they limit the inverter to 1000W which, as RMD has said, will draw MUCH less.
To answer your question, yes, if you keep your loads below 1000W you should be ok. I certainly would not be tossing away your existing inverter.
But if I were you I'd be asking the battery manufacturer/supplier why the very conservative limitation? They might have a very good reason, but if so it escapes me.
909814
Follow Up By: Member-George (WA) - Monday, Aug 10, 2020 at 18:12
Thanks Frank,
I assume that 200A is the total allowed, including any other loadings in the caravan, i.e. fridge, TV etc.
Cheers, G
909816
Follow Up By: Frank P (NSW) - Monday, Aug 10, 2020 at 20:08
Yes, the limit is what comes out of the battery in total at any particular time. It doesn't matter where it's being distributed to, it's still coming out of the battery.
909819
Reply By: Bazooka - Monday, Aug 10, 2020 at 16:03
This might help George:
What size Inverter can I use on my lithium battery (Enerdrive)?
Keep in mind that Enerdrive is talking about their own B-TEC battery with INTERNAL BMS here (extract):
"The internal BMS setups have a safeguard built into their system. If a battery reaches/exceeds the maximum current output, the battery will switch off internally to protect the BMS and the cells from over discharge......."
I'm no expert but have been doing a LOT of reading about lithiums in recent weeks. Would have thought that most decent BMS' should ensure no damage is done if you overload the battery (should shut down). Also seems reasonable to assume that keeping your total load under 1000w ought not have any effect (other than depleting your battery of course) but if the "manufacturer" says damage might be done to the BMS itself then you're risking that AND your warranty to boot. How will you ensure that you (plural) won't exceed the load?
Btw LiFePO4s should be ~13V at ~80% DoD if you want to be more precise in your calcs:
https://enerdrive.com.au/2017/11/29/can-charge-lithium-battery-lead-acid-charger/
"A 12v lithium LiFePO4 battery fully charged to 100% will hold voltage around 13.3-13.4v. Its lead acid cousin will be approx 12.6-12.7v. A lithium battery at 20% capacity will hold voltage around 13V, its lead acid cousin will be approx 11.8v at the same capacity.
What brand battery if you don't mind me asking?
632897
Follow Up By: Member-George (WA) - Monday, Aug 10, 2020 at 18:15
Thanks Bazooka,
Your answer makes sense, Thanks
Cheers, G
909817
Reply By: Noel L2 - Monday, Aug 10, 2020 at 16:51
My answer is..... yes you can...... I'd just keep loads to less than 1,000w continous..... which would keep your current draw to around 80amps .... no worries at all.
I would suggest a larger (ie 2500w) inverter "idling" at 1,000w would most probally be cleaner or a nicer load then a 1,000w one running flat out at 1,000w..... especially if the 1,000w one overloads and drops out from time to time.
632898
Follow Up By: Member-George (WA) - Monday, Aug 10, 2020 at 18:18
Thanks Noel,
I was thinking the same as you.
It's a matter of making sure I don't use any appliances over 1000w or better still 900w to be on the safe side.
Cheers, G
909818
Follow Up By: Bazooka - Monday, Aug 10, 2020 at 20:17
Don't forget that's the TOTAL continuous draw of everything connected to/drawing current from your battery George. Lights, fridge, ........
909820
Follow Up By: Noel L2 - Tuesday, Aug 11, 2020 at 12:54
I think the 1,000w inverter requirement by the battery manufacturer already takes into accout the inverter losses..... ie 10%or so..... so a 1,000w inverter supplying a 1,000w load will draw around 90 to 95amps from the battery.... still keeping a bit under then100amp battery rating.....
909824
Reply By: Bazooka - Monday, Aug 10, 2020 at 19:46
A bit more investigation and it seems 100A max continuous discharge current is pretty standard for 200Ah lithiums George. That equates to about 1330W (13.3V x 100A) continuous power usage.
If your battery has a 75A "Continuous Discharge Limit (BMS)" or "max continuous discharge current" (same thing) that is pretty much spot on the 1000W inverter limit suggested by your maker. At that point the BMS should disconnect, not self-destruct as they seem to be suggesting.
Edit: I re-read your replies and see your battery is 200A max (presumably continuous). That makes their 1000W inverter limit even more puzzling.
Interested to hear what they say after you've spoken to them because I'm close to buying a lithium (~120Ah) for camping.
632901
Reply By: Allan B (Sunshine Coast) - Monday, Aug 10, 2020 at 20:30
Hi George,
The simple answer to your question is 'yes'.
Limiting your inverter load to 1000W would satisfy the battery manufacturer's requirement.
No need to theorise why the manufacturer imposed that limit. It would be pure conjecture.
I can imagine possible reasons for the limitation but would not indulge in conjecture.
If you cannot accept the 1000W load limit then ask the manufacturer's advice.
632903
Reply By: Peter_n_Margaret - Thursday, Sep 03, 2020 at 17:47
LiFePO4 lithium batteries have only 3 or 4 useful advantages over AGMs.
1. Lower weight.
2. Longer life (probably/maybe).
3. The ability to deliver higher discharge rates with less voltage drop.
I don't understand why one of those would be so compromised by a manufacturer/seller to destroy that feature.
That only leaves lower weight as a reason I would buy one of these particular batteries and since there are better choices, that won't happen.
633256
