Loose goose neck
Submitted: Wednesday, Jun 03, 2020 at 14:59
ThreadID: 140107 Views:11053 Replies:12 FollowUps:21
Have they solved the problem of a loose or rattling goose neck in the LCR 200 series or can somebody make a suggestion of how to fix.
Reply By: Gone Bush (WA) - Wednesday, Jun 03, 2020 at 15:28
Shims.
You can make your own or buy some from Toyota for this specific issue.
AnswerID: 631967
Follow Up By: Member - reggy 2 (VIC) - Wednesday, Jun 03, 2020 at 15:47
Thanks Gone Bush it's for brother he has done that still rattles.
FollowupID: 908363
Reply By: Member -Pinko (NSW) - Wednesday, Jun 03, 2020 at 15:38
Reggy 2
This is what I came up with.
AnswerID: 631969
Follow Up By: Member - reggy 2 (VIC) - Wednesday, Jun 03, 2020 at 15:45
Thanks Pinko that looks good.
FollowupID: 908362
Follow Up By: RMD - Wednesday, Jun 03, 2020 at 15:58
Pinko
That is a good solution but the U bolt takes the ballweight load and is in tension, instead of the Tongue bottoming in the receiver at the rear. I would imagine it works well. Many use a bolt in a threaded hole inboard of the pin so it holds the tongue unit hard against the receiver rear bottom edge. Only force on the screw is the upward movement of the tongue which should be lesser of the two situations.
A dmax towbar has a bolt and locknut through a welded on nut on one corner so it shoves the tongue upward and sideways at the same time, it is forward of the pin. So takes any side slop and rotational slop. Just supplied that way.
FollowupID: 908365
Follow Up By: kgarn - Wednesday, Jun 03, 2020 at 16:08
Pinko,
Your picture doesn't look like a LC200 receiver.
This looks like a LC200 receiver:
Ken
FollowupID: 908366
Follow Up By: Member - reggy 2 (VIC) - Wednesday, Jun 03, 2020 at 18:59
Thanks Ken this looks similar as above only in reverse because there is no extension on the towbar this is most likely be the closest.
There's room for the u bolt plate to go under the towbar.
FollowupID: 908372
Reply By: GarryR - Wednesday, Jun 03, 2020 at 15:50
Are you talking about where it goes into the receiver of the tow bar eg Haymen Reece hitch style. If that is the case, my son in law has a bolt on the side of the receiver that you lock onto the hitch then do up, then lock nut so the bolt does not rattle loose. He has the a 200 series altitude crusier
location - Warragul -Victoria
AnswerID: 631970
Follow Up By: Member - reggy 2 (VIC) - Wednesday, Jun 03, 2020 at 15:58
Thanks Garry R .
It is that type of hitch he had that in mind at first but Toyota said he would loose his warranty so decided against it.
FollowupID: 908364
Reply By: GarryR - Wednesday, Jun 03, 2020 at 16:01
the hitch was fitted after market, and was a Haymen Reece hitch and not Toyota. It came std with the anti rattle lock bolt on the side of the receiver
AnswerID: 631971
Follow Up By: Member - Boobook - Wednesday, Jun 03, 2020 at 16:45
GarryR, the hitch is built right into the chassis on a 200. You can't buy a 200 without that.
I would be very surprised if he fitted a HR as well as the standard one.
FollowupID: 908370
Reply By: Batt's - Wednesday, Jun 03, 2020 at 16:45
Done a 60ser I owned yrs ago by running a zig zag weld down 2 sides of the tongue then grinded it down till a snug fit it worked well.
AnswerID: 631972
Reply By: Mark C9 - Wednesday, Jun 03, 2020 at 17:31
its bloody annoying for sure.
My HR came with 2 x very thin shims that are hammered in. Be warned as they are very difficult to get out. Why couldn’t they just make the one with a bolt that is tightened up?
AnswerID: 631975
Reply By: Gronk - Wednesday, Jun 03, 2020 at 18:43
Never noticed mine rattling. With 1.7T and 240kg on the ball, I would have thought the hitch would always have downward pressure, thus no rattling ?
AnswerID: 631976
Follow Up By: Mark C9 - Thursday, Jun 04, 2020 at 07:45
Question, is your stereo wound right up and windows closed? :)
FollowupID: 908380
Reply By: Member - reggy 2 (VIC) - Wednesday, Jun 03, 2020 at 21:30
Thanks all for you're response will pass on to brother.
AnswerID: 631979
Reply By: Gbc.. - Thursday, Jun 04, 2020 at 06:24
Those anti rattle bolts are for a no load situation only. Leave them done up during a towing trip and the bolt end will mushroom and the head will snap off trying to loosen it enough to get the receiver back out. Some brands are worse than others.
Page 14.
https://toyotamanuals.com.au/images/towing_guide-toyota.pdf
AnswerID: 631985
Follow Up By: Member - Jim S1 - Thursday, Jun 04, 2020 at 08:55
Mmmmm ..... thanks Gbc, that seems like very good advice. I have left mine tightened, and will in future loosen it when towing. Makes sense to me.
Jim
"Sometimes I sits and thinks, and sometimes I just sits." A fisherman.
"No road is long with good company." Traditional
FollowupID: 908383
Follow Up By: RMD - Thursday, Jun 04, 2020 at 09:31
Perhaps possible if bolt grade is soft but never seen one mushroom. The whole idea is to have it tight and secure during travel so the undulating action and sideways movement are eliminated and receiver wear and distortion is minimized or doesn't happen at all. At the very inner most edge of my HJ61 Bar I drilled and tapped an 8mm hole and simply screwed an 8 mm bolt to make the whole thing stop moving. It left the ball weight pushing the tongue into the receiver at the rear edge where is most often is anyway. You would not leave it loose while driving it ruins the whole idea of having it in the first place. The grit people speak of in ball hitch doing a grinding paste action, also happens in the receiver IF allowed to move while driving.
The pin is designed to capture the tongue and any continual inward/outward movement and side ways movement will see the tongue and receiver pin hole become more and more loose. Having it locked down just means the pin takes shear forces as intended. No way do you want it flogging around with 2.5 or 3 ton doing it's destruction.
I have plated the sides of some receiver for people where the whole hole thing was enlarged and sleeved the tongue in some cases so suitable clearance is restored.
FollowupID: 908386
Follow Up By: Gbc.. - Thursday, Jun 04, 2020 at 10:32
If any of that was the case, It would then stand to reason that the bolt should be in the top of the receiver rather than bearing the whole towball mass as a point load in the base of the hitch in front of the pin or worse, at 45 degrees from a bottom corner like some are. It takes ten minutes of towing to wreck them.
FollowupID: 908391
Follow Up By: Frank P (NSW) - Thursday, Jun 04, 2020 at 10:54
The anti rattle bolt on my towbar is behind the pin and underneath so cannot be used when towing for the reasons stated above. If it was in front of the pin it could be used while towing. Why didn't the manufacturer think of that?
Agree with Gbc. If intended to be used while towing, it should be on top if behind the pin, and underneath if in front of the pin.
FollowupID: 908393
Follow Up By: RMD - Thursday, Jun 04, 2020 at 11:46
It seems we are talking at cross purposes. The Bolt has to be forward of the pin and as far forward as possible. Not much effect trying to rectify the issue is possible if near or behind the pin. ie, bolt best at bottom region underneath It cannot be on top. Some thought as to the spread of forces within the receiver would be best, nothing which localizes forces to one area in the receiver is a wise move.
FollowupID: 908395
Reply By: Ron N - Thursday, Jun 04, 2020 at 10:56
For rattling hitches, I fabricate two pieces of thin steel plate that fill the gap, side and top, and then tack-weld the plates to the hitch tubing.
Clean up the tack welds and the plates with a sanding disc on an angle grinder until they are smooth.
Run a flat file through the top, bottom and sides of the receiver, to ensure the surfaces are flat and smooth.
Test fit the hitch to the receiver, ensuring a snug slide fit.
Then coat the inside of the receiver and the hitch tube with a coating of Loctite (or other brand) nickel-based anti-seize.
Slide the hitch in, and the rattle is gone for good - and the hitch will always slide out again easily, thanks to the anti-seize.
About every 12-24 months you need to apply some more anti-seize, to ensure the coating isn't becoming degraded.
The whole aim is to reduce the clearance between hitch and receiver to about 0.5mm, rather than the 2mm to 3mm of the "factory fit".
Cheers, Ron.
AnswerID: 631988
Follow Up By: RMD - Thursday, Jun 04, 2020 at 11:37
The whole thing becomes an inertia problem if the clearance is too great and it flogs. Shims do it, sensibly placed screw feature can also help. If there is a gap and also around the pin, it is impact wear which occurs. Far better to push start a car with a PUSH, rather than gain momentum and repetitively hit the car at 50km/hr, which is sort of like the take up, if gaps are too big.
FollowupID: 908394
Reply By: Allan B (Sunshine Coast) - Thursday, Jun 04, 2020 at 12:34
Hayman Reese claim to have solved rattle with their SmartPin.
AnswerID: 631990
Follow Up By: Gramps - Thursday, Jun 04, 2020 at 12:51
HR Smartpin works fine for me. No rattle problems at all.
FollowupID: 908399
Follow Up By: Member - reggy 2 (VIC) - Thursday, Jun 04, 2020 at 20:16
Hi the hole for pin in the towbar on the LCR200 is round does not have slots I still find it hard to take in that pushing goose neck side ways stops neck from lifting up and down.
FollowupID: 908415
Follow Up By: RMD - Friday, Jun 05, 2020 at 07:46
Allan.
You have to laugh at the wording which says you "can use the pin while towing". Anyone with a small degree of reasoning would expect a pin to be in there. The SO CALLED smart pin only sort of holds the tongue sideway and can't stop porpoising of the tongue as it tries to rotate with up and down movements . Looks fancy but hardly doing much, especially if the slop is rotation around the pin.
FollowupID: 908418
Follow Up By: Allan B (Sunshine Coast) - Friday, Jun 05, 2020 at 09:06
Yes RMD, one can also only wonder about the bit.... "Unlike other hitch pins on the market....." which presumably can't be used whilst towing!!!!
But it is "Gold Plated". Think I'll put one in the Troopy even though I'm not towing. lol
FollowupID: 908420
Follow Up By: Member - David M (SA) - Friday, Jun 05, 2020 at 09:14
Bit flash for the Troopy Alan.
Dave.
FollowupID: 908421
Follow Up By: RMD - Friday, Jun 05, 2020 at 10:12
Gee Allan! with one of those gleaming in the hitch, the troopy will look as "flash as a rat with a gold tooth". Be careful, you may be starting a new trend!
FollowupID: 908422
Follow Up By: Allan B (Sunshine Coast) - Friday, Jun 05, 2020 at 10:23
Ah, just like Roz, she loves a bit of bling. lol
FollowupID: 908424
Reply By: Dion - Tuesday, Jun 09, 2020 at 12:39
Let it rattle.
If it rattles, you know it's obviously loose and you'll be able to remove it whenever you want to.
If it's not rattling, it's a bit like a very quiet 4 year old kid, up to no good. If it can't rattle, the void spaces will fill up with moisture trapping dirt and dust, next thing it's 'rust welded' itself in there and requires a great deal of effort to remove.
I've only ever had one hitch I had tightened up with anti rattle bolt. After an hour of pounding shit out of it with a 14lb sledge hammer, heating it, spraying penetrene in it, pulling against a sturdy tree, it finally succumbed and came out. The anti rattle bolt was not put back in. Any other towbar I've had fitted since then, the anti rattle bolt is removed straight away and significantly more than 1.5m of social distancing was applied to that bolt.
AnswerID: 632041
