HELP: 12v water pump tripping enerdrive lithium bms
Hi all,
I'm having a few dramas with my 200Ah lithium B-TEC from Enerdrive.
I have 2 different water pumps and they both seem to be causing the BMS to cutout when the pump is priming or switched on. The battery state of charge is 99% and the battery volts is at 13.4. The pumps only draw a max of 3.5 amps and they are not tripping a 5amp fuse. I have a whole lot of other accessories that do not cause this to happen including a fridge/freezer, uhf, a few lights, and even tested my air compressor which draws 40amps and it did not trip the BMS.
Does anyone have any advice on how to stop the pumps from cutting out the BMS?
Thanks - Pat
