jayco swan - Leak
Submitted: Sunday, Aug 09, 2020 at 17:12
ThreadID: 140350 Views:15067 Replies:7 FollowUps:6
hello all, we've just purchased our first 2004 Jayco swan outback's would love some assistance
Took it away for a test weekend and had some bad weather which was what we wanted tfor finding issues (which we did)
We had water dripping through the canvas on both bed ends. Mainly on the stitching but also from the top of the bed frame as would run down. Canvas looks in good condition but didn't do well in the rain
I kow canvas is wet to touch and water will seep through ifsomething is touching the canvas but different story when your mattresses are soaked.
Is beeswax rubbing on the stitching a good starting point?
Sprays would do more damage in the long-run?
Appreciate your time
Reply By: Member - Jim S1 - Sunday, Aug 09, 2020 at 17:33
Hi James
We have a canvas roofed camper, an Ultimate, and the recommended re-proofing compound is Dynaproof
re-proofing .......
http://www.mcsaddlery.com.au/dynaproof-canvas-reproofing-formulation-648.html
Not sure where else you can buy it. Might be a good idea to check with Jayco if Dynaproof is OK for their canvas.
Wouldn't start any waxing just yet, because the age of the camper suggests that a re-proof might be what it needs.
Good luck, and be careful with canvas. It's easy to screw up . For example, only wash with clean water ...... no detergents.
Jim
"Sometimes I sits and thinks, and sometimes I just sits." A fisherman.
"No road is long with good company." Traditional
AnswerID: 632879
Follow Up By: James T84 - Monday, Aug 10, 2020 at 10:52
Thanks for that wilk have a chat with Jayco this morning
FollowupID: 909805
Reply By: RMD - Sunday, Aug 09, 2020 at 17:48
I previously had a similar type camper and fitted sail track across each end of roof so a fly sheet could be fitted. It ran water away from the top canvas edge and was wide enough to protect the sides a little too. A couple of ropes and poles each end but well worth doing.
AnswerID: 632880
Follow Up By: James T84 - Monday, Aug 10, 2020 at 10:53
thanks for that
FollowupID: 909806
Reply By: Member - MIKE.G - Sunday, Aug 09, 2020 at 19:50
Hi James.
As mentioned cotton canvas is very temperamental and can be damaged very easily. Don’t use wax to proof seams or detergent to clean the fabric before carrying out a few basic steps.
Water coming through the stitching? This may be because the canvas has not been wet for a long time and the cotton stitching thread has shrunk.
Moisture coming through the canvas? This may be that the canvas has opened up over time having not had a regular soaking. Periodical wetting will prevent this by shrinking the canvas.
I suggest you put up the camper and thoroughly wet it down, let it dry completely and do it again. If the canvas has not been compromised by previous treatments, it should close up.
I do this regularly on my camper.
Good luck.
Cheers, Mike
AnswerID: 632882
Follow Up By: James T84 - Monday, Aug 10, 2020 at 10:54
thanks Mike
FollowupID: 909807
Reply By: Member -Pinko (NSW) - Sunday, Aug 09, 2020 at 20:21
I too once had a Jayco Swan.
I agree with RMD. I had sail tracks with vinyl flys and white shade cloth that was fastened to the fly edges and hung down vertically.
This not only gave protection from rain but also the sun. Jaycos without flys can get incredibly hot.
I also have an Ultimate Camper and it does have a double canvas roof with an air gap between. I do reapply a waterproof compound made by the canvas manufacturer but not the one mentioned above. My product has a hydrocarbon base which evaporates after application and leaves a beeswax sealant on the canvas.
AnswerID: 632884
Follow Up By: Member - Jim S1 - Sunday, Aug 09, 2020 at 20:51
Yes, that's correct, Pinko.
"Aged canvas should be rejuvenated with Dynaproof Reproofing Formulation. This product is available in water based and solvent based solution."
Good to remember that canvas must always be dried completely before it is packed away ........ and never store it on concrete.
Jim
FollowupID: 909794
Reply By: OzzieCruiser - Sunday, Aug 09, 2020 at 22:55
Did you have the bed end flys up? Sounds like that is a no - put them up and you should be OK.
AnswerID: 632887
Follow Up By: James T84 - Monday, Aug 10, 2020 at 10:56
Dont have any but I'm aware of them now and am going to Jayco to check them out
FollowupID: 909808
Follow Up By: Nomadic Navara - Thursday, Aug 13, 2020 at 12:31
Check your local canvas/tent makers for comparison deals as well.
FollowupID: 909850
Reply By: swampy - Sunday, Aug 09, 2020 at 23:29
hi
canvas water proof solution
bradmilloutdoor.com.au/files/2012/08/BradProof-Specification-Sheet-2011.pdf
clean AS DIRECTED in PDF [no product substtution] [cleaners can be more or less concentrated ]
Using incorrect cleaner will damage canvas
https://www.ebay.com.au/itm/BRADMILL-BRADPROOF-WATERPROOFER-2L-OR-5L-AQUEOUS-BASED-/252072204669
AnswerID: 632888
Reply By: Rangiephil - Monday, Aug 10, 2020 at 17:15
I use Joseph Liddy Dri seal on my 1998 Camp'o'matic.
I have done it twice and it has held up in the heaviest rain.
It will discolour the canvas to a small extent but the waterproofing is worth it.
I was in a series of 4 storms one night in Karratha and in the morning there were a few drops on the floor but just about every caravan in the park leaked, as evidenced by all the ladders out and windows being sealed.
Regards PhilipA
AnswerID: 632899
